Secondary and spider vein reflections appearing in my telescope images
3 replies101 views
Christopher Gomez avatar
Hi all
Seeing if anyone has run into the issue if having flat frames that show the shadowing and spider veins of the secondary on the RC telescopes. Mine is the IOptron version but other brands may be the same. I know with the newer models, the baffling extension was not an issue and not needed but this has me scratching my head! Is this due to the baffling issues? Light leaks? Reflections?
Any help is appreciated
Thanks,
Chris Gomez
Reflection. Are you using a flattener/reducer by any chance?
Yes, this is the Flattener im using, which is suposed to be designed to work with RCs. I used it with my RC10 in the past and didn’t have that issue.
https://www.firstlightoptics.com/reducersflatteners/ts-3-m68-flattener-for-f8-rc-telescopes.html
Remove and check with a flat. The reflection should disappear.
Serious Stray Light Issue - William Optics UltraCat 56
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope. I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The ...
Stray light issues in RC telescopes may cause similar flat frame defects.
Mar 1, 2026
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Dark frame gradients could relate to flat frame shadowing and light leak problems.
Mar 5, 2026
Help with odd QHY268M images
Image-APPM-2025-10-16-212413.txt-0341-RA_0.064-DEC_25.000.fit Getting these types of images during a mapping run for my FSQ-85 on an AP1600GTO AEL. This is causing many plate solve errors and run results that are unusable. Any suggestions would be ap...
Optical artifacts like spider veins reflections could cause plate solve errors.
Oct 17, 2025
Dark bands at top and bottom of Minicam8M
EDIT: QHY support responded with the following statement: “We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obs...
Dark bands in sensor frames may indicate similar optical obstruction or light issues.
Nov 8, 2025
