Another weird cdk star halo issue!
15 replies228 views
Anthony Grillo avatar
I just recently got my brand-new scope back from planewave after a couple months, they had to refigure both mirrors entirely unfortunately!!
While everything seems to be working tons better than it was before I’m still getting some weird star halos. Mind you now, I still think I need to tweak collimation a tad but I’m not so sure that is the issue here.
The halos of brighter stars seem to skew toward the left/bottom left of my images and is the case with most bright stars across the frame. Anyone have any idea as to what could cause this??
Not sure about a CDK but in other compound systems with spherical or quasi-spherical surfaces I'd suspect a lateral shit of the secondary relative to the primary.
Try shooting without a filter (if you have one in the optical path).
If the filter is causing it, the further off axis you are the more offset the halo will be.
Well written Insightful Concise
Chris White- Overcast Observatory · Sep 5, 2025 at 01:21 PM
andrea tasselli · Sep 5, 2025 at 07:59 AM
Going through my images I just recently took , it looks like this only happened with my red and blue filters and the skew was at different angles between them both?? The blue is the one in the image I posted here where it faces bottom left and the red had it top left.
On my LUM and other filters it doesn’t show up at all.
Starting to think it may be a reflection?? All my data from my WR134 integration seemed fine it was only the latter half of my 7217 data where the moon was low on the horizon where it showed up…I think??
Better post a full field image but I don't think this being a reflection issue.
andrea tasselli · Sep 5, 2025, 02:15 PM
here are a couple frames from my blue filter on 2 different images one is a complete stack the other two are single.
I even noticed this on my red frames with this most recent project where when I finally combined my RGB I got weird star halos that showed different flares of red and blue in different directions.
After looking over multiple nights, I think this is temp related still. I had this issue before the scope had to be sent back because of other issues that they eventually had to redo both mirrors to fix.
Look how different the halos look between different nights.📷 stack.pngstack.png
here is a crop of 2 images a couple nights apart on different targets, same filter📷 bluecrop1.pngbluecrop1.png📷 blue2.pngblue2.png
maybe I should see what happens if I run my fans at 75% vs 100% and check the aperture ring is bulging enough to let air pass more because this looks like boundary layer issues if I’m not mistaken from my earlier troubleshooting
If the direction of the flare is in the vertical direction then yes, this could be an issue with thermal plume. But if the different filters were used across the night then why you wouldn't see on some and you would on others?
andrea tasselli · Sep 6, 2025, 11:39 PM
yea, it isn’t on my lum filter frames at all!! really confusing, I thought maybe tilt also, after running some image analysis it seems I have some minor tilt
Anthony Grillo · Sep 5, 2025 at 12:38 AM
We run the fans on our CDK20 only when not imaging, and at 100% during those times. During imaging we shut them off, as we see issues like this if we have the fans running during imaging.
This is something we are working on a design to solve, as not running the fans at all during imaging is not ideal, however it does improve star quality over what we get when they are on at all.
Dark Matters Astrophotography · Sep 7, 2025, 01:01 AM
Thank you!! I will for sure shut them off after cooling down when I image tomorrow, honestly that’s the only thing I can think of that will cause weird halos that change shape from night to night.
By the way, love your work! your images are some of my favorites!
Respectful Supportive
Anthony Grillo · Sep 7, 2025 at 01:20 AM
Thank you!
Feel free to hit me up in email or DM here once you get some tests done with the fans off.
Well written
Dark Matters Astrophotography · Sep 7, 2025, 01:29 AM
Thank you!
I got a bunch of clear nights up ahead so I should be able to test tomorrow!! I am going to tweak collimation too because it seems I may be slightly off
Anthony Grillo · Sep 7, 2025 at 03:48 AM
Thank you!
Highly suggest using Gaston’s SkyWave software. We use this on all of our scopes and it is great!
Dark Matters Astrophotography · Sep 7, 2025 at 04:10 AM
Thank you!
I have sky wave from a few years ago for my ago idk and I was going to try it with the idk model and see how it did so I didn’t have to purchase another model so crossing my fingers it works
Perplexing Issues with CDK14
Hi all, I've encountered two perplexing issues with my PlaneWave CDK14, that I would love some input on. I am chatting with Bill Dean over at PW on this, and while we both try to get to the bottom of it, I would love thoughts from people on this ...
Author has CDK14 issues; similar scope problems with mirror defects reported.
Apr 15, 2024
A single bright star with a distorted halo in an image of M44
This is an image of M44 taken with my new Astro-Tech AT60EDP, an ASI294MC Pro and and L-Pro filter. The data is 2 hours of lights, plus darks, biases and flats. The image was processed in Pixinsight GraXpert SPCC BlurXterminator NoiseXterminator Mask...
Star halo distortion issue with different scope model; similar troubleshooting approach.
Mar 5, 2024
Unusual star spikes/flares on 10" RC
Hello, I am currently shooting with my 10 inch RC and like it very much. After some nights I wanted to check my results and stacked my images. What did come out was nice, but the stars showed some weird additional spikes and flaring. Do you know what...
RC mirror issues similar to yours; discusses collimation and mirror problems.
Sep 28, 2024
Star shape error
Star halos are prolonged backward. What is causing this, and how to fix it.
CDK star halo issue; directly discusses similar halo problem.
May 28, 2025
Mirror shaped Halo in images
My mate Richard has a New Takahashi E180 ED and is having a few issues intermittently when imaging. I was wondering if any other users of the telescope have experienced any similar problems and know the cause or fix. Looking at it I tend to think it ...
Fast scope mirror issues similar to internal reflection problems discussed.
Apr 3, 2025
