Replacement Mount
4 replies118 views
Gamaholjad avatar
I wonder if folk could suggest a replacement mount. I currently have a Celestron CGXL and it's on its last legs. I currently have 45lbs mounted on it at the moment. Askar 151phq with filter wheel camera etc total 45lbs.
So any suggestion what folk are using to mount such a weight.  Im looking at eq8r, paramount myt 6 series , pegasus nyx101.
So if you have similar equipment mounted, what mount do you.
Thanks for any suggestions.
Brian Puhl avatar
I would avoid harmonics, personal preference for multiple reasons. If I was to pick from your 3 choices I’d probably run the EQ8. Frankly, the CGXL is a horrible mount and I’m surprised you didn’t abandon it sooner.
I currently run my Esprit 150, with dual losmandy plates, imaging train and all on an EQ6 with great results. I’m pretty sure I’m around the same weight overall. Guiding on average 0.35 arc second, and dropping down into the 0.2’s frequently now. Not all EQ6’s are built the same, but I run alot of skywatcher products and have honestly not found a single reason to dislike or abandon the brand.
Brian Puhl · Sep 1, 2025, 05:08 AM
+1
Gamaholjad avatar
Brian Puhl:
The CGXL was bought for me by my father so I'm kinda attached,  but yes it's not the best. Weriod as it is I have a AVX which tracks at .32 ( I know unheard off, I must have the one they built on Monday ). I do also have an EQ6pro which is tuned and reaches .3/.2 rms. So I am swayed a little to the eq8 just for the weight.
Stjepan Prugovečki avatar
I do have Esprit 120 mounted on iOptron CEM70 . It is for 4 years mounted on the fixed pier in my backyard , just covered with Telegizmo cover (temperatures are from -15C to 39C. rain, snow, … name it) . Not a single glitch all that time. Was running also 300mm 22kg Newton on it , with no issues whatsoever. I am in Bortle 4.5 , and if guiding RMS goes to 0.5” levels I consider it terrible night , it is usually on 0.4” level or below. If you looking to non-harmonic , CEM70 is extremely competitive in price/payload , price/guiding performance an weight/payload parameters
RC6 on a CEM26 Thoughts !!!!!!
I am looking to pair an RC 6 with my CEM26 mount !! Total weight will be approx 9 kgs !! I am worried will it guide and balance properly !! Looking for suggestion and help !!
Discusses mount capacity concerns; relevant to balancing RC 6 on CEM26.
Jan 16, 2024
EQ8-R mount construction and setup directly relevant to author's consideration.
28 days ago
Inspiration and/or examples of placing powersupply and Melee
Hey at the moment I have my PegasusAstro Powerbox and Melee astrocomputer mounted on top of my scope. I am considering moving them down to the mount/tripod in some way. It would help on weight distribution and hopefully help improving my guiding even...
Addresses weight distribution concerns on mounts; directly relevant to poster's goals.
Dec 20, 2024
ASA DDM 60 for 3000 usd?
I currently have a chance to get the ddm 60 for about 2800 usd, and I’m wondering if it’s worth it. It has apparently been used only a few times and it’s in “like new” condition. I currently run a EQ6R pro and a 1000mm f4 newt, so I am wondering what...
ASA DDM 60 alternative mount option for similar weight capacity needs.
Jan 28, 2026
Paramount MYT + Nina + PHD2 guiding issues
Hey folks, quick question for anyone running a Paramount MYT with NINA and PHD2. My Paramount is doing my head in. Everything is set up correctly as far as I can tell, SkyX, ASCOM, all that. But every now and then PHD2 throws up the error “your mount...
Paramount MYT experience from current user with comparable equipment setup.
Nov 27, 2025
