D. Jung avatar
I have tried editing my Sadr region several times now, but I keep failing at getting a satisfactory result in terms of color composition of this SHO data.
Maybe someone in the community can manage and give me some pointers?
https://www.dropbox.com/scl/fi/4cct4or5aelq1dmwwfzr7/sho_lin.xisf?rlkey=vf8rgt8cns1uwqzxa91e0ck88&st=1bovynyd&dl=0
The oiii chanel is lightly denoised and all three channels are deblurred using Xterminator.
Well obviously, the color balance is way off. I don’t use PI but In general, to get a starting color balance, assuming the three narrowband images are of similar density my workflow would be:
Correct gradients
LRGB recombination with alignment and linear matching
Plate solve
SPCC color calibration
This should get you close unless one of the frames is really out to lunch. In that case you can try pixel math instead. None of that will get you good star color though. SetiAstro has a great plug-in for that if you didn’t get RGB data.
After that it should be:
Sharpening
Noise reduction
Star removal
Stretching both the starless and star only plates
Final touch up of both plates and recombination (I usually use Affinty Photo as it gives me much finer control)
D. Jung avatar
The three channels are aligned using Lin fit. And I get a similar result using setis tool.
LinearSHO Seti perfect color picker tool with unlinked auto stretch preview
How are you assigning the channels? I know you are working from SHO data, is that the palette also? Have you tried others like Forax?
Oscar H. avatar
Invert image, apply green SCNR, at 100% (or less; this effects how much purple the image has)
invert back, apply green SCNR, use at least 70% (I personally remove all the green, but with your image, I guess some might be desirable)
colors should look better; also make sure you neutralize the background of the image; use a small preview box on a dark nebula or what you think is the background, and use that for BGN.
stars should look saturated at this point, so I recommend extracting them if you want to bring out more color in the nebula later on
D. Jung avatar
Tony Gondola · Aug 19, 2025, 08:11 PM
Standard way of assigning the channels
R - Sii
G - Ha
B - Oiii
My default workflow is to do linear fit and combine them in pixelmath. Usually Ha is quite dominant but in most cases I can create a good color composition via a reduction either with the curve tool or SCNR, but not on this target. I haven't tried fornax, I prefer the Hubble palette.
I can’t see any reason to stick with the Hubble palette if it’s not giving you the results you want.
GBSWM avatar
Don't know what you went for but this is my quick and dirty of your very nice data.
Very basic workflow(in Siril):
-split the channels and extracted stars separatly(probably not necessary)
-recomb starless in SHO pallette and do an unlinked stretch (Statistical stretch with .2 as the target and Normalisation on)
-Curves only affecting R&B elevating the mids and keeping lows and highs mostly the same
-this indroduced some purple so invert & SCNR
-curves only R slight bump in the mid and highs to bring more orange out
-a small saturation boost
-starless finished (it's not perfect but it was a 5 min job...)
-recomb stars(prob not necessary to split in the first place)
-invert & SCNR to get rid of the massive amount of purple and they look amazing now ^^
- Recombine stars into starless stretching to taste
You obv have some (tilt?) artefacting around the edges which would be a shame to crop because of that beautiful diffraction star at the top. There is some purple/green gradiant you might get rid of to make this look way nicer, but i was mostly focused on getting the colors in the middle correct. Hope this might be of some help or tweaks your brain in the right way ^^
-Alex
Edit:
-did another SCNR & pushed more blue into the highlights
[deleted]
There’s nothing at all wrong with this data - it contains lots of color and great details.
Mikołaj Wadowski avatar
First of all, you need to correct the gradients in the image. There was a slight bottom right → top left gradient in all channels, I lazily fixed it with MARS. The lack of reference Sii data was inconvenient, but it should be doable still. Getting rid of gradients before color calibration is crucial, as they can skew the colors by quite a lot.
If you want to do a three-channel color composite of narrowband data, like SHO, linear fit is not a good nor reliable option to achieve good color balance. Neither are SPCC and PCC for that matter, as they’re not designed to create a good balance between narrowband channels but rather one that represents the relative intensities, which will pretty much always make Ha dominate over other emission bands. The way to do it right would be the Color Calibration process:
Start with making a background preview, somewhere where there’s minimal or no signal in any of the channels. In this image, the long dust lane in the middle is a good fit. Use Background Neutralization with that preview as the background reference. Then, in Color Calibration, select the same preview as a background reference. Then deselect Structure Detection and select Manual White Balance and play around with the sliders until you like the result. Optionally, if your color balance is off at the beginning, you can select a bright feature visible in all bands as a white reference and run Color Calibration with Structure Detection disabled to get an initial color balance.
People often massacre the green with SCNR when doing SHO - I believe this to be a mistake. To me, it’s basically throwing out 1/3rd of the data. Suppressing green itself is fine, in the end it’s up to personal preference, but there are other, better ways to achieve that: Color Calibration, Histogram Transformation, Curves. They all can make the image less green-dominant while preserving the delicate color gradients between yellow/orange and blue and the extra layer of color depth. If you are going to use SCNR, do it at a low strength and be careful not to lose the color depth, but if doing a serious edit I recommend giving other methods a shot.
Either way, if you don’t particularly like SHO here, I recommend exploring other color palettes, especially dynamic ones similar to Foraxx’s. Or trying out channel mixing/blending. Both give you much more room for creativity in my opinion.
Here’s what I came up with. Processing: MGC → Background Neutralization → Color Calibration → slight denoise in Sii and Oiii → StarX → Invert → SCNR @ 20% → Stretch → 2x Dowsample (for the Magma image, SCNR was skipped)
1. Normal SHO
2. Dynamic ‘Magma’ palette with a slight saturation boost. The pixel math for the palette was made by Uri Darom, you can probably find it online somewhere.
D. Jung avatar
Thanks everyone for your ideas and suggestions. I tried out a few and finally reached a satisfactory result using the classical SHO pallate.
I experimented with Background Neutralization → Color Calibration over LinFit, but the results did not differ much. What helped in the end was to use Invert + SCNR to reduce purple cast. I also opted for stretching the channels individually this time to control the green cast better.
  • LinFit
  • ArcsinH + Curve on each channel
  • Combine to SHO
  • high/low adjustment and slight gamma correction with histo
  • Remove stars (removing stars first doesnt always play well with ArcSinH)
  • lots of masked adjustments, denoise, saturation and local tone
  • second edit for stars only (h+sii-o-o combination, strong denoise, arcsinh, histo, star screening)
  • combine to final image
Once I get an RGB filter set, I will also replace the stars 🙂
📷 Barnard 347 - Sadr Butterfly nebula_SHO_2600.jpgBarnard 347 - Sadr Butterfly nebula_SHO_2600.jpghttps://app.astrobin.com/u/mxpwr?i=azkobi#gallery
Cant platesolve this image in any of the three color channels for the life of me
I have been trying for months to platesolve any of the three color channels of this image with no success. I tried with both remote and local catalogs (GAIA). The error is the usual *** Error: Unable to find an initial linear transformation. Here is ...
Unrelated to plate solving issues; focuses on color editing rather than astrometric alignment.
Apr 21, 2025
Looking for advice on daystar chromosphere
Hello, I have a daystar chromosphere that seems to be slightly heterogeneous in terms of imaging results. Do someone can give me advice? Thanks in advance. Francesco
Addresses image editing and color composition issues similar to chromosphere imaging problems.
Mar 14, 2024
Do you know what is wrong with my image capture?
I've been troubleshooting my imaging on the Lobster Claw Nebula over a few sessions now. I have an artifact that I'm stumped as the the problem. 1. Collimation has been verified to be good 2. Tilt has been verified to be little or none 3. Foc...
Addresses image quality issues, though focuses on capture rather than post-processing.
Aug 15, 2025
Pixinsight Workflow Suggestion
I have been OSC imager since 8 years and now i am switching to Monochrome camera with full broadband and narrowband filters set I have always looked to retain the original color balance of the object. Now with the use of SHO narrowband filters how am...
Discusses SHO color composition and editing challenges with narrowband data.
Sep 18, 2023
"Eyeshadows" on the stars ?
Sometimes I get these eyeshadows on the stars (blue color spots). Can someone help me ? 24 x 180s with ZWO585MC Pro, APO125 with Korrektor 0,8 = 780mm Stacked with siril Denoised with GraXpert Tuned with Gimp Thanks ! Reiner
Color composition issues in post-processing similar to eyeshadow artifact problem.
Mar 25, 2025
