New mini PC won't boot after remote imaging session
Jerry GerberJohn HayesChris White- Overcast ObservatoryKevin MorefieldDark Matters Astrophotography
34 replies695 views
Jerry Gerber avatar
I got the new mini PC set up remotely and it’s blazingly fast, faster than I even expected. All went well on the first night of imaging with it. But this morning when I downloaded my data, I shut the computer off and it kept trying to reconnect. I asked Google what was going on and I tried a few remedies but none of them worked. I tried shutting it down again and then it kind of froze for a short time and I got disconnected. I waited a few minutes and cut the power with the WPS.
This afternoon I turned on the WPS and now the computer won’t even boot up! Brand new machine, brand-new installation of Windows 11. Before I shipped it to the observatory I installed all the software and tested it multiple times and all was well. BIOS was configured properly for remote power on.
Hmm….
Well written Engaging
Kevin Morefield avatar
Three initial questions:
1) What service are you using to connect remotely to the PC?
2) Did you alter the Bios so that it would boot on power up?
3) Why are you turning off the PC?
Kevin
V avatar
Kevin Morefield · Sep 18, 2025, 12:34 AM
Most important question here, just set the PC to sleep or win+L to lock it. Turning it off will just introduce problems like this.
Jerry Gerber avatar
Kevin
  1. Tailscale and Windows Desktop Remote
  2. Absolutely, tested it several times before shipping the PC to HCRO
  3. I’m beginning to ask myself the same question… Do you leave the PC on 24/7, even in the summer when the inside of the observatory can get pretty hot?
Thanks Kevin!
Jerry Gerber avatar
V · Sep 18, 2025, 01:10 AM
How do you prevent the computer from going to sleep, say at 2am when imaging is taking place?
Jerry Gerber avatar
It’s working now, Greg went into the observatory and told me the password was the problem, so I got rid of the Windows password. It was never an issue over the past year and a half since I’ve had my scope at a remote site.
I guess I should just leave everything on, 24/7?
Jerry Gerber · Sep 18, 2025 at 03:20 AM
It will not go to sleep as it is actively doing something. It might disable the display, but you can set that to never happen in the settings if you want.
Jerry Gerber · Sep 18, 2025 at 03:23 AM
Yes, there is no good reason to ever turn it off.
Jerry Gerber avatar
Dark Matters Astrophotography · Sep 18, 2025, 04:04 AM
Anyone use hibernation instead of sleep mode when using a PC remotely?
Jerry Gerber · Sep 18, 2025 at 05:08 AM
No, I change the settings to turn all of that off.
Jerry,
Aside from power outages, my observatory PCs have been on for years. I go into the power settings and turn off any setting that would cause it to sleep, hibernate or shut down. I also have found (special with QHY cameras) that you need to dig deeper and turn off the USB power saving setting that can cause the USB to stop responding.
Kevin
Jerry Gerber avatar
Kevin Morefield · Sep 18, 2025, 05:53 AM
Jerry,
Kevin
I definitely don't have sleep or hibernation turned on when the computer is idle during the night or when it's imaging!
That being said I'm thinking why not have the PC sleep or hibernate after I've downloaded all the subs in the morning? It saves energy and the computer isn't doing anything until the evening when I start imaging again.
then I shit the computer down after a session
I hope not, it's got to be pretty painful...
Jesse Priolo avatar
I usually set up my mini PCs with a local account, disable any settings requiring a password to access the PC, and disable the lock screen, which allows for automatic login on power on or reboot.
Annoyingly, even with “sleep” set to “never” under power options, I’ve still had my mini PC randomly sleep or shut down during an imaging session.
Then I discovered Windows PowerToys, which includes a module called “Awake”. There’s a setting in there to “keep awake indefinitely” which keeps the PC from ever going into sleep unexpectedly. Since installing this, I haven’t had a problem.
Also, make sure your “active hours” are set to your normal imaging times, so the PC doesn’t randomly reboot for an update during those times.
Well written Helpful Insightful Concise Supportive
Arun H avatar
Yea, that brought up a rather unpleasant image.
John Hayes avatar
Jerry,
I turn my remote PCs off every single night and I’ve been doing that for 8-9 years without any problems. If you can’t turn off your PC for fear that you won’t be able to get it booted again, there is something wrong. Kevin and I have discussed this topic as a question of best practice a couple of times. One way of thinking is that the thermal cycles that happen during a power cycle are what might accelerate age induced failures. Another line of thinking is that the electronics (including fans) last for a certain amount of run time before something fails so it’s best to keep it running only when needed. I’m not sure which is right but with Windows, I personally prefer to start with a freshly booted PC that doesn’t contain some lurking problem that will shut my system down after a I get it started. I’ve run into enough problems along the way that require a full system reboot to fix to be very skittish about Windows (I run Win10 on both of my machines). My Macs run for a year between reboots but I personally want to do a fresh reboot every day with Windows, which is why I shut down all of my equipment every single morning.
BTW, I also run wide temperature range, ruggedized industrial grade, fan-less PCs on both of my remote scopes. The control enclosures have fans to keep the internal temperatures reasonable (and to spread a uniform deep lay of dust over everything inside). They have been out there for years and so far, these PCs just keep on ticking! I have these things set up to never sleep and never update. They are simply controllers and as long as they are working, I don’t care if they are running code that’s 10 years old.
The primary reason I don’t turn off my PCs is that I’m running a perpetual script. So the PC starts the session, selects the targets and finishes the session and waits for the next night without requiring my intervention.
John is right, of course, that there is no reason you shouldn’t be able to turn off the computer and reboot daily. I just want to be sure you have a reason to do so.
Kevin
Well written Respectful Concise
Kevin Morefield · Sep 18, 2025 at 05:26 PM
Kevin
Exact same use case as I have for our systems. Voyager runs perpetually for me and pulls its work from RoboTarget then restarts after the night is over to wait for the next.
Alan Brunelle avatar
I love a topic such as this where the question and solution turn out to be pretty simple and resolved, but where the varied responses teach me so much more! Maybe unaware, but you guys have answered a number of questions for me that are unrelated to the original question.
Jerry Gerber avatar
The problem I was having not being able to log in was because I had a Tailscale setting that wasn’t checked. If any of you are using Tailscale, be sure that the Remote PC has the following parameter checked: PREFERENCES-RUN UNATTENDED.
Greg and Justin, over at HCRO, also advise to leave everything on 24/7, particularly in the winter when temperatures can get low. If condensation forms on any gear, that can be bad. The warmth of the power being on helps prevent that.
I know there’s pros and cons about leaving gear on 24/7 in terms of which choice might lessen the life of the equipment (not to mention wasting electricity when something isn’t being used) but the condensation argument makes sense. Observatories are not air conditioned, at least I don’t think any are…
Well written Helpful Respectful
Read noise Astrophotography avatar
Jerry Gerber · Sep 18, 2025, 03:18 AM
Kevin
Thanks Kevin!
I leave mine on 24/7 the advert did say suitable for 24/7 operation. But I take everything in over summer the skies dont get dark enough during summer..
Jerry Gerber avatar
John Hayes · Sep 18, 2025, 03:34 PM
Jerry,
Hi John,
At the observatory where my scope is at I was told by several people that it’s better to leave everything on 24/7, particularly in the cold months as condensation can form on circuit boards if the temperature is low enough. By keeping gear on, this provides enough warmth to prevent this from happening.
Do you turn your mount, camera, filter wheel, etc. off every night as well, or just the computer?
Jerry
John Hayes avatar
Jerry Gerber · Sep 20, 2025, 04:21 PM
Hmm. Is all of your gear (other than the scope) just sitting out under the sky? This is one reason that I keep all of my gear in an enclosure. It will never get wet as long as there isn’t fog and when the temperature-dew point spread gets small enough, they close the roof so none of my electronics ever gets wet even when there’s fog.
Jerry Gerber avatar
John Hayes · Sep 20, 2025, 07:28 PM
Everything is under the roof of the observatory. I don't control when the roof opens or closes, but NINA knows and responds accordingly.
In very cold weather I've been told to leave all equipment on 24/7 to keep everything just warm enough to avoid condensation.
Well written Concise
My computer has been on 24/7 for 13 months now. I religiously update windows every 5 weeks. Ive never had a windows related problem on any of the many capture pcs I have used over the last 11 years. The same can’t be said for computer hardware. Ive had cheap mini pcs have hardware failures. Now that I use a “real” computer its been working great (the last 20 months.
John Hayes avatar
Jerry Gerber · Sep 20, 2025 at 07:42 PM
Ok, that isn’t really what I was asking so let me explain why I was checking. If your equipment isn’t in an enclosure or a cabinet, then it is exposed to the sky. In that case, I agree that you should always keep it on to keep it above the dew point. Just understand that “very cold weather” isn’t what causes condensation. Condensation will happen whenever the temperature-dew point is less than about 3C and that can happen at any temperature when the relative humidity is high enough.
Condensation isn’t the only problem that can occur when you leave your gear out in the open. At DSW, we went through a period of rodent infestation and mice chewed up a lot of cables throughout the observatory. I had to protect all of my cables and block every tiny opening into my mount and electronics enclosures. I lot of guys out there had PCs, power supplies, hubs, cables, and other gear scattered all around their scopes on the floor and I never thought that was a good idea for a lot of reasons. Half of those guys didn’t last long. Most of them gave up after having so many gear failures—probably due to condensation, mice chewing cables, poor quality gear, blown power supplies, people tripping over their stuff on the floor, and who knows what else.
Hopefully you’ve got your gear organized and protected in some kind of cabinet or enclosure.
BIOS Settings for Remote Imaging
My new Windows 11 PC's BIOS does not have a setting called 'Wake on AC'. This setting allows the computer to boot remotely from a state of being off when it receives power from the WPS. There is however a setting called State 0, which see...
BIOS settings may help resolve remote reconnection and shutdown issues.
Sep 8, 2025
Basic new install glitch
Hi folks, I completed a brand new install on a Win 11 Pro machine and am unable to download updates from any non-PI repositories. This is version 1.8 .9-3 build 1612. I'm getting a 'network error 301' . Not sure if it's a windows 11 s...
Windows 11 compatibility issue with imaging software on new system.
Nov 13, 2024
QHY10 on Windows 11
Has anyone gotten their QHY10 drivers to work on a Windows 11 machine? I have tried several suggestions found on Cloudy Nights to no avail. it may be time to retire the camera.
Remote imaging PC software/driver compatibility issues on Windows systems.
Jul 23, 2024
Best Internet Device for Powering Up (and Down) a Remote Observatory
My observatory is all of 15 km from home, but in the New England winter that's a long way. I've got all the software for automatic operation working, and thanks to recommendations from an an earlier query to an AB forum, I'm now connectin...
Remote imaging session issues may relate to power management and equipment control.
Dec 4, 2023
New PC apps list
Hi all, I want to know what everyone here installed in their PCs to use it for astrophotography except processing programs? Do you use the computer to do all your capturing such as DSO and planetary or you have separated computers for each? I am talk...
Troubleshooting mini PC issues relevant to astrophotography setup process.
May 10, 2024
