CQ350 - Home Position
1 reply61 views
Ilya avatar
I recently got a Skywatcher CQ350 and have been setting it up for the first time. My previous mount was an Orion Skyview Pro GoTo, which I had to always manually set the home position.
In setting up this mount, I got a little confused because there doesn't seem to be any obvious way to set it to home position during setup. Does anyone have a method to do this?  For reference, I'm using ASIAIR software alongside it. I was under the impression the Go to Home button via ASIAIR would only return the mount back to its original start position prior to launching the app, so as I understand it I need to get it to the Home Position first before I begin to polar align?
Nick Fritz avatar
Yes when you set up your telescope with the Cq350 and asiair, you will want to put the telescope at home position pointing towards Polaris. When you first turn on asiair with everything connected go into the mount tab and select go to home. I like to be watching outside incase it thinks home is at another location. It should do some small slews and realize it’s at home position. If it tries to go somewhere else I would double check your location in the asiair. I would then power down and restart everything until go to home takes the mount to home position. From there you can select the PA tab and do a polar alignment. Hopefully this helps.
Polar Alignment question
How many times before I start imaging, should I run the polar alignment? I usually do once. I try to get it under 1'. I will then notice my guiding is off, so I will move my mount to the home position, run the 3PPA again, only to see it is off. W...
Discusses home position setup relevant to polar alignment procedures.
Feb 27, 2025
How to change the star used for alignment fine tuning?
At the end of the PoleMaster alignment routine there’s a fine tuning stage where you hit a button to start monitoring and then fine tune alignment via the green and red (pole and axis) symbols. Is there any way to change or control which reference st...
PoleMaster alignment routine; discusses mount setup and reference star selection issues.
Jan 11, 2024
CEM40EC Handset: "Unknown Position" - What does it mean?
I may be a little paranoid after suffering a tripod collision due to a known (but not to me) software compatibility issue between the ASIAIR and the CEM40 series of mounts. But I just noticed that as soon as I begin to slew after setting the mount ze...
CEM40EC mount home position issue similar to your Skywatcher CQ350 setup problem.
Jan 28, 2026
Park position doesn’t stick.
I use TSX as my database source when using N.I.N.A. I open TSX, put in the target and hit Find. I then minimize TSX and load N.I.N.A. In which program do I establish the home position? I don’t seem to be able to establish a permanent position. It see...
Home position setup issues with GoTo mounts directly relevant to author's problem.
Apr 25, 2024
A Few iOptron HAE43 setup questions
I just started setting up a travel rig with a newly purchased iOptron HAE43C mount. It connected immediately to NINA, but I have a few housekeeping questions. BTW- no manual came with it. So, I had to download but it still did not address my question...
iOptron mount setup questions may provide relevant GoTo mount configuration insights.
24 days ago
