D2 experience with fast optics (f/2.2)?
8 replies223 views
Is the d2 working well for you on a Hyperstar/rasa?
Single choice poll 4 votes
75% (3 votes)
0% (0 votes)
25% (1 vote)
Sjors Robroek avatar
Im looking for a sii/oiii dual narrowband filter specifically for a Hyperstar 9.25 v4, and unfortunately options are pretty slim. From the ones available it seems only the askar c2 and d2 are realistic, and the c2 seems to have a very wide bandpass.
From the people using the d2 with a rasa/hyperstar, how has your experience been so far? The typical recommendation for filters seems to be a 10nm bandpass for filters which the d2 doesn’t meet, so I’m wondering how this filter is working out for you before I commit to it.
Elevated_Astro avatar
I used the ZWO Dual band. I have a 9.25 and version 4 paired with an asi533. I believe I have a few examples in my public gallery but thought the pairing worked well.
Sjors Robroek:
*I can't say about the SII/OIII one but the other one isn't doing too well at f/2.8. I suggest you consider the ALP-T Highspeed (as I do).
Sjors Robroek:
I’ve got the L-PARA for H/O but that’s good to know. Likely that the D2 might also not perform that well either.
David Néel avatar
ZWO Dual band is very large (15nm Ha and 35nm OIII). So it's fine for very fast optics.
David Néel:
That’s the H/O though, I’m specifically looking for the S/O dual narrowband.
Georg N. Nyman avatar
I asked the manufacturer of those filters regarding the ability of the D series to work with my RASA and they responded, that they are fine with f /2.2
TiffsAndAstro avatar
Georg N. Nyman:
what is "fine" ?
And how is it possible?
TiffsAndAstro · Aug 31, 2025, 11:34 AM
Georg N. Nyman:
what is "fine" ?
Fine means, that you can use them, their FWHM is large enough to work sufficiently well with f/2.2
How is it possible - if the bandwidth of the filter is not too small, the shift of the central wavelength does not matter or not matter much
Whats your recommendation for a dual narrowband filter on a fast f/2 system?
I run an Asi2600mc OSC on my EdgeHD with an Hyperstar v4 at wonderfully fast f/2. Unfortunately my L-Enhance creates really massive star halos, so I look for a better dual narrowband filter on my f/2 system. Any experiences with L-Extreme F2 or recom...
Seeks dual narrowband filter for fast f/2 optics; directly addresses author's filter concerns.
Nov 21, 2024
Askar C1/C2 vs D1/D2 filter set... which one??
Hello Folks, I have a question about Dual band filters…. I currently shoot OSC, thinking about maybe going to mono, but that won't be very soon… I'm getting ready to pull the trigger on getting the ZWO ASI2600MC-Pro for the larger...
Author uses fast optics (Redcat 51, Hyperstar); relevant filter discussion for similar setup.
Aug 16, 2024
Is it a mistake to combine Ha-oiii 12nm with oiii-Sii 6nm filters?
Hi, everything is in the title. Is it a mistake to combine Ha-oiii 12nm + oiii-Sii 6nm ? I’d like to add an additional filter to my set-up, a dual band oiii-sii. It is difficult in France to find a 12nm dual band in o3-s2, and I received an offer for...
Directly relevant - discusses D2 filter with SII/OIII dual narrowband for fast optics setup.
Oct 18, 2025
2026: best dual-narrowband filters for RASA 11?
There's been a lot of new development in filter tech over the last 2-3 years. I'm looking to buy a RASA11 with a IMX571 camera and am looking for dual-narrowband filters. I'm looking for the tightest bandpass, most transmission, and least...
Discusses dual narrowband filters and halo issues with fast optics systems.
Jan 28, 2026
Tightest highspeed or f/2 dual band OSC filter?
I currently have a 135mm f/2 Samyang and a RASA8 is always a tempting thought at the back of my mind. I have a dual band filter for my 533MC-Pro, an IDAS NBZ-II. The IDAS NBZ-II seemed like the logical solution for me since it’s tighter than my prior...
Discusses narrowband filters for fast optical systems similar to yours.
Aug 27, 2025
