Mossyback avatar
I decided to expand my astrophotography into narrowband imaging. My budget has allowed me to get three 5nm filters. Last night I tried out the H-Alpha filter using N.I.N.A. and immediately ran into a couple of problems.
Autofocus is not working well. I’m using Hocus Focus. What adjustments should I make to it as it works well with LRGB?
ASTAP also gave my problems so I’m assuming this is related to the exposure times used by both these programs.
What settings should I be using?
Hank
You have the right idea, Ha cuts out a lot of light from the stars as you've probably noticed. You need to increase the exposure time for both solving and focus. That assumes you're not using a filter wheel. If you are, NINA can switch to the L filter for both tasks so no changes would be needed. On way or the other you'll need to figure out the right values for your setup. I generally use 15 sec. for solving and 5 sec. for focus but your mileage may vary…
Sam Badcock avatar
I could not for the life of me get ASTAP to work with my SHO and LRGB filters as it just wanted to debayer them everytime despite all setting relating to this being turned off!!
For a plate solver I use PlateSolve3.8 from PlaneWave!! It’s free and works bloody well and only a tiny fraction slower than ASTAP so maybe give that one a whirl
Now for focus I use Hocus Focus as well and have no troubles with focusing with NB filters!! Are you sure you have enough exposure time and gain for it to do its thing?? Cuiv has a video on the tube where he shows you how to setup a mini pc with NINA etc etc and there’s a section in there where he shows you the settings he uses for focusing with an EAF!! I’ve copied these and have no troubles, I also run my focus exposures at 2 or 3 seconds from memory with 0 offset (haven’t calculated this yet)
When I get home I can copy my focus settings here if you would like and I’ll try find the link for PlateSolve3.8 for ya shortly
Sam Badcock:
+1 on PlateSolve 3, I use that as my primary solver and ASTAP as the backup.
Mossyback avatar
Thanks folks. This is very helpful.
Hank
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
NINA autofocus issues with narrowband filters similar to your H-Alpha problem.
Nov 25, 2025
PhD2 timeout issues after filter changes with N.I.N.A. and SB MtY mount
I’ve finally got PhD2 working reasonably well but with one exception and I’m not sure how to fix it. Guiding appears quite good but the PhD2 program sometimes “times out”. Is there a setting that I can adjust to remedy this situation? I’m assuming th...
NINA filter changes may affect autofocus settings like your narrowband setup.
Sep 28, 2025
DSLR Mod: Installing a Narrowband Filter Directly on the Sensor (Results Included)
Hello everyone! I wanted to share a super fun mod I did on my DSLR in case anyone is interested or has feedback — or if someone out there has tried something similar! I recently sent my main astro rig to a remote observatory, and honestly… I started ...
Narrowband filter implementation on sensors relevant to your narrowband imaging expansion.
Dec 1, 2025
