Seti Astro Suite Pro - Windows11 with Norton 360
14 replies266 views
Georg N. Nyman avatar
A question for you all - in case you have already downloaded and installed the new Seti Astro Suite Pro!
My workstation is running with Windows 11 and Norton 360 - downloading the Suite did only work after I had stopped Norton 360 protection. I was then able to install the suite and run it - as long as Norton 360 was disabled. But I need to have Norton active as you can imagine - however as soon as I enable Norton 360, the suite is automatically closed and locked away - Norton tells me, it is a dangerour malware.
What I can I do? Any advise available?
Thanks and CS
Georg
bigCatAstro avatar
Georg N. Nyman · Sep 18, 2025, 02:59 PM
Thanks and CS
Georg
I’m not a Norton 360 user, AVG Internet Security subscriber here, but there should be an exceptions list you can add Seti Astro Suite to so that the anti-virus software doesn’t move the software to quarantine.
Per Norton 360:
“Add exclusions for your Norton scan
  1. Open your Norton device security product.
  2. On the left pane, click Security.
  3. In the Security dashboard, in the Scans tile, click Open.
  4. In the Scans window, click the Exclusions tab.
  5. Click Add/Add Exclusion.
  6. In the Add Exclusion window, click the browse icon.
  7. Navigate and select the file or folder that you want to exclude from Norton scans, and then click OK.
  8. Click Add.
    The item is added to the Exclusions list.
To exclude a file from Download Intelligence, you must download the file to an excluded folder. You can add a folder to the Exclusions list and then download the file to that folder.”
Hope this helps!
bigCatAstro avatar
AstroStew · Sep 18, 2025, 03:20 PM
I use AVG and had Set Astro listed as an exception, and still couldn’t use Seti Astro when AVG is turned on, if it even opens at all, so had to give up and delete seti Astro, I also sent a message to Frank about it, but he was not at all really interested, which was a shame ☹️
That’s a shame, sorry to hear that.
Mikołaj Wadowski avatar
Thanks and CS
Georg
For 99% of users third party AV software is completely pointless. If it gives you any issues, uninstall it. Windows defender is sufficient nowadays.
Edit: + given Norton’s past, I’d say that, ironically, it itself is more of the malware it’s trying to protect you from :)
Mikołaj Wadowski:
101% agreed
Alan Brunelle avatar
andrea tasselli · Sep 18, 2025, 06:20 PM
Mikołaj Wadowski:
101% agreed
102% agree. As a person who spent many years in Microsoft Land and having almost all my friends and acquantances be MS employees, all the trusted ones told me to ditch that particular antivirus (and any others). Not only do they cause a whole suite of problems, nothing, bar nothing, will put a larger strain on your computer’s ability to perform.
If you take risky actions with your online activities, then that is where you should invest your efforts. And at least isolate your activities on those computers that matter the most to you.
Gerald avatar
bigCatAstro · Sep 18, 2025, 03:39 PM
No, that’s not a shame. You cannot expect a developer to test his sofware with all available AV softwaree on the market.
And, as expressed already by others, any other AV software than MS Defender is pointless. Especially Norton…
AV Software should not be installed at all on the observatory PC. Protection on network level is the key to security.
AstroArg avatar
the answer here is for you to uninstall AVG. Unless you are doing some serious worrying activities on that PC, you do not need AVG, Norton or any other free/subscription based AV. Microsoft invested a lot in Defender, it does exactly what it needs to do and is a key cog built into W11.
bigCatAstro avatar
Gerald · Sep 19, 2025, 03:39 PM
I’m sorry, I don’t understand the tone taken here. Expressing empathy at someone’s situation doesn’t equate to the level of response taken in this message.
That said, sure, you can use Windows Defender—I’m not advocating for any software to be used over an other.
Thank you all for your constistent replies!
Georg
Gerald avatar
You're right, my tone was sharper than it needed to be, and I apologize for that. I reacted strongly because I thought the word 'shame' implied blame on the developer, and I wanted to defend them. I see now you were just being empathetic. My point about AV software was a separate rant that I shouldn't have bundled into my response.
Well written Respectful
Paul H avatar
Hi Georg,
I use SAS Pro, Windows 11, and Norton.
  1. Open Norton.
  2. Click the Security tab.
  3. In the new window click on Quarantine.
  4. You should see the Seti Astro Suite file in quarantine.
  5. Look for the option to edit. (Maybe 3 dots to the right). Look for the Restore option. This will move the file back to it’s correct location.
  6. For the first startup Windows Defender will complain. Choose to run anyway and you’ll be good to go.
This is what I have to do with every update Frank does. Takes under a minute and is no issue at all.
Please reply if you are still having issues and I will delete SAS Pro and reinstall so that I can do screen captures for you.
Paul
Well written Helpful Supportive
Paul H · Sep 20, 2025, 03:08 PM
Hi George,
  1. Open Norton.
Paul
Hi Paul,
Thank you so much for your productive and good answer and reply - I did as you suggested and it works now !
Thanks again and CS
Georg
Paul H avatar
Georg N. Nyman · Sep 20, 2025, 04:04 PM
Hi George,
  1. Open Norton.
Paul
Hi Paul,
Thanks again and CS
Georg
Hi Georg!
Yay! Glad it’s working for you now!
CS! Paul
Orion StarShoot guide scope downloads needed for Windows computer
i have an orion starshoot guide scope, what downloads do i need for windows computer and where can i find them, thanks much
Windows software installation question relevant to astronomy equipment setup.
Dec 2, 2025
Twinkling stars?
Hello Astro Imaging Junkies, I have a question. I have seen “twinkling” stars in some to the Images when I view in “presentation mode”. Is this a process available in Pixinsight, Seti at home or any other software or is this something available form ...
Discusses SETI Astro Suite Pro software mentioned in original post.
Oct 31, 2025
Graxpert
Does anyone have trouble installing graxpert on windows? I try to run the app and nothing happens. I have uninstalled the antivirus and still won’t run. Any advice ?
Windows 11 with antivirus software causing application issues; directly relevant.
Nov 30, 2023
Basic new install glitch
Hi folks, I completed a brand new install on a Win 11 Pro machine and am unable to download updates from any non-PI repositories. This is version 1.8 .9-3 build 1612. I'm getting a 'network error 301' . Not sure if it's a windows 11 s...
Windows 11 security software potentially blocking network connections/updates.
Nov 13, 2024
Complete Windows 11 astrophotography PC build guide from scratch
🛰️ Windows 11 Astro Imaging PC Full Build Guide From Bare Metal to Stable Observatory Appliance This guide describes a complete rebuild from scratch of a Windows 11 PC used exclusively for astrophotography. The goal is not convenience. The goal is st...
Windows 11 astrophotography PC build guide addresses OS compatibility issues.
Dec 18, 2025
