Powering the EQM-35 Pro
5 replies149 views
Eric Gagne avatar
That mount comes with  12V car type plug to power it through the hand controller, I don't like those car plugs.   I know it's probably a stupid question but I am dumb when it comes to everything about electricity.
Is this just another 12V DC connection ?  Can I use any 12V adapter like the ZWO or Pegasus I have on a shelf catching dust ?
John Esser avatar
I bought some no-name 12V adapter, and it works great. The plug dimensions just have to fit.
Sort of, make sure the plug fits and that the adapter can deliver the min. amount of amps and of course, it's DC not AC.
Paul Evans avatar
I had this problem when I first got my EQM-35 Pro in 2021. I contacted Sky-Watcher customer service, and they recommended the Celestron 5 amp 12 volt adapter. (Sky-Watcher and Celestron are part of the same company as I understand it.) The model number is 18780.  I've used it for years, both with the EQM-35 Pro and the HEQ-5, and it works great.
If, as John said, the plug dimensions fit, your ZWO or Pegasus adapters should work, but you have to use a 5 amp adapter with this mount.
Well Written Helpful Concise
Eric Gagne avatar
Thank you.  The ZWO is 12v 5A, that’s perfect for the task.
AndreaMarini avatar
Any power supplier with 12v and 5 amps works fine. I took one on Amazon if I remember correctly. It should be stable
Help! All of a sudden my brand new Sky-Watcher EQM-35 mount doesn't turn
I got the mount today and when I first tested it inside everything was perfectly fine, I could manually control the motors and automatically. But then I moved the mount outside to test it further and when i plugged the power supply in again, turned i...
Power supply issues may affect motor performance outdoors like described.
Sep 4, 2023
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Dew heaters use 12V power; relevant to understanding 12V adapter compatibility.
Nov 28, 2025
Power Station for occasional use
Hello all, I know this topic comes up a lot, but i’m trying to consolidate my research with a few opinions of those who might be in the same boat as me. My normal set up at the moment is a SA GTi mount, with a REDCAT 51, ASI533MC Pro, filter wheel, E...
Power station discussion likely covers 12V adapter options and power solutions.
Aug 31, 2025
Fornax LighTrack II setup advice
Hello all, I bought a Fornax LighTrack II used for about 370€. It's just the tracking arm so that gave me room to improvise how I would like to have my rig set up and I've come to this final configuration. However, I am very open to any suggestions. ...
LighTrack II mount setup may address 12V power connection questions.
Jan 10, 2026
