Keep or sell my Optolong filters?
4 replies160 views
Tareq Abdulla avatar
I have Optolong SHO filters with 6.5nm and 7nm 36mm since 2018, and i used them several times in the past without nice results due to LP in my area, and later when i added 3nm filters i no longer using those Optolong 6.5nm/7nm filters anymore, but i see some people using them if they have fast optics, also some are using them for nice results anyway with different scopes, i now have many scopes so i might have nice results again, also with RGB filters and if good processing it might be possible to minimize the issues of those Optolong filters, i just still think i won’t use them much in my LP over 3nm or 5nm filters anyway unless they are better for fast optics and i didn’t buy that highspeed filter, so what do you think, keep them or sell them?
Mikołaj Wadowski avatar
I could only imagine the wider bandwidth filters could be useful for galaxies with significant redshift and for those you usually need a very large scope, as they’re far away.
I see you’re using a f2.8 lens. I think, though I haven’t done the math, that 3nm filters will give you a better or at least similar SNR to 7nm filters despite the bandshift, as the 3nm filter blocks >2x more unwanted light.
If you ever see yourself building a second rig to run alongside your main one, leaving these filters will save you some money. If you don’t I’d sell them.
Helpful Insightful Respectful
6-7 nm narrow band filters are still useful even under heavy LP. Someone just getting started could put them to good use if the price is right. Figure on getting 50% of the current price.
Mikolaj Wadowski · Aug 22, 2025, 12:24 PM
Ok, so for galaxies i think wider bandwidth could be a better way, i will try that, and funny that you also mentioned very large scope, i have a large scope, 10”, that i bought it mainly for galaxies although i leave under Bortle 8/9, and i am thinking about buying even larger scope in future but for planetary or everything, so maybe your point about keeping it for those situations could be a good idea.
I have different lenses, but larger one i have as prime lens is 300mm f2.8, i do have 135mm f2 and 85mm f1.8 and even 50mm f1.4, so i am not limited with aperture of lenses, same with telescopes, i do have a Newt with f4, i can use a reducer to bring it to ~f2.8, so that i also keep thinking about those cases i am using fact optics, but the last point you mentioned is what making it confusing decision.
Your point about building a second rig is a point to be taken, but i am building multiple rigs for different reasons, one reason is to take RGB completely separated, so this is the thing i am thinking about, if that fast optics will have redshift, is that affecting the nebulosity or the stars, if stars then simply i am removing stars from SHO data and adding RGB ones, hence i ask if using 7nm/6.5nm is any useful if i am going to use RGB data anyway, i don’t want to rush a decision now and later i find out that 7nm/6.5nm can be handy for something more than 3nm-5nm filters.
Tony Gondola · Aug 23, 2025, 12:38 AM
I still have them since 2018 as i said, i will hold on them maybe until next year, if i didn’t find much use of them anymore then i think i won’t hold them any longer.
Fast optics with regular speed filters?
Hi, What will happen if using not a highspeed designed filter with fast speed optics such as f/2 or f/1.8, f/2.8? What could be the problem if doing that?
Discusses filter selection and usage considerations for astrophotography setups.
Feb 22, 2026
My PixInsight OSC Workflow
This is my current process flow for OSC processing without and with a general LP filter. The process flow is a little different using Dual, Tri …etc band filters. I will update the process flow for PixInsight 1.9.2 MARS later. Something to do w...
Relevant; discusses narrowband filters and LP filter considerations in processing.
Jan 7, 2025
Did I created an artefact with light pollution filtering
On this photo of IC1318 in SHO, I tried light pollution correction in AstroPixelProcessor. I ended up with those EW orientated reddish crescents. Are these crescents an artefact of the correction or they really exist. Without the light pollution corr...
Direct experience with Optolong filters and light pollution correction challenges.
Jan 10, 2024
Chroma 3nm for Fast Systems - Anyone using them?
I am considering replacing my present 6 nm Astronomik Max FR filters on my Epsilon 130D (f3.3) with the much narrower "Chroma OIII (3nm) Imaging Filter Optimized for f/2.8-f/3.6" (link is to the O3 but they have the others as well). Should ...
Optolong narrow filters in light pollution; directly relevant experience comparison.
Jan 8, 2025
Optolong LRGB and 3nm SHO
Hello, I’m thinking of buying a new camera. At the moment, I’m using an IMX571 color and an IMX533 color. Sometimes, I use an SVBony SV220 filter to get DNB data. Now, I want to start using mono because I believe it will make a huge difference, espec...
Compares filter brands including budget alternatives to expensive Antlia/Astronomik options.
Nov 22, 2024
