My Second Attemp to process this data...
4 replies161 views
Andrew Topper avatar
📷 June Ha RegionJune Ha Region
https://app.astrobin.com/i/rmeadn/
This is my second version of this image. I wanted to get the stars correct from RGB filters and using foraxx. Any suggestions at making this one better given constraints of equipment and location. Much appreciated.
Fritz avatar
Dear Andrew,
much better colors in your second attempt, you eliminated the green tint very nicely. But someting went wrong with the stars: the bright star in the upper left corner shows artifacts in the core and in general I have the impression, that you reduced the star size just a little bit too much. To sum it up: try to combine the colors of your second attempt and the star shapes of your first attempt.
In PI I simply would extract Lum form your first attempt, blur the second picture a little and make an LRBG combination by using Lum from the first picture.
Just my 2c, it is a nice picature as it is now.
Best Regards
Fritz
Helpful Insightful Respectful Supportive
IMO it’s not a very strong composition, there really is no clear subject. I actually think the composition is stronger with your original image because you cropped in more but it’s still a bit awkward. it’s a common problem with super wide field images like this. Perhaps going back to your original crop and presenting it vertically would help.
📷 faf2bc5c-2a70-468c-8e8a-82d296a1d261-1751760849.jpgfaf2bc5c-2a70-468c-8e8a-82d296a1d261-1751760849.jpg
If you could get a bit more emphasis in the very faint Ha on the left side I think you’d have a image that compositionally, works a lot better.
Thank you both for the input. You have given me some good feedback to think about. I will post an updated image in a few days.
Brian Diaz avatar
work on the background, noise, and contrast, the rest is fine
crop, colors and details, for second step
[RCC] SHO M16 Current Version and Narrowband Processing
I’m still working on narrowband imagery processing and would appreciate any comments you have on my current version of M16 or the workflow below. My goal here was to get as much detail and brightness as I could in the “jewel box” outer nebula while r...
Narrowband processing workflow discussion relevant to RGB filter color correction work.
Sep 20, 2025
One Click, Real Science
Early last summer, while I was working on a new image, it occurred to me that the SpectrophotometricColorCalibration tool in PixInsight was generating all of the information that is needed to plot star data from a globular cluster as a Hertzsprung-Ru...
Color calibration tool directly applicable to achieving accurate star colors in RGB.
Oct 13, 2025
[RCC] Seagull Nebula
Please provide your critique on the Seagull Nebula. It is imaged in dual narrowband using OSC. So far collected ~7-8 hours using L-extreme filter and 1 hr for RGB stars. The nebula is using the filter, while the stars are RGB (no filter used). Planni...
RGB star correction in narrowband imaging; directly addresses author's star processing concern.
Jan 26, 2025
My first Andromeda Galaxy project
Andromeda Galaxy(M31) Hi! I am new in astrophotography and here in the forum. Last night i shot the Andromeda Galaxy with the beginner equipment that i have: Canon eos250d Canon 75-300mm len (used 200mm) Asiair pro Eqm-35 mount Iso 800 F/5 I take 73 ...
Second processing attempt; relevant for processing feedback on similar deep-sky object.
Sep 4, 2024
