Power Station for occasional use
6 replies111 views
Adrian Webster avatar
Hello all,
I know this topic comes up a lot, but i’m trying to consolidate my research with a few opinions of those who might be in the same boat as me.
My normal set up at the moment is a SA GTi mount, with a REDCAT 51, ASI533MC Pro, filter wheel, EAF, guide scope and camera, ASI Air and a couple of dew heaters.
I power the set up via a Nevada PS-08 6-8A Regulated Linear Power Supply.
I run one cable from the 12v ciggy lighter socket to the mount, and another cable from the poles (via a fused 12v ciggy lighter socket) to the ASI Air. The air then powers the dew heaters, and camera.
I run all this in my back garden from the mains (240v).
The only problem is, there are a couple of targets I want to shoot over the winter, I can’t see from my garden (mainly the Orion Nebula, Horse head etc.)
Just up the road I have a playing field, which offers good parking and a good view of the sky. But no power.
I was therefore thinking of picking up a power station to run the ASI Air and its associated ancils, and sticking 8 AA’s into the mount to power that.
The Bluetti EB3A and Elite 3v2 seem reasonably priced at the moment, so I was looking at these, especially considering that this is for occasional imaging use only.
So my questions are:
  • Has anyone done this?
  • Will the AAs give me sufficient time to image a night (in a UK winter, so ultimately from 1800hrs until 0600hrs. and maybe down to -5 degrees C)
  • Will something like the Bluetti EB3A or Bluetti Elite 30V2 provide the power needed to run the rest of the kit (I’ve read too much about if a power station doesn’t deliver a full 12v, the gear can become knackered!) yet all the power stations seem to be rated at 12v.
  • Other than the price, and the EB3A’s DC5521 port being 10a per port and the Elite 30V2 being 5a per port, is there any consideration on why I should choose one over the other.
Finally, if i’m going the wrong way with all my research, please feel free to let me know where i’m going wrong and what alternatives might be better.
AstroÅmazer avatar
I have used 8x rechargeable Energizer NiMH AAs in Boston, MA winters without any problems.
I use a 27000mAH battery pack for the ASIAir/ASI 533/585 MC Pro Camera and accessories and another 27000mAH battery pack for the dew heater. The dew heater dies first. I have EAF, EFW, CAA, and a guide cam for accessories.
Edit:
No CAA or EFW with 533 setup. FMA180 with EAF and filter drawer.
AstroÅmazer · Aug 31, 2025 at 09:07 AM
Were these 2000mAh?
AstroÅmazer avatar
Adrian Webster · Aug 31, 2025, 09:13 AM
Were these 2000mAh?
Current ones I have are 2300. I use them for all kinds of gadgets and kids toys. I may have 2000 ones too. Just looked at the last Amazon purchase.
Michael Ring avatar
The Bluetti EB3A has 286Wh capacity, which means roughly 8 hours at 3A current, so it may not last the full night. When you have a way to measure the total power consumption of your rig it is well worth checking the actual current the whole system draws when tracking and imaging.
I’d not use batteries for the mount, it draws little current and will not drain the battery in the powerstation much.
What I do is that I have a 100Ah LiFePo4 battery with 100Ah which lasts a whole night to feed 3 rigs, but my nights are a little shorter because I first have to drive to the mountains and set up.
Something like this here:
https://www.litime.de/products/12v-50ah-bluetooth-lithium-batterie-fur-elektromotor-boote-zuverlassige-power
should last the whole night for you
There are versions of the battery with and without bluetooth, it is nice to see the statistics over night but this is not a must, only convenience
Martin Lück avatar
I use the Bluetti EB3A for the following setup:
AM3, EAF, ASI715MC, ASI120MM Mini, ASIAir Mini and two COOWOO lens warmers.
I can record for around 8 hours with this setup. I have not yet been able to test whether this also works in winter at low temperatures. The voltage of the EB3A is approx. 13.4V. Which works perfectly. I had previously ordered another power station, but it had an unregulated 12V output, which dropped down below 12V. I then had to send this powerstation back.
Sam Badcock avatar
I run an EQ6R-Pro, ASI2600mm, MeLe mini pc, EAF and EFW plus guide cam with a single dew heater on max setting full time (this is another story) all through an ECOFLOW River 2 Pro
https://ecoflowtech.co.nz/products/ecoflow-river-2-pro
I could get 13hours run time before I had to permanently make the dew heater run full noise and now I’m not 100% sure what I can get though I’m pretty sure it’s around the 10 Hour mark!!
That link should give you a rough idea the kind of specs to look for when getting a power station!! It may only be for occasional imaging use as you mentioned but they do come in handy for other things
What is a Good Way to Power it from backyard?
Main question is what type of Cables and all do i actually need and could i power via Main or Battery if it's only in my backyard
Discusses power options for equipment, relevant to backyard power needs.
Jun 17, 2025
Pegasus Pocket Powerbox Micro - Comments wanted.
Hello, Like many others I am having issues powering my dew heaters with the Asiair Plus so I am looking at buying a powerbox just for that. The Pegasus Micro seems to suit my needs and it does suit my budget. My ZWO cooled camera, EAF and guide camer...
Power station options for astrophotography equipment powering needs.
Mar 5, 2024
Connecting EAF, EFW, main cam, guide cam, and mount to ASIAIR?
There doesn't seem to be enough ports….only 4 USB ports and I need 5 it seems. Anyone else deal with this issue? Can you power things from the 2600 MC pro?
Power station could provide additional power for USB-powered devices.
Sep 10, 2024
Beelink 12V box PC power supply
Hello, I have a Beelink box PC that I would like to start using for field acquisition. The Pc runs off of 12V. Using a simple wall wart, I have no issue getting it powered up and set up. However, for some reason, it will not power up when connected t...
Discusses power station solutions for occasional battery-powered equipment use.
Oct 6, 2025
Connecting ZWO Camera Help
Hello Everyone, So Today I have received my first Astrophotography Setup ( I am a complete beginner, I have never done astrophotography before) A SkyWatcher Gti Mount and a ZWO ASI2600MC AIR Camera, Ive been at it for about an hour and cant figure ou...
Power Station for occasional use — relevant to powering mount and camera setup
Mar 22, 2025
