Gain settings
7 replies•108 views
Maciek Jarmoc avatar
Hello!
What gain and offset settings do you use in your cameras? Are these settings analogous to those in the ASI 2600?
I ran a test in Sharpcap - sensor analysis - and the result showed that the unity gain should be 300.
Every sensor is going to be different. It’s a balance between subject requirements, noise, gain and dynamic range. Don’t worry about unity gain. All that means is that you are using a gain setting where 1 detected photon = 1 ADU of signal. That’s not usually where you’ll find the best balance as described above.
SkyHoinar avatar
With this camera I use most of the time: Gain=100 and Offset=120.
Mikołaj Wadowski avatar
Regardless of the camera, I recommend using the gain at which your camera switches to the HGC mode, which is when read noise suddenly drops. Going higher rarely brings any significant improvements in the read noise while decreasing the dynamic range, making it pointless in my opinion. Going any lower (or switching to LGC manually if your camera can do that) isn’t worth it either, in my opinion, since when you’re imaging targets bright enough they clip at HGC you can simply take 10-15mins of short subs and combine them after stacking.
For offset, I’ve set mine to 20 and never really noticed any clipping on the low end, but you can go higher if you want, it doesn’t matter all that much.
Helpful Insightful Respectful
SkyHoinar · Aug 31, 2025, 10:20 PM
This is data from SharpCap which shows that the camera switches to HGC at a gain of 300.
That’s your sweet spot…
Check what is your RON in ADU instead.
Dave Erickson avatar
Good suggestions above. I look at the histogram of a dark frame and bias frame under the integration conditions and select the lowest Read Out Noise for gain and an offset with some head room.. Here is an example.
📷 IMX571GainOffset.jpgIMX571GainOffset.jpg📷 IMX571MCGainOffset.jpgIMX571MCGainOffset.jpg
This work is part of fielding an 85mm F/2.8 astrograph
https://cdn.astrobin.com/ckeditor-files/14617/2025/7464f91a-23b6-4898-8291-b8d342ce583c.pdf
ToupTEK 2600 MM Setting
What are the best settings for the ToupTek camera 2600 MM like Gain and offset in the different modes, HDr etc Thx
Discusses gain and offset settings for similar camera models and modes.
Sep 29, 2024
Touptek ATR585M + Sharpcap sensor analysis = Massive Confusion.
Info 00:46:43.289585 #1 Opening SharpCap.Cameras.ToupTek.sdk.SDKWrapper`1[SharpCap.Cameras.ToupTek.sdk.Toupcam] Camera ATR585M(USB2.0) (#\\?\usb#vid_0547&pid_157d#7&33b0be72&0&1) : FLAG_CMOS, FLAG_ROI_HARDWARE, FLAG_MONO, FLAG_TEC, FL...
Discusses Sharpcap sensor analysis with similar camera model and settings.
Nov 17, 2025
ASI 1600MM pro gain and offset
Hello everyone I am looking for the best gain and offset for my 1600mm pro. Exposure time: 180S (LRGB) and 300S (SHO). Thank you for your help Clear sky Nico
Directly addresses gain and offset settings across ASI camera models.
Sep 29, 2023
Player One Poseidon M camera showing clustered hot pixels in dark frames
Hello everybody, I recently bought a Player One Poseidon M camera (analogous to ZWO’s ASI2600-M Pro). The camera hasn't had its first light yet, because the weather has been bad and the filters haven’t arrived yet. However, I took bias and dark frame...
Addresses camera gain/offset settings and mentions ASI2600 comparison directly.
Dec 14, 2025
HyperStar - Advice on Camera Settings
I just bought and received a Starizona HyperStar for my Celestron Evolution 6. I'm using a ZWO ASI585MC Pro, shooting from a Bortle 6 area. With the current weather conditions, I could only test it once, during a two-hour session interrupted by c...
Discusses gain and offset settings for ZWO cameras, directly relevant to your configuration.
Oct 8, 2024
