Script Not displaying under the script tab
2 replies32 views
Zhaoyu Xu avatar
I’ve installed the the Cosmic Photons Image Blend script through the repository. However, for some reason, it doesn’t show up under the script tab and doesn’t show up even when doing a search. The script appears under /src/scripts/CosmicPhotons/ImageBlend. So every time i want to run this script, I would have to go under the script tab then execute script and manually navigate to that folder and select the JS script manually. Anyone know how I can fix this?
Zhaoyu Xu:
Have you tried: Scripts>Feature Scripts>Regenerate and then select the offending script and click <Add>
Zhaoyu Xu avatar
andrea tasselli · Sep 16, 2025, 05:23 PM
Zhaoyu Xu:
ohh I didn’t know about this, it worked. Thank you so much
