AstroArg avatar
It’s been kept away for a while in its case, indoors so not anywhere cold or potential with damp.
I decided to try and use on a 2nd setup.
In the past, it’s been fine and I used on many outreach sessions.
Problem now is that even though it starts up, connects and the hand controller shows no issues, the mount will not respond to slews. I have tried to do a calibration when starting up, whilst it seems to work it’s very slow and takes 20-30 mins to complete.
I’m not sure if there may be an issue with one of the boards (or more than 1). I’m in the UK, the mount is well out of warranty, I may take to Altair Astro as they are UK servicer but just wondering if anyone has any ideas that may help. I’m going to try and get some videos over the weekend, but just wanted to get the ball rolling, in case someone understands what I’m on about without seeing the videos!
thanks in advance,
Luke
Does it show it is tracking and does it tick if it does? Beyond that I'd ned to see it. I'm in the UK too so I might be of help (and don't put too much stock in the service capabilities of AA!).
AstroArg avatar
andrea tasselli · Sep 19, 2025, 04:34 PM
Hi Andrea, thanks. Most of my kit is from AA, has been for the last 4 years and never had issue. This mount was 2nd hand though, on a whim but has been fine until now (cant actually remember when I got it, think 2022 maybe earlier).
It makes a very high pitch ‘whine’ and then that stops but still no response.
Let me grab vids tonight, thanks for quick reply.
High pitch whine means usually motor stalling, as if something is seized.  I also have quite few bits from AA but their repair shop I find a bit lacking.
John Tucker avatar
I”ve interacted extensively with the service crew at the US shop in Woburn, MA. They are very patient in discussing problems by email and have lots of PDF instructions for do it yourself adjustments. If you have any confidence in your mechanical abilities at all it might be worth sending an email to support@ioptron.com
Georg N. Nyman avatar
I got the same mount for my mobile setup and had similar problems. I updated all firm- and software to the most actual version, disassembled the entire electronics parts, reconnected all connectors and now it works fine.
Georg
Strong Horizontal Banding
In the last few days I found that the images acquired by the Altair A26C (a rebrand of the Touptek equivalent IMX571C-based camera) is starting to show significant and variable horizontal banding and I'm wondering whether the good people of AB ma...
Camera storage and reactivation issues similar to reported hardware problems.
Dec 9, 2025
NexStar Evolution 6 — Strange Motor Behavior After PC Disconnect
I was planning to take pictures tonight, but unfortunately ran into an issue with my Celestron NexStar Evolution 6. I use CPWI for alignment and NINA for imaging. While the mount was slewing to the target, my PC lost connection to the mount. Before I...
Mount not responding to slews; similar motor/connection issue troubleshooting.
Oct 17, 2025
AM5N weird noise while GOTO movements
Hi ! Since I mounted a telescope of around 16 kg on the AM5N with counterweight , I’ve started to notice this noise when performing GoTo slews. Guiding is not affected, but I’m concerned about the noise and it seems to be getting worse. Do I need to ...
CEM25EC mount issues may relate to similar mechanical problems.
Feb 11, 2026
Harmonic Mounts and Belt Replacement (Ioptron HAE29C)
To cut a long story short: Recently, the RA Axis of my Ioptron HAE29C (both axis Harmonic gears) mount stopped responding. After some email exchanges with Ioptron, I decided to open the front panel of the mount. The belt on the RA Axis was broken. No...
Mount axis stopped responding; relevant diagnostic and repair experience shared.
Sep 15, 2025
Help me choose a Strainwave/Harmonic Mount!
Hey folks, Hope you're all having a great day out there! I'm on the hunt for a new portable mount for astro imaging with a range of gear, starting from a camera lens/dedicated camera combo right up to a small wide-field refractor and camera. ...
Author seeks portable mount; CEM25EC is compact iOptron alternative.
Apr 3, 2025
