AstroDarks avatar
Looking  for recommendations on EAF settings for my Edge HD 8" with ASI Air. The autofocus curve I see is pretty shallow. I am currently using an AF step size  of 50. ( Backlash 0, min size 10, max size 100 of that matters)
The images turn out soft. See below. This is M27 at 2000mm FL F10.
Also my guiding is great. Mostly below 0.4 arc sec. Yet, I see the stars very slightly elongated. I ran this image through ASTAP and I saw no tilt (5%). Is this bad collimation? The scope for stored for 2-3 months and I did not collimate before imaging last night. It was in perfect collimation at the time of storage.
Any help will be greatly appreciated. Thanks!
Rémi avatar
Hi, it look like a range out/in off your Backfocus...do you use reducer ?
Ancient.Photon avatar
I recently switched my EAF from my refractor to EdgeHD8. I still have the same setting that I used with my refractor. my step size (slow) is 10. 50 seems little large movement for me. I didn.t change my backlash (its still at 90) . Maybe reduce the AF step size to 5 or 10 and start what a backlash of 50 to see if you get tighter stars.
DARRELL DUBOSE avatar
Can’t help with your ASI settings as I don’t have one. I suggest before you start fiddling with back focus and ASI settings, you get a tri-bahtinov mask and check your focus and collimation after you run the autofocus routine.  If your collimation and center focus is good, then start looking for other issues.
Darrell
Much the same as Darrell suggested. Find out first what the best focus is in terms of FWHM or whatever measurement your system uses. Then run your autofocus and see if it matches it but in terms of star size and visual appearance. The only difference is I wouldn't bother with a mask, the human eye is very sensitive to small changes like this. Zoom way into a not super bright star and at high screen magnification. Also, don't forget that every optical system is going the have a zone of critical focus where tiny changes won't have any effect. That's the great thing and auto-focusing as why it works so well. Even though you might make 2 or 3 samples in that zone, it's the overall curve that pinpoints the best point right in the middle of the CFZ. Another indication that you're close is the number of detected stars in your image. When you are slightly off the very faintest stars will pretty much disappear so that can also be a good check. Seeing star images that are not round has nothing to do with focus.
Terry Doran avatar
SCTs need much larger auto focus step sizes.  I have mine set at 90 for my EdgeHD8.  When you have a shallow focus curve you want to increase step size not decrease it.  To be clear, this is the step size in the auto focus settings and has nothing to do with the fine and course settings.  Those are for manual focusing and have nothing to do with auto focus.  It’s not unheard of to see people using step sizes of 100 or more with SCT scopes.
Well written Helpful Insightful Concise
AstroDarks avatar
I have now set up the autofocus step size to be 100 and backlash of 50
I see the attached curve with final star size of "5.9" at focus. What numbers does everyone see here when you focus? Even when using slow movements of 10, I see the focuser move. So backlash is ideally 0 but I set it to 50. I have also made sure that the focuser final movement in in counter clockwise direction when dialing focus. 📷 1000215585.jpg1000215585.jpg
PS: This screenshot shows focusing at F10 (no reducer).📷 1000215607.jpg1000215607.jpg
AstroDarks avatar
The backlash setting is meant for manual focus and not autofocus, correct?
Setting Up ZWO EAF with the Edge 8" for the First Time
I have some questions: 1. What constitutes 0 position? Does this mean when the scope is in focus? 2. The AF exposure time defaults to 2". Is there any situation in which this should be changed? 3. What does "Reverse" do? 4. I don't...
Direct match - EAF settings recommendations for Edge HD with ASIAir
Aug 11, 2023
Do you know what is wrong with my image capture?
I've been troubleshooting my imaging on the Lobster Claw Nebula over a few sessions now. I have an artifact that I'm stumped as the the problem. 1. Collimation has been verified to be good 2. Tilt has been verified to be little or none 3. Foc...
Author troubleshooting soft images; similar focus/collimation diagnostic problem.
Aug 15, 2025
EdgeHD 8 Focus Point Moving
Hello! Curious if anyone can assist here. I have an EdgeHD 8 using a ZWO EAF. Been using it fine for well over 2 years now and everything has been fine until recently. It can’t seem to find focus anymore using Nina/Hocus Focus. What happens is the fo...
Author has EdgeHD 8 with EAF; directly relevant equipment and focus issues.
Mar 15, 2026
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Author experiencing star elongation; fan vibration could cause similar symptoms.
Nov 18, 2025
