astrojuanan avatar
Good morning, my equipment is an askar Fra500 and with the 130phq it also happens to me, zwo2600mm camera and antlia filters, the problem is what happens to my images, especially olll, in the lower left part I get the feeling that I lose all the signal, could someone help me? The images are from b5 but from b2-3 in trvinca the same thing happens to me.
It's mostly the bottom left corner. My gallery is a clear example of what's happening to me. Thanks.
📷 Filter_Ha_registered_ABE.jpgFilter_Ha_registered_ABE.jpg📷 Filter_Oiii_registered_ABE.jpgFilter_Oiii_registered_ABE.jpg📷 Filter_Sii_registered_ABE.jpgFilter_Sii_registered_ABE.jpg
Robert Žibreg avatar
Could you post raw masters please.
Tobiasz avatar
Looks like a stray light issue. Did you check the setup for light leaks?
Did you rule out reflections from your filter rings? There are many reasons something like that happens.
Touptek filter wheels may suffer from IR light leaks because of a faulty firmware version, I don’t know about ZWO though.
Concise
astrojuanan avatar
I don't have to upload them, I upload them to drive
astrojuanan avatar
Robert Žibreg · Sep 14, 2025, 09:41 AM
https://drive.google.com/drive/folders/1x232vFBFds1jabkGcEXQQexXqVu?usp=sharing
I don't have to upload them here, I'll upload them to Drive.
Tobiasz avatar
I don’t see this gradient in your OIII master, even after one round of GraXpert it looks fine to me.
astrojuanan avatar
Tobiasz · Sep 14, 2025, 09:48 AM
lo revise si pero extraño que me pàsa en el observatorio de trevinca que es fijo y en casa con otro equipo
astrojuanan avatar
Tobiasz · Sep 14, 2025, 09:57 AM
pues debe de ser cosa de mi edicion creo, no lo entiendo
Tobiasz avatar
astrojuanan · Sep 14, 2025, 09:57 AM
After seeing your masters I dont think it is an equipment issue.
astrojuanan avatar
Tobiasz · Sep 14, 2025, 09:59 AM
After seeing your master’s I dont think it is an equipment issue.
Mil gracias, prestare atencion a ver que puede ser
Tobiasz avatar
astrojuanan · Sep 14, 2025, 09:59 AM
What is your processing workflow?
astrojuanan avatar
Tobiasz · Sep 14, 2025, 10:00 AM
para sacar el gradiente uso gradientcorrection tal cual esta📷 Captura de pantalla 2025-09-14 a las 12.04.08.pngCaptura de pantalla 2025-09-14 a las 12.04.08.png
Tobiasz avatar
astrojuanan · Sep 14, 2025, 10:04 AM
Sorry, I don’t have much experience with GradientCorrection. Maybe someone else can help on that. I use GraXpert only.
astrojuanan avatar
Tobiasz · Sep 14, 2025, 10:10 AM
mil gracias de verdad
astrojuanan avatar
sabes el scrip de graXpert?
Tobiasz avatar
astrojuanan · Sep 14, 2025, 10:29 AM
You can find everything regarding GraXpert here.
astrojuanan · Sep 14, 2025, 09:52 AM
Masters are fine, it’s your workflow. Probably gradient correction
astrojuanan avatar
Yes,
astrojuanan avatar
Robert Žibreg · Sep 15, 2025 at 06:24 AM
astrojuanan avatar
Yes, you're right, the problem is solved, thank you so much.
Fast optics with regular speed filters?
Hi, What will happen if using not a highspeed designed filter with fast speed optics such as f/2 or f/1.8, f/2.8? What could be the problem if doing that?
Discusses filter performance problems with specific equipment configurations.
Feb 22, 2026
Help - Vertical bands - Flats is the culprit - Can someone help me understand what's happening ?
Hi, Recently I am noticing some weird band like structures in my images. My setup - QHY600PH-M + Takahashi Epsilon 180ED + Astronomik Filters. I Captured RGB images in QHY 2CMS-1 Readout mode at 56 gain for broadband images. (mistake) After noticing ...
Vertical bands issue similar to your corner signal loss problem; flats troubleshooting relevant.
Nov 23, 2025
