MetaGuide won't recognize ZWO 585MC camera, missing directshow driver
5 replies82 views
I’m attempting to experiment with MetaGuide and I can’t seem to get it to recognize my ZWO 585MC. I know it needs the directshow driver but it’s no longer to be found on the ZWO website. When I run Meta the only camera it recognizes is the one in the laptop. When I try to “select camera” in Meta, nothing happens.
Well written
Himanshu Pandey avatar
You can download the ZWO direct show driver if you scroll to the bottom on the “Others” section driver site.
Tobiasz avatar
Did you try the workaround with sharpcap and broadcasting the video stream to metaguide? That's what I do with my qhy5iii585m. Qhy cameras dont work with metaguide directly either.
Concise
I haven’t but I like that idea as I don’t have to mess with drivers. I’ll have to dig into Sharpcap and figure out how to do that
Himanshu Pandey · Aug 23, 2025, 09:47 PM
Ahh, there it is. I’ll grab that in case the SharpCap angle won’t work.
Tobiasz avatar
From Tony Gondola · Aug 23, 2025, 10:43 PM
From the sharpcap side it's easy, there is a button “Enable live broadcast” and if you activate it SC will broadcast the video stream via UDP to every other client on the network. In Metaguide you have to setup a MG server with an IP and port and if it works it will then receive the live broadcast frames.
I can check later the settings of my mini pc and give you feedback.
Edit: I forgot that the MG server setup is described in NINAs Guiding chapter: click
Zwo asi 2600mc pro get's recognized as westbridge
Hi everybody, I got a problem with the asi2600mc pro. All over a sudden it only gets recognized by westbridge. I tried with all programs, changed cables, laptops, nothing helps. Zwo forum says it needs a driver for westbridge, which I can't find....
Similar ZWO camera driver recognition problem with directshow driver solution.
May 2, 2025
Drivers Question
Hi, I am new to the QHY cameras. Currently using a QHY600 with Mele 2q mini PC. I installed the all in one drivers which seems to work. But after every session, I turn off my PC. When I start next session, the device is no longer recognized and I hav...
Similar driver installation issue with astronomy camera on Windows system.
Oct 13, 2025
Polemaster camera not recognized on Windows 11 despite working on Windows 7
I have a Polemaster camera that I bought around 5 years ago. I used it with my old Laptop (Windows 7), and SharpCap. It worked great and still does with that laptop. I recently purchased a new laptop (Window 11 home), installed the driver/App package...
Camera not recognized despite previous functionality; Windows driver problem.
Jan 27, 2026
I need to update my Asi 120mm mini because of faulty guiding. The ZWO Updating Software doesn't provide me with the right Files
I need to Update my ZWO 120mm mini guidescope because it won't guide properly and loose stars even in a clear night. Sometimes over half of my exposures during a night are unuseable. I downloaded their Upgrade software, connected the camera, whic...
ZWO camera software driver issues similar to missing file problem.
Oct 13, 2023
TouTek filter wheel registered as a camera..?
Hey, I just got my new ATR585M + AFW-M by ToupTek and the camera works absolutely fine. My only issue is the filter wheel, I could originally not find it in NINA under filter wheels but then I saw it was registered as a camera.. I already tried updat...
ToupTek camera recognition issue; similar hardware/software compatibility problem.
Mar 16, 2026
