Enrique Ojeda avatar
Hi! Does anyone know why my flats shots have two circles in the center of the image? My equipment is a WO RedCat v3, and in the optical train I have a ZWO filter drawer, a filter wheel, and my ASI 294mm Pro camera. I have the filter drawer because I can't remove it because it's too tight. I've already taken flats with this setup without any problems in the past. My HA master shows these circles, even though my lighting shots don't have them in each individual shot. I'm obtaining my flats with the same software and parameters as always. The flats are calibrated with Darks flats. I would appreciate any suggestions on my problem, please. Thanks! CS!
Flat
Adam Block avatar
Only H-alpha (and perhaps SII)?
That means it is wavelength dependent and likely an interference effect. If so, it *is* in your lights- but it would be hard to see since the sky  brightness is so dark in H-alpha (and red in general). If you see it at all wavelengths, then scattered light from a cylindrical surface (like an adapter).
The coatings on the chip or glass cover may indeed have this pattern. It honestly doesn't look symmetric enough to me to be scattered light.
Helpful Insightful Respectful
Médéric Hébert avatar
I'm no expert, but I think this is a reflection in the light path
ScottF avatar
What are you using to take the flats with? That camera is tricky with light sources. I'd get that filter drawer off there. Try some heat and strap wrench to loosen it.
Adam Block:
Hi Adam! Thanks so much for taking the time to help me. I'm going to take shots with all the filters, both narrowband and wideband, to confirm if the circles appear in all of them. I managed to get my HA master to come out without those two circles in the center by using a library of flats from a year ago. These are flats I took at a different temperature than the current ones and with the camera in a different position. I'm going to try removing the filter drawer and give it a try. CS!
Médéric Hébert:
Hi Médéric. Thank you so much for taking the time to share your feedback. I'll try removing the extra filter drawer and see what happens. CS!
Hi Scott! Thanks so much for your suggestions. I use an iPad as a light source for my flats and haven't had any problems so far. I'm not sure if the filter drawer was already in place when I took my flats without details. My memory is failing me. =). I'm going to follow your suggestion and remove it and try again. CS!
ScottF avatar
Enrique Ojeda:
Be aware if you remove the filter drawer the flats you take later may not work with the images you've taken. Any changes in the optical train affect the flats removal. Are you using the iPad in a well lit room? I had trouble with reflections and light leakage taken that way. I then started taking them in a completely dark room and problem solved. Also, what are your exposure times, a few seconds or very short?
Hi Scott! It’s true what you say....I’ve already had 5 hours of HA with the current setup ='(. I first took the flats outdoors after finishing my session, it was still dark although in the middle of the city. Then I tried as you say: inside a darkroom but the problem continued although I remember I had the laptop screen almost in front of the telescope, I don’t know if the light coming from the laptop screen could be affecting me, I will do the test again but being careful that it doesn’t shine light on the tube. My flats time is 7.75 s. Thank you very much for your support. CS!
Marcelof avatar
That's a flat in Ha (Sii can look very similar) that looks perfectly “normal” for that camera and sensor. The 294 is known for being very finicky to calibrate; you can find more information on CN.
(For example, a quick Google search for “flats asi 294” will bring up images very similar to yours).
The important thing is whether or not it is calibrated correctly.
Hi, Marcelof, thank you very much for your comments. That's right, the 294mm flats are very special, although I only had problems at the beginning. After that, I haven't had any problems until today, when I see circles in the center of the flat, which means they also appear in my final stacked HA master. I'll check online for your suggestion. Best regards! CS!
Respectful Supportive
Enrique Ojeda:
Médéric Hébert:
Instead of removing it, try to look down the tube and look for any shiny surface.
Médéric Hébert:
Hi Médéric! Thanks for your feedback! Fortunately, the problem was solved! The problem was caused by the least expected thing: the light source. I used a 2024 iPad mini for my flats and remembered that the last successful flats I had generated were with a regular iPad. I did remove the filter drawer, but the problem persisted. I tried with a white shirt and the iPad mini on top, and at different brightness levels, but the problem persisted (by the way, only in Ha and SII). Then I tried with the regular iPad, which, because it's so old, I only used it for flats before acquiring the mini, and surprise! I don't really know why my flats came out badly with the iPad mini. But well, in the end, the problem was solved, and I'm calm because it wasn't my setup. Thank you so much for your support and that of everyone who took the time to write to me with their suggestions. CS!
Flat wrong with the new iPad mini  ='(
Flat OK with iPad regular  =)
Helpful Respectful Supportive
Arun H avatar
Enrique Ojeda:
Hi - you should know that displays such as iPads can have significant illumination gradients themselves.
To see this, you can take a set of flats in one orientation, rotate 180 degrees, and take another set. Dividing each by the median and subtracting them will show significant differences. Simply using diffusers like a t-shirt etc. is not adequate to force uniformity over the entire panel/display.
These gradients will complicate the overall gradient that must be removed by ABE, DBE, etc.
It is worthwhile to invest in a flat panel of known uniformity.
Arun H:
Hi Arun! I didn't know that! I really appreciate your comment. I'll look into getting a light source like the one you mentioned. CS!
Francesco Meschia avatar
I had the same experience using iPads for the 294MM camera. I gave myself this explanation of why this happens:
When an iPad shows a white screen, there's actually no white light being emitted… each pixel on the screen is actually a triad of red, green, and blue filters. They're so small that our eye perceives the color as white, when all three filters are equally "lit". But if you think of the spectrum such a light source would have, it's actually not that of a black body radiator (e.g, an incandescent bulb),  but a spectrum with three peaks, corresponding to the three filter colors. The 294MM reacts badly to this, probably because of etaloning in its sensitive surface.
The solution I found is to use a proper white light source, not one composed of three discrete colors. A cheap white LED tracing panel was perfect for me.
Francesco Meschia:
Hi Francesco! Thanks a lot. What you mention is very interesting. I'll definitely do the same thing you did: buy an LED panel. CS!
What could cause this bizarre diffraction spike effect?
I was doing some testing tonight to get a target framed(it’s too windy to actually image tonight), when I noticed in my test shots, that the brights star, Ain, has a very bizarre appearance, with multiple spikes coming off in many directions. I have ...
Diffraction spikes may relate to optical artifacts in flat frames.
Dec 9, 2025
EdgeHD 8 - Flat problem on Green and O3
Hi! I'm having some trouble getting my green and O3 filters to calibrate properly. The image attached is an example of what's happening. The image on the left is without flats, the one on the right used flats. Both images were run through Gra...
Discusses flat generation problems that may relate to calibration artifacts.
Nov 10, 2023
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Similar doughnut/circle artifact issue with ZWO camera and optical train.
Nov 27, 2025
Odd "circle" in imagery when taking photos
Hi all, Starting with: This is a 12” newtonian (1200mm), with a Poseidon-M connected to 50mm (round) filters and an OAG-MAX (with a coma corrector) - 56mm back focus So I’ve been banging my head against a wall trying to figure out what this is… I fir...
Circle artifacts in imagery with similar optical train configuration.
25 days ago
How to Setup the image train
Hi, does anybody has an idea how to connect 1). the Altair Hypercam 26M with the (T2/M42 female) 2). Touptek Filter Drawer (M54 female) I don't understand why the front side/front plate of the Altair Hypercam 26C/M does not have any screw holes. ...
Discusses optical train components and equipment configuration issues similar to yours.
Feb 17, 2025
