EdgeHD 800 -- How long is the threaded tube on the back of the telescope?
16 replies•265 views
John Stone avatar
Take a look at this Primalucepart:  Adapter ESATTO 2" LP for telescopes with SC thread
You'll see the threaded central hole goes completely through it.  This means this part can screw down onto any tube even if the tube itself is longer than the adapter (the extra threads will stick out the top).  But this will only happen if the threaded tube on the back of the telescope is threaded all the way down to the baffle nut flange, or if the threads on the tube protrude such that the unthreaded portion will still fit inside the Primalucelab adapter.
I really need to know how far down this thing will screw onto the baffle tube.
Whatever that "screw-down" distance is will need to be added to the Celestron Published 133.35 mm backfocus spec for this telescope.
It's surprising that Celestron's been making these telescopes for what, 50 years, and I can't find anyone talking about how long they are.
And clarity on this would be very helpful
Thanks.
Jeff Reitzel avatar
đź“· Edge HD BF.jpgEdge HD BF.jpgHi John.
I am not sure if this will help or not. This is from the Celestron Edge HD scope white paper showing how the back focus is measured on these scopes. If I understand your question correctly, none of the threads on the back of the scope are included in that measurement. It starts at the top of the threaded flange away from the back of the scope. I am guessing you would have to see how that adapter fits your scope in relation to that flange and only parts above that flange (camera side) would matter. I don’t think the focuser tube itself is going to fit past that flange. Also, with the primary mirror moving to initially focus the scope, that distance will never be exact. Only a close approximation that should fit within the travel of the focuser you are adding on the back of the scope. Your initial setup should be to try and get that 133.35mm distance to fall near the center of the focuser travel. At least that is how I configured it setting up my EdgeHD 11 and everything worked out just fine with a similar style focuser.
Jeff
Alessio Lolli avatar
I personally called Celestron because I had the same problem as you and they told me that the measurement for the backfocus starts exactly from the end of the male thread on the back of the telescope and the adapters screw over the thread going to the thread and not on the back of the telescope, so any adapter will not screw completely until it goes to beat on the back of the telescope but will go to beat on the final part of the thread, that's where the backfocus measurement starts for the Edge HD 800.
So don't worry so much about the length of the thread because knowing it or not will have no influence on the size of your backfocus..
John Stone avatar
I understand that screwing on an adapter won’t change the backfocus of the telescope, but without knowing the thread depth or how far down the primalucelab adapter will go there is no way for me to find out if my imaging train will fit within the backfocus of the telescope before actually buying everything, screwing it together, and measuring.
i can’t place my order for all the equipment until I know for sure whether or not it’s going to fit ahead of time.
With the bare minimum of effort of scrolling down the page you'd have found the answer to your question.
John Hayes avatar
John Stone · Sep 17, 2025, 08:48 PM
This why you buy adapters that have a fixed size. They screw down onto the thread until they reach a lip in the adapter. The length of the adapter is measured from that lip. If you don’t want to buy a fixed adapter, there is another way to do it. Simply screw your threaded tube all the way onto the baffle nut until it is snug. Then take a digital caliper and measure the precise distance from the rear of the baffle nut to the rear lip of your adapter. Use that dimension to reference the spacing of everything that you want to mount to that part. You can also use a lock ring(s) to set the spacing as well. It helps a lot to make a scaled mechanical drawing in CAD if you have that capability.
John Stone avatar
John,
Thanks for your reply.  I appreciate your time.
I don’t own the Primalucelab adapter nor do I own the EdgeHD 800 (but I’m thinking of buying one).
That Primalucelab adapter is threaded all the way through with SCT 2”-24 threads.  It doesn’t have an internal stop flange.
Primalucelab talks about this feature in this article they published about using the EdgeHD 0.7x reducer and taking advantage of the fact that the adapter screws all the way down on the threads and how that gives them more back focus because the top of the reducer threads are now inside the focuser.
https://www.primalucelab.com/blog/support/how-to-provide-a-rotating-focuser-to-edgehd-8-with-0-7x-reducer-for-deep-sky-astrophotography/
Id like to do the same thing but without the reducer, hence my original question about how long those threads are.
Thanks
Respectful
John Hayes avatar
I can see one glaring problem here. Primaluce is confusing the terms “mechanical distance” and “optical distance” in their description, which makes their entire explanation super confusing. So, let’s first get one thing straightened out here. The backfocus (called the back working distance [BWD] in optics) is defined by the distance from the rear of the baffle nut to the focal plane. That is simply a mechanical distance between two planes. The term “optical distance” simply refers to the equivalent mechanical thickness needed for the required light path including internal optical components. This term appears to be most specific to amateur astronomy and I personally wish that everyone in the industry would dump it. It is simply too confusing for almost everyone and it can be easy replaced with some very minor adjustments due to optical widows. It is very simple to say that the BWD of the reducer is 105 mm but if we include a 3 mm filter and (say) a 3 mm camera window, the required spacing will be 107 mm. That’s the distance that will be required from the rear of the baffle nut to the sensor, taking into account the two optical windows in the system. How hard is that?
Be that as it may, the problem that Primaluce has is that when they stack up all of their gear, the “optical thickness” of the assembled stack is greater than the 105 mm mechanical BWD they have with the reducer—by 10.8 mm. Note, that has nothing to do with any notion of “adding backfocus” by screwing things together. That concept is even more confusing than computing optical thicknesses!
They are solving the problem by simply screwing the rear of the baffle nut far enough inside the focuser until the sensor is in the correct position. They can do that because of the depth of the threads on the baffle nut and the size of the aperture through the focuser. They are simply overlapping parts to get it all squeezed into the required space.
At the end of the day, I personally never trust any of this stuff until I make a scaled drawing of all of the components showing the virtual and real focal points relative to where the sensor sits. Here’s an example from a CDK17 project I did a while back—and this particular drawing doesn’t even show all of the true ray paths through the window! They are simply represented by the offset center line and the displaced focal point. This is the best way to avoid mistakes, which is really important if you have to order expensive custom machined parts.
đź“· image.pngimage.pngGood luck with it!
John Stone · Sep 17, 2025 at 08:48 PM
The depth of the thread doesn't matter to you because any adapter made for edge hd 800 that you screw on the male thread of the telescope will hit the final part of the thread, you just need to measure the optical train from that point once the adapter is mounted and then from there you set up the entire optical train until you get to 133.35 mm without reducer and 105 mm with 0.7X reducer.
Eric Emmons avatar
Hi, John.
Sounds like you are looking to build a rig similar to mine. I went through this exercise at the beginning of the year. I opted to use an OAG, so there was no way to use the reducer.
📷 edgehd8.pngedgehd8.png📷 Screenshot 2025-09-18 at 2.46.30 PM.pngScreenshot 2025-09-18 at 2.46.30 PM.pngI have no issues whatsoever with focus. I could even lose the spacers and move the focuser tube in more, but… ain’t broke, don’t fix.
Hope this helps.
John Stone avatar
Thanks for your reply.  Looks like a great setup.
However, the whole point of the article I linked to is that yes, you can use the reducer with the Primalucelab gear.  How to provide a rotating focuser to EdgeHD 8” with 0.7x reducer for deep-sky astrophotography
Also your diagram does a great job of calculating the mechanical back-focus, but you didn't account for how far down the PL3600542 screws onto the threads on the rear of the EdgeHD 8" telescope.
Finding out how far those threads are inside the PL3600542 is the what I've been asking in this posting.  Any possibility of taking off your ESATTO and measuring it for me?
Thanks.
2.5 mm i.e 1/10th of an inch.
John Stone avatar
Finally heard back from Celestron; short answer 12mm
Which means that you add 12 mm to the 133.35mm back-focus number Celestron publishes if you use this Primalucelab adapter (and screw it all the way down).
Eric Emmons avatar
I should have been more specific. If you are adding the LP focuser, rotator, and also want to use an EFW, you won’t be able to. There isn’t enough back focus. The only way I could draw it up to have the reducer, rotator, and the EFW was to lose the LP focuser and use the SESTO SENSO 2 focuser, which would mean not being able to lock the primary mirror and having to deal with mirror flop.
I would love to know if you figure out a way to get it all to fit.
Good luck.
Well Written Helpful Insightful Respectful Supportive
John Stone avatar
Eric Emmons avatar
I started with the same article. But if you notice, there isn’t an EFW in that imaging train. It’s a filter drawer. I even emailed Phillipo and asked. If you aren’t using an OAG, which I am, you may be able to make it work.
Post your results when you have it all worked out.
John Stone avatar
Eric,
I haven't done the math but let's check.
Let's start with mechanical back-focus:
2 mm      – PL3600542 adapter
54.2 mm – ESATTO + ARCO
4 mm      – PL3600215 adapter
55 mm    – Camera + FW + OAG
115.2 mm – mechanical back-focus
Let's check required optical back-focus:
105 mm – EdgeHD 8" Reducer 94242 (from end of threads)
12   mm – Length of threads on 94242
1     mm – 1/3 chroma filter thickness
118 mm – optical back-focus required from base of 94242 threads (NOT end of threads).
To make this work you just need to screw down the PL3600542 until it's telescope side is flush against the base of the 94242 (the threads on 94242 are inside the PL3600542).
Since your mechanical back-focus is smaller you can extend the ESATTO drawtube by 118 mm - 115.2 mm = 2.8 mm to make your mechanical back-focus match the optical-back focus.
This leaves plenty of room in the focuser movement for focus V-Curves.
What's your math look like?
External focuser on an SCT; What about temperature change induced focal shift and back-focus?
It seems like every serious astro-photographer is putting external focusers on the back of the EdgeHD telescopes and locking the mirrors. I picked up a nice little EdgeHD 8" and a Primaluce Lab Esatto 2" LP focuser and gave it a try myself....
Discusses external focusers on SCT telescopes and back-focus considerations relevant to adapters.
13 days ago
Askar 130 PHQ field Flattener
Does anyone know if the field flattener is in the drawtube of the focuser or if it's in the scope's tube? I ask because I am replacing the stock focuser and won't be able to use the Esatto 3" if the flattener is inside the focuser. J...
Discusses Esatto focuser compatibility and back-focus considerations for SCT telescopes.
Jan 13, 2025
Custom Newtonian Builders in the US?
Hi, I'd like to build a 10" F3 newtonian with a curved spider, and a Big Paracorr coma corrector for full-frame astrophotography. I want a carbon fiber tube and everything screwed into the focuser (including coma corrector) then OAG then Fil...
Discusses threaded tube adapters for telescope accessories and focuser connections.
May 8, 2024
PrimaLuce Lab - ESATTO 2" LP and Celestron EdgeHD 8
Hello, All. I would like some help, please. I am currently imaging with the EdgeHD 8 and the ZWO EAF when imaging with the Celestron Reducer at F7 my current back focus is 105.3mm, with the following components: 0.7x Reducer, SCT Adapter - 25.3mm, Ce...
Provides PrimaLuce ESATTO adapter information for EdgeHD back-focus calculations.
May 15, 2024
