what kind of trail is this?
9 replies187 views
adrian-HG avatar
What could cause this type of stellar trail? It looks a bit different from satellites and airplanes.
this is a raw 180 seconds OIII light taken 28-08-3035
Jure Menart avatar
Looks like meteor trail to me :)
adrian-HG avatar
thanks for the answer ! , i never seen this bfore in my lights
Or a rotating satellite. More likely.
Die Launische Diva avatar
I also believe it is a spinning satellite. If your telescope had a wider field of view, you could possibly see another instance of it along the imaginary line extending from the trail.
Well written
Jure Menart avatar
Yes, you two are right - you can see the dimm trail through the image.
I didn’t look careful enough at the beginning.
Bill McLaughlin avatar
Agreed.
On that topic, I have always wished that someone would come out with an AI tool to remove satellite trails from sub frames. If you have enough frames standard rejection removes them well most of the time but for fewer frames it often leaves a remnant. If they were removed from the subs, even if it was not done all that perfectly, that will get rid of them totally by the time rejection is done. I have done this manually with the clone tool on occasion and it works very well but is tedious. I would think this would be a task at which AI would do well
One thing is for sure and that is this issue is only going to get worse.
Bill McLaughlin · Sep 12, 2025, 02:17 PM
Does Satellite Trail Removal from Seti Astro (https://www.setiastro.com/cosmic-clarity) work for you? I haven’t tried it myself 🙂
Well written Engaging
It doesn't work well, I'm afraid, at least in the final composite. Might work if just removing the traces on some subframes.
Bob Lockwood avatar
To the OP, am I seeing the date correctly, 28th of August 3035.
This is an example of both, left center is a meteor (shooting star), bottom center is a spinning satellite.
I intentionally left both in this image I did back in 2018. Both were in single sub frames.
Review of the QHY5III678M for ground-based satellite imaging
This is a review that shows the performance of the QHY5III678M planetary camera for ground-based imaging of satellites, I will showcase the specifications of the camera and example images I have taken with it of several satellites. I also want to kin...
Camera specifications may help identify equipment limitations causing unusual trail patterns.
Jan 12, 2026
