BAADER RCC COMA CORRECTOR , BACKFOCUS AND NO FOCUS
14 replies165 views
Jandro.rm avatar
Hi there
I’ve bought this coma corrector, and the documentation says its backfocus is 91,5 mm. I have a SkyWatcher 250 Quattro, and I’ve replaced the focuser with a more robust one. The problem is that in order to reach focus, I have to insert the coma corrector almost entirely into the focuser tube to get focus, which leaves me no place to mount an OAG in addition to the CAA rotator. Does anyone else have the same problem? Any solutions?
Jandro.rm avatar
Hi there
I’ve bought this coma corrector, and the documentation says its backfocus is 91,5 mm. I have a SkyWatcher 250 Quattro, and I’ve replaced the focuser with a more robust one. The problem is that in order to reach focus, I have to insert the coma corrector almost entirely into the focuser tube , which leaves me no place to mount an OAG in addition to the CAA rotator. Does anyone else have the same problem? Any solutions?
Sam Badcock avatar
The backfocus is 91.5mm from the last piece of glass to the camera sensor so you will have heaps of space for an OAG and CAA!!
I have the same scope with an upgraded focused from AliExpress with the Sky Watcher Coma Corrector which has a backfocus requirement of 55mm!!
For me my image train is -
Coma Corrector —> ZWO OAG-L —> ZWO EFW 7x36mm —> ZWO ASI2600mm …….. that gives me the 55mm required back focus in my situation!! All pushed hard up to the focuser tube as well
Not sure what you mean by you can’t have an OAG or CAA??
Jandro.rm avatar
Sam Badcock:
 Hi Sam. Yes i have the same focuser i think ( is the same that Cuiv made a video for). i have 2600 mm pro+efw+CAA and i would like to mount a askar Oag but is not possible for that reaseon. I have the entire coma corrector inside the focuser to get focus
Tobiasz avatar
I think the RCC is not the problem, but the focus point of your newtonian is. I would guess that it is too low and/or your focuser base height is too high and that’s why it can’t focus properly. Your focus point sits somewhere in the focus drawtube. Be careful, the RCC is no barlowed coma corrector, so it does not push out the focus point like some other correctors (Paracorr or TS GPU)
I had a similiar problem with my 8 inch newtonian and the only solution is to get a focuser that is lower in height, so that my setup is closer to the focus point AND has enough headroom for a focus curve.
Most mass produced newtonians have a focus point 130-140mm above the tube which is not enough if you have a rigid focuser installed. Only the generation 2 newtonians from GSO are finally built with a much higher focus point (mine reaches focus ~160mm above the tube).
I use my camera (17,5mm) + filter wheel (20mm) + oag (17,5mm) + Baader heavy duty rotator (15mm) + M54/M48 Adapter (~7mm) with my RCC and still need M48 spacers to reach the correctors backfocus. When I ordered my newtonian I knew I would need a low profile focuser and ordered a custom one to be installed. Now I could even use some hefty reducers like the 0.73x one and still have enough focus travel for a focus curve.
You can also move the primary closer to the secondary to push out the focus point, but then you will need a bigger secondary to prevent additional vignetting. Thats not a workable and fast solution imo.
Edit: A big advantage of a higher focus point is also, that the RCC does not protrude in the light path of the primary. (Less obstruction) This happens with most of the newtonians that are available, too.
Helpful Respectful
Jandro.rm avatar
Tobiasz:
Yes i think that is the problem. By the way what kind of focuser do you use? maybe i can looking for another focuser with low base
Tobiasz avatar
Jandro.rm · Aug 12, 2025, 11:17 AM
Tobiasz:
I think one of the lowest & more affordable focusers on the market is the UNC G2 focuser from TS (UNCN2-G2). I think TS does not produce them themselves so you might find the focuser with the same design from other vendors, too. Depending on the focuser base you need to install on the tube, the focuser can be as low as 50mm. It is REALLY low. But installing an EAF on it sucks, I would recommend 3D printing a flange instead of using the only screw hole it provides.
This focuser with the Generation 2 Newtonians from GSO is a match made in heaven.
Jandro.rm avatar
Tobiasz:
Tobiasz:
It must be check the holes for the focuser. Maybe with other marks don´t fit the skywatcher tube holes
Tobiasz avatar
Jandro.rm · Aug 12, 2025, 11:32 AM
Tobiasz:
Tobiasz:
I think TS offers the corresponding base for it to fit for Skywatcher Newtonians. Just contact and ask them if you can make this focuser work with your newtonian and how. They are very eager to help, even Wolfgang himself (the owner of TS) helped me setting up my new newtonian with this focuser :-)
Jandro.rm avatar
Tobiasz:
Tobiasz:
Tobiasz:
Great, thanks Tobias
Tobiasz avatar
Jandro.rm · Aug 12, 2025, 11:40 AM
Tobiasz:
Tobiasz:
Tobiasz:
You’re welcome and good luck!
Jandro.rm avatar
Sam Badcock:
By the way. Does that scope work with the skywatcher coma corrector? i mean, is the f4 coma corrector or the f5?
Sam Badcock avatar
Sam Badcock:
The scope is the 250/1000 F4 version running the corresponding F4 coma corrector from Sky watcher!! Link below -
https://www.testar.com.au/products/f4-aplanatic-coma-corrector?_pos=1&_psq=Aplan&_ss=e&_v=1.0
The corrector slides all the way down the focuser tube right up to the flange
Also yes same focuser as Cuiv done a video about!! I also just purchased a new spider, primary mirror mask and cover plate from CYCK the same brand as the focuser
Jandro.rm avatar
Sam Badcock:
Sam Badcock:
Ok, i have the same focuser, same spider and cover plate. I have baader mpc mark II coma corrector too but i don´t use with this fast scope (i mounted in my last 200/1000 pds newtonian). =Y2IQFcI want to find something to screw the optical train and remove the blue piece from the focuser, I would gain 12 mm=QmZWSe=DHcWmd =oSioSc=g9WsWb PZPZlf=tw-ta-container tw-nfl
=tw-target-rmn tw-ta-container tw-nfl
=QmZWSe=DHcWmd
Jandro.rm avatar
Sam Badcock:
Sam Badcock:
Problems with my Quattro Skywatcher
Hello, I have this problem with the stars, my equipment is a Quattro 250p with coma corrector. One side is ok, but the other the stars are no uniform.📷 IMG_0728.png
Same equipment with coma corrector; addresses non-uniform stars issue.
Sep 28, 2025
Lunt LS50tha and ASI585MC Pro compatibility and focus issues
Did anyon try to pair up Lunt LS50tha with ASI585MC Pro? I am having focus problem and I am not able to where if I use say ASI174MM mini then all works well. I do believe I have correct backfocus setup for ASI585MC Pro but still. Any idea clue? wheth...
Backfocus setup issues with optical equipment compatibility problems.
Dec 18, 2025
Coma corrector suggestions for SkyWatcher 150PDS
Hello everyone! I was wondering if you have any suggestions for a coma corrector to pair with this telescope (SkyWatcher 150 pds)? I have the Baader mpcc iii which i’m not happy with as it is quite susceptible to tilt, Although, it does a great job i...
Addresses Baader coma corrector backfocus issues with SkyWatcher Newtonian telescope.
Apr 2, 2024
Askar FMA180 Pro focusing issues and coma problems
Hello everyone, I am currently building a wide-angle setup, but I am facing serious issues with my Askar FMA180 Pro. Firstly, there is a problem with focusing: I am unable to reach focus at the manufacturer’s specified 55 mm backfocus distance. Inste...
Discusses coma problems and focusing issues with optical equipment.
Feb 21, 2026
Extender for Skywatcher 250p
Exist any extender for Skywatcher Quattro 250p, for exemple 1.5X?
Author has Quattro 250p with coma corrector; discusses optical accessories and focus.
Jun 29, 2025
