Baader >F3.4 filter on the Rasa 8
4 replies76 views
Abdul Thomas Jnr avatar
Hi. I was thinking about buying the Baader Cmos narrowband high speed filter F2 for my rasa 8. But someone is selling the Baader next grade ones F3.4. I’m just wondering if the F3.4 will work just as fine as the F2 filter on the Rasa. Thanks in advance
It'll work but not just as fine.
So there is noticeable difference between the two filters? I want the best for the Rasa you see
You got a relatively large CO so the loss in transmittance is going to be significant compared to the F2 filter. If you shoot only bright targets that might not be obvious but the faint stuff will resent it.
Okay thank you. I will just go with the F2, might as well
Baader high speed 6.5mm or 3.5mm
Hi. I’m just wondering which filter thickness to get between Baader High Speed 6.5mm or 3.5mm Narrow Band CMOS Optimised. Set up will be the Rasa 8 and Zwo 294mm pro camera. I know the 3.5mn are more expensive but I just want the best for this setup....
Discusses Baader High Speed filter thickness options for Rasa 8 setup.
Sep 27, 2025
Focuser for RASA 11V2
Hi folks, I'm setting up a RASA 11V2 and wondering what autofcusers are working for you. Thanks in advance for your input. Dave
Discusses Baader filters for RASA 8; relevant for autofocuser setup information.
May 8, 2025
Band shift vs more integration time
What would you choose? I have shot an image I’m quite happy with at f/2 and my 7nm Optolong Ha filter. However, I am aware I might have gotten some band shift. I was shooting other things and I didn’t pay attention to the f-stop at the time. Since th...
Compares f-ratio effects on narrowband filter performance and image quality.
Nov 24, 2025
