BIOS Settings for Remote Imaging
17 replies272 views
Jerry Gerber avatar
My new Windows 11 PC's BIOS does not have a setting called 'Wake on AC'. This setting allows the computer to boot remotely from a state of being off when it receives power from the WPS.
There is however a setting called State 0, which seems to accomplish the same thing, but, if I understand correctly, it keeps the computer in a semi-on state even when off.
Is there any downside to using State 0?
Thanks,
Jerry
Well written Engaging
Jerry Gerber avatar
Surely you would have checked that before you bought it, not all PC’s have the wake on AC option.
Obviously I didn't.
It wouldn't be in the specs, even the most detailed specs.
Bill McLaughlin avatar
That is why I build my own since I can check the Mobo and bios before the build. Building gives you tons of options that buying does not.
Tim Ray avatar
Hi Jerry,
What NUC did you purchase? or Mini PC???
Thanks Tim
Ferrante Enriques avatar
state 0 usually means the fully operational mode of a PC, while state 1 to 5 are decreasing power consumption states (sleep, hibernate, off).
It seems your setting would work if it says “state 0 on AC’'.
For booting a PC from remote also wake on lan comes handy if you have this setting in your BIOS
ferrante
Brian Puhl avatar
You want something called “restore power on AC loss”.
S0 is a power on state and will do nothing once power is removed.
Frédéric Tapissier avatar
try Firmware update ;)
Jerry Gerber avatar
Problem solved.
STATE S0 powers on the PC when AC power is applied.
I tested it several times and it works.
I also have Wake on LAN enabled.
The company that makes the computer says that the BIOS contains 'Power On AC' but I've not found it yet.
Jerry Gerber avatar
Hi Jerry,
Thanks Ti
Geekom IT12 (i7-1280P CPU)
Jerry Gerber avatar
Brian Puhl:
S0 works.
Jerry Gerber avatar
Jerry Gerber · Sep 8, 2025 at 11:54 PM
AstroStew:
Obviously I didn't.
It is in the specs on the Mele PC I use, even the basic specs show it as a feature
I did not purchase a Mele. I'm replacing the Mele I have with a Geekom IT12.
Specifics on the BIOS functionality are available, but I had to dig around on the website for them.
John Hayes avatar
Jerry,
You have found the same thing that I’ve found. The “Power On after Reboot” option in many BIOS incarnations can be very difficult to find. It took me a lot of time and searching before I figured it out on my Minisforum PC and I’ve pretty much forgotten where it was. In my view, it wasn’t in a very logical place and it was labeled as something rather confusing. In my experience, virtually all PCs have this feature but it can be buried so deep in the BIOS that it’s a frustrating experience trying to figure it out.
Well written
Jerry Gerber avatar
John Hayes:
Jerry,
Yeah , it's strange. I've been configuring settings in the BIOS for decades but they keep renaming things!
I'm still searching for Power On AC but I think the setting is now called State 0, at least in this particular BIOS. In any event when I turn on the power strip it powers up.
I think it's ready to be sent to HCRO.
Benny Colyn avatar
Heya,
What I haven’t seen mentioned: if this machine is fully remote (as apposed to a backyard observatory or something) I would highly recommend investing in something like a PiKVM or JetKVM. These have extensions for either tapping into ATX power management (desktop power button) or DC power switching (for mini PCs). This way you can remotely reinstall the operating system if needed, change firmware settings or even update the firmware from the other side of the planet. Traditionally this is enterprise-grade hardware (out-of-band-management) but the aforementioned options are open source and affordable (well as affordable as anything in this hobby). It is an absolute lifesaver if a software update hoses the OS, or a piece of malware forces a reinstall, you need to run memtest86 (when you suspect RAM has gone bad) or the thing just needs a good old power cycle. I cannot recommend it enough.
As for changes in BIOS options: Power management on PC hardware is going trough some changes, with the traditional S-states getting removed and the “connected standby” (where all power management is done through the OS) is getting pushed as the new way of working. This brings changes in the UEFI (“BIOS”, except it hasn’t been a proper BIOS in years anymore), not always welcome for our use cases but it is what it is.
Setting up remote computer so that it can boot up when making remote connection (without having to turn off/on Web power switch)
Hi! I currently have a Windows 11 machine at my remote site. When I turn off Windows on my remote machine, the only way to boot it back up is to turn off the web power switch, wait a few minutes, turn it back on and wait a few minutes and then connec...
BIOS Settings for Remote Imaging — addresses Wake on AC for remote boot capability.
Apr 3, 2025
New mini PC won't boot after remote imaging session
I got the new mini PC set up remotely and it’s blazingly fast, faster than I even expected. All went well on the first night of imaging with it. But this morning when I downloaded my data, I shut the computer off and it kept trying to reconnect. I as...
BIOS settings may help resolve remote reconnection and shutdown issues.
Sep 17, 2025
Remote Connection Software
I've been using Windows Desktop Connection (comes with Windows) to connect my Win11 mini-PC to my Win10 desktop at home. I'm losing connection multiple times a night. I have tried changing some recommended settings in my Windows remote PC gro...
BIOS settings may help stabilize remote connection issues on Windows 11 mini-PC.
Sep 1, 2024
Rebooting Remote MINI PC
When I need to re-boot my remote PC I shut it down, but I can't just wait a minute or so and then reboot it. Instead I have to wait till the computer is off, turn off the power at the Digital Loggers Web Power Switch web page, turn off the power,...
BIOS settings may enable remote boot without physical power cycling.
May 18, 2025
