QHYCCD Minicam8 Mono SPCC Filter Setup
5 replies158 views
Jim Raskett avatar
Hi Everyone,
I know that Minicam8 mono users here are using some sort of color calibration in PI.
I have been comfortably shooting OSC for years. I am new to mono and was hoping that I might get some help from some folks using this camera with setting up SPCC.
I received some help from a user on the CN forum and have set up SPCC for broadband like this:
I am trying his QE curve using the his sensor data and QHY graphs and use the Sony Color Sensor/UVIR Cut filters because they are very close to the QHY filter curves.
Not sure how to setup the narrowband (Ha, OIII, and SII) either.
I did get out and image M39 for a few hours with the RGB filters. I have decent results using the settings in the image above, but not quite sure if the color balance is right  (still making adjustments). I would just like to see other Minicam8 users setups to help me.
I someone would be kind enough to at least reply with images of their SPCC setup or some pointers, I would be very grateful!
Hopefully, I can figure out how to set things up from there.
Many thanks!
Respectful
Mikołaj Wadowski avatar
Not a Minicam8 user but I believe I can help regardless.
Sony Color Sensor filter curves in SPCC contain the QE of Sony color cameras. So you should set the filters to something else, otherwise you’re effectively applying two QE curves. If I’m thinking about the same QHY filters as you, it looks like Baader RGB filters match them pretty well.
Narrowband is very easy to set up, just check the narrowband filters mode box and the rest is pretty self-explanatory. SPCC is fairly useless for narrowband-only though, as Ha will always be way brighter than the other two emission bands. For that I recommend you use manual ColorCalibration instead, as it has the tools necessary to get roughly equal intensities for each channel.
Jim Raskett avatar
Mikołaj Wadowski:
Hi Mikolaj and thank you very much for the explanation!
I compared the Baader RGB filter curves to the XiMei RGB filter curves and yes, they are pretty much a perfect match. Excellent! That works for me and I have already setup a PI process icon.
I did look at the narrowband settings for SPCC and yes, they are pretty basic and self-explanatory.
Funny that you mentioned that ColorCalibration was better for narrowband because of channel intensities. I am in the process of watching a video by Bray Falls on YouTube "A Beginners Guide to Editing Narrowband Images" where he explains exactly that and just as you said.
I can't thank you enough for the great explanation and taking the time to compare filter curves! Actually quite a bit simpler that I thought and I really appreciate you setting me on the right path!
Thanks a bunch Mikolaj!
Respectful Supportive
Jim Raskett avatar
Much, much better correlations in SPCC with the Baader filter curves. With the Sony curves, both had a significant non-linear tail. thanks again!
Emphases7392 avatar
Jim Raskett · Sep 8, 2025 at 07:18 PM
It may have been me who you talked with in CN (Whendewsday). Glad to see these results are better, and I’m updating my own workflow to use the Baader as well.
Jim Raskett avatar
Hi Emphases7392,
Yes, it was you that helped me out on CN.
Again, I really appreciate that help. You gave me a good starting point and got the thinking.
I posted an update to the CN thread.
The Baader curves seem to work well on an open cluster. Decent star color with only some saturation.
Looking forward to shooting some narrowband, but waiting a bit for the moon to wane some.
I really like the success that you had with your Pacman image!
QHY Minicam8 blue halo
Hello to all Minicam8 users. I experience a substantial halo when I use the blue filter, that result in a blue halo around the brightest stars. Anyone else have this issue? Do you have any suggestion on how to deal with it in post processing? Olivier
QHYCCD Minicam8 Mono SPCC Filter Setup — same camera model, filter-related discussion.
Feb 20, 2026
Minicam8 OAG
I thought minicam8 owners would like to know, the OAG will be available on preorder soon. https://www.instagram.com/p/DK1RImSOR2U/
Minicam8 mono users discussing color calibration and imaging techniques.
Jun 17, 2025
Using SPCC in Pixinsight with QHYCCD MiniCAM8M Deep Sky Combo mono camera
🌌 A way to use SPCC in Pixinsight with QHYCCD MiniCAM8M (Mono) Deep Sky Combo I cannot find either the sensor or the filters of QHYCCD MiniCAM8M Deep Sky Combo, so I tried to solve it. Finally, I did. You can follow this link to do it ~ 🌹 https://git...
Directly addresses SPCC color calibration setup for same camera model.
Jan 25, 2026
One Click, Real Science
Early last summer, while I was working on a new image, it occurred to me that the SpectrophotometricColorCalibration tool in PixInsight was generating all of the information that is needed to plot star data from a globular cluster as a Hertzsprung-Ru...
Discusses SpectrophotometricColorCalibration tool in PixInsight, directly relevant to SPCC setup.
Oct 13, 2025
UV/IR Cut vs Luminance
I’m sure this is discussed at lengths here and in the internet but still I failed to find an answer. So are the 2 doing the same thing ? Are they interchangeable? I own 2 mono camera, Touptek ATR585M with a 8 position filter wheel that have LRGBSHO f...
Author owns Minicam8 mono camera; discusses color calibration setup relevant to their gear.
Feb 28, 2026
