Harmonic Mounts and Belt Replacement (Ioptron HAE29C)
14 replies197 views
Rajat Kumar avatar
To cut a long story short:
Recently, the RA Axis of my Ioptron HAE29C (both axis Harmonic gears) mount stopped responding. After some email exchanges with Ioptron, I decided to open the front panel of the mount. The belt on the RA Axis was broken. Now I have two options: one is to send the mount to Ioptron in the US for repair - expensive, issues of customs,
The second option is to fix it myself. Ioptron has sent me a manual to adjust the backlash of the belt, but there are no specific instructions regarding changing the RA belt. I wanted to ask if someone has undertaken this sort of endeavour on their respective harmonic mounts? The process seems to be to take out both RA and DEC motors and reach the innermost layer of the mount to install the belt, put back the motor + reattach the sockets to the PC board and tighten the belts
The mount otherwise is under warranty, and Ioptron has agreed to send me the belts to perform the replacement. I am speaking to them, but I wanted to know if there is anyone who has undergone a similar issue, not just with the Ioptron mount but in general with the harmonic gear mount.
Video showing broken belt - RA Axis broken belt.mp4
Apparently there is a lot more torque there than those belts can take (another good reason to avoid them). As for replacing the belts themselves, just keep the RA tight but not too tight, let's say a couple of millimeters either way and you are good. Backlash is a non-issue for the RA axis.
Rajat Kumar avatar
andrea tasselli · Sep 15, 2025, 11:22 AM
Avoid the mount or the belts the company provides?
Avoid the mount but since you already have one check what belts you've got and how they compare to the best in class.
Ashraf AbuSara avatar
First time hearing of this issue on belt driven SWG mounts. Assuming the mounts are loaded below maximum capacity and no catastrophic collisions occurred, this is not something these mounts are “known for”, certainly not a “reason to avoid them”. I have two HAE69s that have been operating remotely with more than a 1000 hours of integration on both of them for a year now.
Not saying what happened to the OP is not possible with normal use, but certainly any piece of equipment can break down.
Rajat Kumar avatar
Ah, surely! The belts are being shipped today by Ioptron, but I will check the model and see if I can get better ones. Thanks for underlining that.
Rajat Kumar avatar
Ashraf AbuSara · Sep 15, 2025, 12:17 PM
Yes, I agree.. I have been using it normally. For the last 11 months or so I have been using it with 70mm refractor+OSC set up and it worked fine. Recently, I changed my scope to GSO RC6 Carbon Fibre with OSC Camera. The gear slippage issue happened when I was trying to collimate my scope, and I did not even have any guiding equipment on the scope. Even Ioptron support said that they don’t know what could be the reason for the belt. I would have sent it to the US for repair but it is expensive, and more importantly, a time-consuming process. As of now, the company is trying to help as much as possible. They will provide some technical help.. lets see how that goes.
I just want to give some encouragement here. Take the mount apart step by step and take pictures as you go. Put all the screws in a tray or cups and label to keep track. I think you’ll find it easier than you expect.
Well Written Concise Supportive
Rajat Kumar avatar
Thank you, Tony! As of now, that is the plan. To systematically dismantle the scope and fix the issue. The jitters come from the fact that there is no precedent for this on the internet. :D
Isn’t it great to be a pioneer? 🙄
Since you’ll be taking pictures all the way you could always post that somewhere as a guide to anyone else who might have a similar issue.
Rajat Kumar avatar
That’s a good idea. I will try to document the process in some manner and share it here.
SkyHoinar avatar
I didn't know harmonic drive mounts have belts. It is good to know!
I have a HEM27 with harmonic only on the RA. I opted for it because it is very convenient for air travel as it doesn't need conterweights. I really like it and it works fine and I hope it will be OK still for some time, but I have to admit that now I am starting to have some worries.
Thank you for sharing your experience! I hope you will solve your problem as soon as possible! Good luck!
Respectful Supportive
Rajat Kumar avatar
SkyHoinar · Sep 15, 2025, 05:49 PM
Hey, I can’t say that “all” harmonic mounts have belt, but at least AM5/3 - the most popular option - has belts on both axes. The difference between HEM27 and HAE29 is that the latter has SWG on both axes. I don’t think there is anything to be worried about. Mechanical errors can appear anytime in any machine.
SkyHoinar avatar
How is the HAE29 in terms of tracking/guiding and also polar alignment (does it still have the iPolar)?
I was considering buying a second mount and I was thinking to this one because of its SWG on both axes, but I am not sure if that makes any difference (compared to the HEM27). Some feedback from owners would be welcome.
Rajat Kumar avatar
SkyHoinar · Sep 15, 2025, 07:51 PM
I have been quite happy with it so far. Have no complaints except the polar alignment mechanism (this is my second Ioptron mount and it's the same story). The knobs which are there for RA axis adjustment are small. Apart from that there is no complaint as such. Having said that I have always managed to get PA below 1” without much issue. I can't say if it makes any difference in guiding but one doesn't need to balance the DEC axis in HAE. That's a plus for me - allows for quick set up. But that's just a minor issue, if your guiding on hem has been fine.
DIY Strain Wave Mount
After making my first star tracker, I immediately started to wonder about making a goto mount. The tracker took me a year and a half with several drivetrain configurations and lots of lessons learned. This Big Ballhead GoTo Mount took less than half ...
DIY Strain Wave Mount — Author considering self-repair; DIY mount construction highly relevant.
Feb 23, 2026
CEM25EC Woes
It’s been kept away for a while in its case, indoors so not anywhere cold or potential with damp. I decided to try and use on a 2nd setup. In the past, it’s been fine and I used on many outreach sessions. Problem now is that even though it starts up,...
Mount axis stopped responding; relevant diagnostic and repair experience shared.
Sep 19, 2025
CQ350 Tracking Issues
Have recently bought a CQ350 mount for use with my GSO RC12 and I having an issue with the mount. I wonder if anyone out there can help with advice and/or experience. This is the 1) When the RA drive clutch [not the best design in the world] is locke...
Not relevant - Harmonic drive mount; different mechanical system than worm gear CQ350.
Mar 8, 2024
Skywatcher experience needed - seeking user feedback and recommendations
Hello, Has anybody experience with the skywatcher Wave150i ? My wave 150i worked very good until I made some changes in the cable management. In order to have less USB cable between the telescope/mount and the PC, I installed on the telescope platfor...
Mount axis failure troubleshooting similar to author's RA/Dec axis problems.
Oct 9, 2025
Similar axis malfunction troubleshooting on different harmonic gear mount model.
Jan 18, 2026
