So how bad is the EdgeHD 9.25 reducer anyway?
John Stoneandrea tasselliedwardgharpNE-FL-Astro
37 replies1.1k views
John Stone avatar
I'm looking for a scope in the 1600mm range and I really don't like diffraction spikes so that leaves me with very limited options.
Either a giant crazy expensive refractor or an SCT with a reducer.
The EdgeHD 9.25 fits the bill perfectly with it's 146mm of backfocus in which I can install the Primalacuelab 2" LP Focuser/Rotator Kit, a Starlight Xpress AO unit, and a standard mono OAG/FW/Camera.
It's 0.7x reducer brings it down to 1645mm which fits all my galaxy/PN targets perfectly fine on an APS-C chip sampling the sky at 0.47"/px which gets me seeing down to about 1.5" seeing without drizzling.
Those with experience, how bad is the 0.7x reducer on an mono IMX571 chip?
What are the defects to expect?
Thanks.
David Foust avatar
I recent juggled with the decision to go with the 9.25 Edge or the plain old 9.25 SCT.
There were two factors it boiled down to for me:
  • I don’t have an observatory, so shooting at native focal length just wasn’t going to happen for me. The large scope is a sail and any breeze will impact your subframes. The main benefit of the edge is to get a flat field at the native focal length. I even struggle a little bit shooting at about 1450 and f6.3 with the Starizona .63x reducer. The whole setup is much more sensistive to environmental factors than if you were shooting at around 800mm FL or less. If you’re going to reduce it anyway, there’s some debate out there about the plain SCT with a Starizona corrector actually being sharper than the Edge with the Celestron Reducer. I haven’t been able to test this side by side, but I’ve been pleased with the Starizona corrector with my non-edge 9.25. Ultimately, my thought was that if it’s unlikely that I’ll use the native focal length, I might as well save myself $1,200 and go for the non-edge scope. (I actually saved even more than that when I bought mine.)
  • Speaking of reducers, there’s not really other options for reducing the edge, other than the Celestron .7x Reducer and the Hyperstar. Whereas the plain SCT can utilize the hyperstar, Starizona Night Owl .4x, and the .63x (starizona or celestron). I guess the Night Owl is being redesigned and it’s hard to find one used, but nonetheless, I use a 533MC, and it would be a great fit for me. It’s nice to have the another reducer option that would cover such a wide range of focal lengths. with the plain SCT and those reducers, you’d be shooting at about 525mm, 870mm, 1450mm, 2350mm, and barlowed (presumably at 2x) for planetary around 4700mm. The edge loses out on the 870mm length, and is a little slower at 1600mm. Plus, depending on your skies, being at a slightly lower FL around 1450mm may give you slightly better sampling than 1600mm.
In the end, as I mentioned, I decided on the plain SCT to save some money, since I wouldn’t be able to take full advantage of the native FL of the Edge (not without considerable expense at least (probably need a new mount and observatory too! 😅)
John Stone avatar
Thanks for the extensive reply. I appreciate it.  For me the Starizona is a no-go on the c9.25 XLT since it only has 90.3 mm back focus while the Edge gives out 146 mm.  The edge also has collimating screws for the corrector, mirror locks, and the larger 3” baffle nut.  Maybe there are other differences I don’t know about.
i wonder if the corrector lenses in the baffle tube can be removed?  If so then I could use the large format Starizona corrector and maybe get better performance?  I’d have all the advantages of the Edge design too.
I wonder if that would work?
Has anyone performed optical tests on the reducer to see what it’s spot diagram looks like?
maybe a ronchi?
The edge 925 with reducer is fine for aps-c.  It won't do well with full frame, but for galaxy hunting and PN's, I wouldn't hesitate to use the combo you suggest.
Of all the edge scopes the 925vis really the best optically.
Have you reviewed spot diagrams on the celestron white paper?  I can't recall if they post it for the reducer but I think so.
Concise
John Stone avatar
I checked out the white paper on the edge and the only spot diagrams they show are for the C14
https://s3.amazonaws.com/celestron-site-support-files/support_files/edgehd_whitepaper_final.pdf
I've never seen a spot diagram or optical test of the EdgeHD reducer anywhere.  The EdgeHD reducer has 5 glass elements (plus the 2 in the baffle tube) for a total of 7 glass elements and 2 mirror surfaces.
Starizona doesn't list the number of glass elements in their LF corrector but they do specific 5 glass elements in the smaller SCTCORR IV.   The image circle of the LF corrector is 42 mm and the back space is 146mm exactly the same as the EdgeHD corrector which is pretty interesting coincidence if you ask me. :-)
Starizona does have a "sort-of" spot diagram for their LF Reducer on a C14 but that's it.
I'll give Starizona a call and see if I can talk to Scott and see what he thinks about creating a hybrid scope.
If anyone has any other information about the performance of the EdgeHD 9.25 reducer, I'd love to hear from you.
Also, if anyone has a suggestion of alternative 1600mm-ish 10+"-ish scope I'd also love to hear from you.
The white paper has spot diagrams for all the edge scopes. At the end is spot diagrams for the 14 with the reducer. So not totally helpful but you can see that the 925 is better to start with (without the reducer).
Alex Nicholas avatar
Can’t speak to the Celestron Edge 0.7x reducer on the Edge HD 9.25, but have you considered the GSO (or rebrands) 8” Ritchey Chrietien?
  • Considerably Cheaper.
  • Considerably Lighter.
  • 1634mm @ F/8.
  • Less dew issues with no corrector.
  • Purely reflective optical system with no refractive elements.
  • Can add a reducer giving ~1300mm @ F/6
Worth considering…
GalacticRAVE avatar
John,
I am also a friend of “no spikes”. My experience is based in the Edge 11, which is a similar design, but the C9.25 has a somewhat slower main mirror (f2.3 vs f2) and less curved secondary, which results is slightly better optical specs. For the Edge11, I discussed some issues in the following post:
https://app.astrobin.com/forum/topic/49075/reducer/celestron-edge-reducer-some-experiences-and-experiments#post-79255
basically, the native Edge has a much cleaner optical performance than the reduced Edge. Problems are worst in the blue when you see blue flares well within the area covered by a MFT detector, so it should be worse for an APS-C. I pixel peeped a lot of images on astrobin, and it seems a very common problem. You can mitigate the problem by using Baader’s fringe killer., but loose quite a fraction of the blue light (which is starved anyway owing to pollution in suburbia). BXT can also help fixing it (though not always). but a fix is a fix, ie a repaired image rather than a good image.
So I ended up using most of the time my Edge 11 at native f10, using the reducer only when I really need the FOV (and even then I would consider mosaicing instead + binning)
CS Matthias
John Hayes avatar
I am not a fan of reducers. Save yourself the trouble and just get a bigger sensor. Reducers sound good in theory but in practice they often have trouble with aberration and/or stray light. I have never had good luck with any of the reducers that I’ve tried—ranging from Celestron to Astro-Physics. I’m even ready to get rid of the field flattener on my ASA600 because of its problems with stray light.
Well written
NE-FL-Astro avatar
I have an EdgeHD 9.25” with the reducer and an asi2600mm. The stars in the corners are not great, but BlurX helps and I tend to just crop them out. I don’t have any issues with the center of the image. This is the master in Luminance on the Cocoon Nebula with just an STF, no other processing. F/10 is very slow so I definitely did not want to image at that speed. You can check my uploads for processed images. I am in the process of upgrading to 3nm filters.
John Stone avatar
Is your backspace correct at 146mm?
Because that is really ugly!  And if that's the "normal" performance with this scope/optic I'm going to keep looking.
Maybe my "remove the corrector lens and replace it with a Starizona LF Corrector" idea would work better?
Now if someone would just invent and AI "diffraction spike eliminator"...  I'd pay for that.
Maybe we should ask Russ Crowman about is.
John Stone avatar
John Hayes:
John,
When you image at native F10 what do you do about the extreme oversampling of the seeing?  Bin?
But then your already long exposures need to become longer to overcome the additional 2x read-noise you get when binning x2 CMOS cameras, right?
The normal 1.5e- error on the IMX533/571/455/451 becomes 3e- if you're in HCG (double that for LCG) and that's just for Bin2.
But then you might run into dynamic range issues due to the longer exposures, right?
I'm curious about your thinking on the limits of binning vs exposure time.
Thanks.
John Stone avatar
https://www.stellaroptical.com/santel-mk9.htm
Thanks.   This looks one heck of a planetary scope for sure!   But it's focal length/ratio much longer/slower what I'm looking for for DSO.
However this one would do the trick:  https://www.stellaroptical.com/newt-mn106.htm
I don't know the size of the corrected image circle on it or the back-focus available but in theory it checks all my boxes.
However I think that webpage was last updated in 2005.   Are these scopes still available?
NE-FL-Astro avatar
John Stone · Sep 2, 2025, 07:59 PM
Thanks.   This looks one heck of a planetary scope for sure!   But it's focal length/ratio is 2x what I'm looking for for DSO.
I use the Celestron adapter that then requires 55mm of back focus, which I do have. This was 300 second exposures in luminance which does make bright stars a mess, but it does do better with shorter rgb exposures. If you’re looking at 1600mm+ focal lengths, you’ll have to make compromises with either shelling out money or compromise on quality. I have heard the Starizona reducer is better, but I have no personal experience with it. Down the road, I will probably upgrade to something like a Planewave CDK14 with a .66 reducer. That will acchieve a 1692mm focal length at f/4.75 (2.17x faster than f/7).
John Stone avatar
NE-FL-Astro
The planewave scopes sure are nice and a CDK12 with a reducer could work very nicely, but we're back to my hatred of diffraction artifacts in my images.
I hope I can get a hold of someone at Starizona and see what their reducer's spec are.
NE-FL-Astro avatar
John Stone · Sep 2, 2025, 08:20 PM
NE-FL-Astro
If you do, please share… I’d be curious to see the performance difference.
John Stone:
*What availability there is in the US I have no idea  AP still make those 10" mak-cass, if you have the cash. The AP FR should work pretty well on those long focus maks, as it was designed for them in mind (and other similar flat field telescope). They do crop up in the used market though. Both mak-cass and mak-newt.
John Stone avatar
thanks for the update.
It looks like the AP Mark-Cass is no longer made (ended in 2019)
and as far as I can tell, the last MN106 changes hands on AstroMart in 2019.
I’m starting to think a DiffractionSpikeXterminator might be something to develop to go along with a CFF RC (or similar). :-)
You can easily remove spikes either at the source or using an add-on on any telescope with standard spiders. No need for hypothetical software…
John Hayes avatar
John Stone · Sep 2, 2025 at 08:05 PM
It depends on your seeing conditions. I just go with the extreme over sampling on my ASA600 because the seeing is sometimes sub-arcsecond and BXT does better with slightly over-sampled data. If the seeing is poor, it’s easy to bin in processing. Regardless, most of the time, reducers are more about field of view than sampling. Under 1.5” conditions, the optimal seeing for a 10” scope at F/10 is about 7.2 microns, which might be ~6.9 microns for a 9.25”. That’s about perfect for 2×2 binning with a 3.786 micron pixel, which will double the SNR. With a reducer at say F/7, the optimum sampling becomes around 5 microns, which is slightly under-sampled for 2×2 binning and slightly over-sampled for no binning. Read noise is independent of exposure length so the only concern is to make sure that it’s small compared to photon noise. As long as you aren’t doing lucky imaging with super-short exposures, the read noise for most “common” long exposures (say 3-10 minutes) isn’t going to be a problem. And…all of these considerations pale in comparison to the problems you’ll face if you find stray light problems or serious halos around bright stars introduced by the reducer—and that happens all the time. Yes, some reducers work well (and if they are perfectly made, they should) but I have fielded so many questions behind the scenes from folks who have problems with their reducers that I’ve lost count. The biggest problem is that if a reducer doesn’t work well, you can’t fix it. The simple fact is that reducers are VERY hard to make correctly. If it’s not right, it either has to go back to the manufacturer, you have to sell it, or you put it on the shelf and go back to plan A, which is running the scope without a reducer. That’s why I’m telling you to skip all the intermediate steps and just start with a bigger sensor and skip the reducer in the first place. Maybe it will work out if you ignore my advice but remember the words of Dirty Harry, “Do I feel lucky? Well, do you…?” I’ve personally played the odds and every reducer that I’ve ever bought has ended up on the shelf.
John Stone avatar
John Hayes:
No, No, I don't don't feel lucky at all, Mr. Dirty Harry Sir.  :-)
But seriously, thanks for this hard earned advise.  This is the kind of knowledge that takes years and $$$ to learn the hard way.
So I got it, and I hope the other folks reading this  do to:
F10/bin2, it's the only way to go.  :-)
Charles Tremblay-Darveau avatar
I’m using the 2400mc with the edge 9.25” at f/10. This camera has larger pixels and work well at bin1. The other approach I would go is bin2 with the 6200mm as John recommends.
I have the reducer but don’t use it. I think the full frame / large pixels-binnning/ f-10 combo works very well with most target I would frame with an SCT
John Stone avatar
John Stone:
I want to follow up on this.   I had a nice conversation with Scott, the optical designer at Starizona, about the possibility of using his LF reducer on an EdgeHD 9.25.
It turns out that the secondary mirrors on the edge scopes are different than the XLT scopes in addition to the corrector lenses in the baffle tube.   While it is possible to "convert" and EdgeHD 9.25 to an XLT 9.25 optics by removing the corrector lenses and swapping the secondary mirror, it turns out that the LF corrector won't work well with the slightly different mirrors on the 9.25 version as it's designed for the faster mirrors in the C11 and C14.
So that's the end of finding a better reducer for 9.25 optics.
Which is fine b.t.w. after John Hayes and GalacticRAVE's personal advise on skipping reducers and binning the camera instead.
