Maximum Number of Subframes with WBPP
8 replies272 views
Jerry Gerber avatar
I’m using an APS-C sensor (ASI2600MM), each subframe is little less than 50MB.
How many subframes can I pre-process in WBPP before starting to see it slow to a crawl or even fail?
I’m running Pixinsight on a fast i7 CPU, fast SSD drives but with only 16GB of RAM. Would adding more RAM change this capacity?
Thanks,
Jerry
Marcelof avatar
With such little memory, I would say around 100. And yes, increasing the RAM will certainly increase the PC's capacity (put in as much as you can afford).
Peter avatar
Hello Jerry.
Difficult number to pin down as to how many exactly will impact speed.
More ram will certainly help. Pixinsight recommend 64Gb minimum but I've run WBPP with an 8gb laptop and a 32Gb memory PC.
I would suggest if you can, go to 32GB or if your board can take it 2x 48GB dimms. You can populate all 4 Dimm slots but you won't get maximum speed if you do. They will run at 3200MHz or there abouts which is fine. Go with as much memory as you can afford and fit on your computer.
I've just done a 401 lights run of LRGB HSO at 32mb each and took around 45 minutes at 2x drizzle.
The Drizzle part at 2x is about 50% slower than 1x Drizzle so makes no real difference to overall time.
I'm now running a I9 285 and 192Gb memory.
On my old machine with an 18 core Xeon at 2.3GHz and 32Gb memory the same stack took just under  3 hours. Which I though was pretty good going.
The longest run was 32 hours with 240 lights @199mb each hence the new build. While it didn't collapse the computer it came pretty close.
Also how you setup WBPP helps..
Linear defects correction can be left out if you know your camera chip hasn't got lots of column and or row  defects. That will reduce your time. Use Fast integration. Change the presets from Maximum quality to Faster with good quality or even the fastest with lower quality.
I'm sorry this isn't a definitive answer as there isn't one really. Hopefully the community can give you more of a definitive help than I have.
Peter
Jerry Gerber avatar
Marcelof · Aug 15, 2025, 07:26 AM
That estimate is off. I’ve processed numerous images with over 400 subs using WBPP.
Arne Biermans avatar
Jerry Gerber:
Thanks,
Jerry
Yes, adding memory will increase the number of subframes you will be able to process. IF all of your RAM were available for holding images that would equate to about ~300 images. But obviously Pixinsight/windows and other apps eat into available RAM. I use 96GB  of RAM and have processed north of 500 images no problem. But you also need to assign a good size page file on a fast drive. Advice: add as much RAM as you can afford / your system allows.
Oskari Nikkinen avatar
I tried stacking ~1500 subs with WBPP once but could not get it to make any real progress overnight. 16GB ram, SSD, i7-6700k and also an IMX571 camera so same sized files as yours. So whatever the max reasonable number of subs ends up at, its lower than 1500.
Oskari Nikkinen:
Did you use a page file? I would suggest setting a 100-200GB page file on a fast drive. But 16GB of RAM is just not remotely enough.
Jerry Gerber avatar
Oskari Nikkinen · Aug 16, 2025, 04:23 PM
I just ordered more memory so the total will be 64 GB.
That should help.
Arne Biermans:
Oskari Nikkinen:
Have not modified the page file in any way so whatever size is allocated to it by default was in use. I already knew that WBPP is slow/ram hungry but tried it anyway to see if it can work on my machine if only in overnight use. Siril doesn't mind 16GB ram though, and the same dataset stacks in a couple of hours so i use that (SSD write speed limited basically).
WBPP experiencing "Unknown exception" errors during "Measurements"
I have been having issues with Pixinsight WBPP failing to measure a significant number of sub-exposures during the Measurements step with the reason as “Unknown exception. I have posted this issue to the PI forum and this time been told to use FBPP b...
WBPP measurement failures may relate to memory constraints with large subframe batches.
Sep 28, 2025
