Mini PC specs recommendations?
5 replies95 views
Tareq Abdulla avatar
I ordered another mini-PC but this time it is from MeLe models, and i want to know how much RAM and drive storage you really need if you use it into astrophotography.
I think i will be using it for anything, be it DSO or planetary or solar, for DSO i know what storage is enough, but for planetary or solar for one session before i transfer the files if i remember to transfer, how much i should get?
And for RAM, is 16GB really more than enough if i won’t use it for any processing? Is there any program during acquisition that will require maybe more than 16GB or even up to 16GB? I already bought a 32GB version, but if i buy again next time i might just go with 16GB or even 8GB if it is not demanding.
bigCatAstro avatar
Tareq Abdulla · Sep 8, 2025 at 06:02 PM
For my set-up, I’ve been using a MeLE 3Q with the N5105 processor, 8gb RAM, and 256gb SSD. It has been reliable and has worked effectively for me using NINA. I don’t store subs on the MeLE, those are being stored on a 256gb SSD flash drive and then Remote Copied to my processing computer. The RAW image files never approach the capacity of the SSD flash drive when I elect to not use remote copy.
Although it has worked very well for me, I think the16gb RAM version would have been a better option.
Since I don’t do planetary imaging, can’t say whether or not this set-up would be ideal for your needs.
bigCatAstro · Sep 8, 2025, 06:45 PM
I used my first mini PC which is from Beelink for astro for short time, it was good enough, but i can really tell that when i used it for solar it was like i get it almost half empty for one session that isn’t even long enough, i was using 512GB drive and i can fill this easily if i might do full night of planetary or two, and transferring that much data will take time if i am not using fast connection.
Anyway, in fact what i want to say is that i can afford an SSD with 256GB or 512GB or 1TB or even 2TB, not a big deal, but just i don’t want to go that too much spending for no point, i mean if i won’t fill that 1Tb or 2TB at all because i will keep transferring then it is no point to get them, and i don’t know what future proof it can make, i just want to see people approaches, some will say they never exceed 256Gb and some others will say that even 2Tb isn’t enough.
bigCatAstro avatar
Tareq Abdulla · Sep 8, 2025 at 07:42 PM
Ah, I see. Sounds like you are more of a Planetary and Solar imager. I think you’re on the right track in terms of going with larger capacity SSD.
Maybe get a 2Tb SSD for your overall needs since you’re lucky imaging? You’ll probably have enough headroom for your storage.
bigCatAstro · Sep 8, 2025, 08:24 PM
I do planetary more and since like 2 years ago i added solar because DSO is a big complicated and a headache, i am still collecting so many gear for DSO and i am not in rush, most likely i will buy another MeLe for DSO only, but that is why i asked here to see if any Solar System imagers using mini PCs with whatever specs they went with, 2TB is a big safe choice but not most important or a must, 1TB i am at the edge of filling that if i do big activity of imaging in short time, less than 1TB and i will always be at mercy of full drive space and either i need to empty it by sacrifice data or just stop imaging, so for me 1TB is the minimum choice, but will 2TB be too much or just a backup extra storage when needed.
Ok, the updates so far:
  1. I bought two MeLe PCs, Overclock 4C and Quieter 4C
  2. I bought Samsung 990 Pro 2TB for Overclock [solar system] and i already have Samsung 990 Pro 1TB will be used with Quieter [DSO], Overclock version is 32GB RAM while Quieter is 16GB
I don’t know what i can do with Overclock eMMC drive once i install 2TB SSD, do you know any use for it? Someone recommended me to close that SSD after i am done into eMMC so i have a backup, and my idea is to install Linux or RPi OS such as StellarMate, what about your opinion or suggestion?
I only tested Overclock 4C for like 10 minutes just as idle, the heat is unbearable, i am worried if i will use it outdoor with pressure it might heat up to bad levels, although it is with fan, and i am not interested in looking at hundreds of people’s idea to cool it and lost into decision, but definitely i want best solution for heat, specially if i want to mount it with the setup which is another concern i need to find out.
Minimum/recommended spec of laptop for capturing data
Hi, I'm planning on getting the asi585mc camera for imaging planets and I'm aware that I need fast fps which needs a fast capture. I'm a total newbie on this and opinions vary elsewhere on the Internet. Can I get away with i5, 8gB Ram, an...
Mini PC specs directly address your hardware requirements for planetary imaging capture.
Nov 20, 2024
Minimum gpu?
Hi, Based on your experiences, what spec of gpu is the minimum needed to use this software to the extent you require? Thanks Mark
Discusses hardware specs and RAM/storage requirements relevant to software performance needs.
Oct 6, 2024
Drivers Question
Hi, I am new to the QHY cameras. Currently using a QHY600 with Mele 2q mini PC. I installed the all in one drivers which seems to work. But after every session, I turn off my PC. When I start next session, the device is no longer recognized and I hav...
Mini PC specifications and setup for astrophotography, directly relevant to your hardware.
Oct 13, 2025
New to or Considering Astrophotography/astronomy?
I had posted this with a new image I’d uploaded as a change from the “typical” review of my processing steps/acquisition. A friend/commentor suggested I post in a forum, so this is the result. This is VERY subjective and based entirely on my experien...
Relevant for astrophotography beginners; addresses equipment and setup considerations.
Jul 31, 2025
