Advice with problem on bright stars
7 replies223 views
Joe Kent avatar
Hello,
Can anyone give me some idea of what is causing these issues on my bright stars.
I know the image below is not perfect but the smaller stars are acceptable but I seem to get a half halo on the brighter stars...
Any help or suggestions would be greatly appreciated.
I am using a Skywatcher 130PDS.  Could it be the alignment of the secondary mirror?
Thanks,
Joe
urban.astronomer avatar
Joe,
I am not familiar with Newtonian scopes, but it looks to me as this might be an issue related to a tilt of the sensor.
https://aiastro.wordpress.com/2019/01/24/sensor-tilt-adjustment/
-Martin
Stjepan Prugovečki avatar
Collimation ?
James Malone avatar
I've also been investigating this issue on my RASA 8 too.
1 possible cause is decentered secondary, the 2nd is bright off-axis reflection (e.g. mirror holders). Shot one bright star centered in the sensor so that the fresnel pattern can be easily seen and we may rule out options.
Jeffrey Geiss avatar
Also try shooting the bright star in all four quadrants of your sensor. If possible, try to recreate the error with an artificial star. Try to discern what orientation your sensor is to the optics. Rotate camera, does the error follow the camera or stay with the optics. Look at the optical path for anything that could cause reflection. Bare unflocked metal, a screw protruding, we even had an inch or two of a glossy glue used to fastened felt flocking in a dew shield cause a horrible bright star reflection. Is there anything in the optical path above the telescope, sorry I know seems obvious but a power wire on a pole or similar can distrubt light. After all that look carefully at any corrector lens filters or oag in optical train.
most important is seeing if the error follows a rotation of the camera and any device attached to it then yiu can start to narrow the problem.
James Malone avatar
Jeffrey Geiss:
This is good advice. Many of these things are on my list, whenever Seattle finally has a clear night.
Ya I hear ya. South Carolina can be a sky swamp. Thats were the artifical star can help. If you have access to a long dark hallway, a long basement, someplace dark but long enough to allow system to come to focus. Mirrors can be used to extend that distance. There are Art Stars avail but you can make one. Ours using a piece of fiber optic cable, can buy a short one for a few bucks. Hot glue one end to a bright led. We use cheap PWM controllers to modulate brightness. This may allow you trouble shoot during day without wasting good clear dark skies fixing optical issues. Also goo to test back focus when adding new gear.
Supportive
Something's wrong with my Edge HD 8
EDIT: I THINK I'VE GOT IT NOW. If your images look like the ones at the bottom of this post, you may need more than simple Collimation (You've probably got the secondary mirror so far out that Collimation won't work. This can happen from ...
Edge HD collimation issues similar to Newtonian mirror alignment problems.
Sep 20, 2023
Collimation Problems
Hello guys. I just acquired a Sky-Watcher 150/750 PDS Newtonian and I am new to the whole Newtonian thing, I watched videos and read articles about how to collimate and I follow through all the techniques (Cheshire eyepiece, collimation cap, laser co...
Collimation problems directly relevant to Skywatcher PDS Newtonian telescope.
Sep 21, 2023
Flat files showing "central obstruction" of Skywatcher 130PDS
I have a Skywatcher 130 PDS, and for imaging I have a TS GPU coma corrector, 5 position filter wheel and ASI533MM. For my flats I use a fairly thick white opaque acrylic plate and this has been working well - it calibrates out dust and vignetting. Bu...
Same telescope model experiencing optical issues requiring troubleshooting.
Nov 12, 2023
Getting rid of divergent spikes with a defocused star
Hi Folks, I would like to share a little tutorial with you about the alignment of the secondary mirror vanes. The goal is to create nice and narrow diffraction spikes without splitting towards the ends. This applies to all Newtonians with adjustable ...
Secondary mirror alignment affects star appearance and halo formation.
Aug 19, 2023
