Spotty Background Help (Light Pollution)
8 replies148 views
Iris avatar
Hello! I was hoping I could get some help with my pictures. In pretty much all of them, I have this really spotty background which I assume is from light pollution. I’d rather not cut off the black and make the image 100% dark. How can I fix this?
Thank you!
This is what I mean, by the way, if you zoom in on the background.
📷 The Eastern 'Face' NebulaThe Eastern 'Face' Nebula
https://app.astrobin.com/i/up4mto/
The background is "spotty" because it is noisy and it is noisy because both the RON is high and because of the background brightness being rather high I suppose.  But being a Seestar I'd be happy with this result.
Iris avatar
andrea tasselli · Sep 11, 2025, 10:24 AM
duly noted, thank you! so what I’m doing is probably good?
Gerassimos Arsenis avatar
This area has a lot of hydrogen-some of which isn’t bright enough to show up especially with the Seastar or shooting through light pollution. I think this can also be mistaken as noise or patchy spots. See if you get similar results in other areas of the sky.
Jure Menart avatar
To me it looks like it could be walking noise. Did you calibrate the images (dark, bias, …)?
Yeah, albeit a bit lacking in terms of color brightness. The Ha areas should really be of a bright red and the OIII should be more like teal. Your colors area a bit lacking, both in the nebula and in the stars.
bigCatAstro avatar
I think this a good outcome using a Seestar. It’s more than likely blotchy due to a combination of signal noise, added noise reduction, and probably a low integration time. Noise reduction artifacts can show up like this if they’re applied too strongly.
I don’t see any exposure information but I would guess that more time on the object would help, maybe a multi-night session is needed. Lack of integration time is usually the reason for splotchy or wormy backgrounds.
Well Written Concise
Iris avatar
Tony Gondola · Sep 11, 2025, 04:35 PM
Ahh duly noted, thank you! The shoot was only around 1.5 hours, 10 second images. I’ll see if in future shoots where the object is dim I can go longer :)
Light Pollution--With Awareness There's Hope
https://www.space.com/light-pollution-loss-dark-skies-noctalgia
Light pollution causes spotty backgrounds in astrophotography images; relevant to source discussion.
Sep 19, 2023
