External Focuser Edge 8HD
14 replies350 views
Which focuser?
Single choice poll 17 votes
18% (3 votes)
29% (5 votes)
41% (7 votes)
12% (2 votes)
Dan avatar
Hello
I am finally looking to ditch the zwo eaf on my celestron edge 8HD and go for a separate focuser. This will allow me to lock the mirror down and hopefully have an easier time with hocus focus and mirror flop etc. I currently use the asi 2600mc pro camera and the celestron OAG. I am in between the moonlight CHL focuser and the Esatto 2in LP robotic focuser. Does anyone have any pros or cons? I think I can make both fit with my current setup. I have cross posted to reddit and astrobin to grab the biggest audience.
Thank you!
Keith Mombourquette avatar
I use an Esatto on my Edge 8 and it works perfectly.  I've used it for a year off and on, and it has been trouble free.
Dan avatar
Keith Mombourquette:
Do you ever use it for visual or planetary? One advantage of the moonlight is that you can loosen the clutch and do a manual focus with it. What's your image train? Thanks
No, I use it strictly at f10 for imaging.  I have been using it with an ASI2600mm but recently installed a 585MC as I use it for small targets only, so I usually end up cropping.  I have an EFW and an OAG and a manual Rotator in the train with the 585.  There was no room for the Rotator with the 2600.
Edited to add:  the 585 was installed a few days ago and I have not used it yet.
AstroRBA avatar
If you don't want to sleep just deal with the flop … the 8 inch isn't so bad - just check every hour or so - I'm also running a 14  - new tools can save a lot of grief to be honest
JohnAdastra avatar
I have the Moonlite CHL on my C925 EDGE and it works super. I get perfect v-curves and I get to keep the mirror locked down. Moonlite makes some high quality focusers right here in the USA, with plenty of custom adapters for virtually any backfocus needs, and their ASCOM driver has never failed me even once. Their units can last a lifetime if not seriously abused. I vouch for them 100%.
Well Written Helpful Concise Engaging Supportive
Kartik Atre avatar
I am using Baader Steeltrack focusser with a ZWO EAF. It does require drilling bigger holes into the EAF bracket. I have been using it for a couple of years now. Finally have collected enough money to be able to afford the Esatto LP and have also splurged on Arco rotator at the same time smile
Kartik Atre avatar
Hi Keith,
Can you post how you go with 585 sensor paired with the C8? I am super keen on trying this. But worried I will be oversampled. My mount is good but not a premium one, and generally seeing at my location is terrible.
Kartik
Bill Powers avatar
I’m a big fan of secondary focusers on SCTs. Trying to achieve good and consistent focus with the internal focuser has caused me nothing but trouble. Once I went over to a secondary focuser and was able to lock down the primary mirror, everything worked as it should.
I am currently using a big Feather Touch focuser, FTF3515 with a EAF on it , and it works fine.
Bill
Well Written Concise
Dan avatar
Thank you everyone for your help!!!
Rob Lyons avatar
I have two 8” Edge HDs and have never had mirror flop or any other focus issues. Usually you would only want a third party focuser for serious planetary work, but if that is your goal you are better off spending the money on a bigger scope.
Concise
Dan avatar
Rob Lyons:
Rob Lyons:
its not even about planetary it’s about better v curve in hocus focus. Its never great.
Kartik Atre · Aug 11, 2025, 08:48 AM
Hi Keith,
Kartik
I think over sampling is better then under sampling if you’re interested in resolution. Give it a try…
Area51x avatar
Which moonlight are you using?
JohnAdastra avatar
The CHL is the model number. You can check out their webpage at:
https://focuser.com/
Mine has been working without issue for over 7 years now. No problems with the ASCOM driver either - it always connects. Their webpage is a bit busy, but you can probably call for the best recommendation. They have no shortage of adapters and extensions to get your backfoucus just right. Satisfied customer here.
Aftermarket primary cell/backplate for celestron C11 edge
Does anyone know if it's possible to find primary cell and backplate for C11 edge telescopes? i was wondering if those are compatible with standard SCTs and if it would be possible to buy them as spare parts, maybe from celestron themselves - i w...
Discusses locking mirror down on Celestron Edge scope, directly relevant to upgrade goal.
Dec 17, 2024
Screen shots of my specific Edge HD 8 Collimation issue
Started new thread with more info and pix that are not in this post below: Something's wrong with my Edge HD 8 - AstroBin =–=-==-=–= Hi. I'm struggling with Collimation on Edge 8HD. Have proper back focus (105mm with .7x reducer f...
Discusses Edge 8HD focuser modifications relevant to collimation setup issues.
Sep 20, 2023
Mirror Lock on Edge HD8
When I am using the ZWO EAF with the Edge HD 8", I am assuming I should not lock the primary mirror if I automate focusing. But if the temperature differential between when I start imaging and when I end imaging isn't large, I assume I can k...
Directly addresses external focuser alternative to ZWO EAF on Edge 8HD.
Nov 20, 2023
External focuser on an SCT; What about temperature change induced focal shift and back-focus?
It seems like every serious astro-photographer is putting external focusers on the back of the EdgeHD telescopes and locking the mirrors. I picked up a nice little EdgeHD 8" and a Primaluce Lab Esatto 2" LP focuser and gave it a try myself....
External focuser setup for EdgeHD 8" telescope with mirror locking benefits.
12 days ago
EdgeHD 8 Focus Point Moving
Hello! Curious if anyone can assist here. I have an EdgeHD 8 using a ZWO EAF. Been using it fine for well over 2 years now and everything has been fine until recently. It can’t seem to find focus anymore using Nina/Hocus Focus. What happens is the fo...
Directly relevant; discusses ZWO EAF issues on same telescope model.
22 days ago
