Luminance Noise Pattern / WBPP Errors
15 replies462 views
Jack Groves avatar
The past few months I've been noticing a pattern in my luminance data that I'm hoping the forum here might be able to help me diagnose. The pattern looks to me like walking noise, however I've been using the same dithering settings for over a year with no issues until recently and so I'm doubting that walking noise is the culprit. This pattern also doesn't show up in any of my R,G,B or narrowband data.
The examples I have here are master lights from 600s sub frames. My scope is a Wiliam Optics FLT91 and the camera is a 2600mm. I'm dithering at 5 pixels every 5 frames. I'm shooting from the dark skies at Starfront Observatories and the data was all taken on moonless nights. You'll have to ignore the pinched optics from my telescope as that's another issue entirely!
I've processed the data using both PixInsight and APP but have had the same results with both. I've also tried to process with just flats and bias (and no darks) but the pattern still shows. When I'm running WBPP in PixInsight I'm also getting the following error message when the image is going through the astrometric solution process:
I'm at a loss for what this could be and I'm open to any/all suggestions. Thanks!
Well written Engaging
Jerry Gerber avatar
Hi Jack,
I'm not seeing anything but the normal noise that occurs in any integrated master light before processing with Noise-X.
I must be misunderstanding the issue you're having.
Are you doing anything different lately from how you've been pre-processing or processing before the problem you're having occurred?
Jerry
Well written Respectful Concise
These are very aggressive stretches, especially the first one. I agree with Jerry, things get pretty messy when you dig that deep. Is this something that's suddenly changed and wasn't there before?
Well written
What is your image scale? I guess it's too high for the telescope you're using. That is just shot noise.
danieldh206 avatar
With 600-second subs, suggest you dither after every image. Dithering is one of the most effective ways to reduce noise in a stacked image.
Well written Concise
Jack Groves avatar
*** Hi Andrea, I’m at 1.44” so it should be well sampled. I see your train of thought but it doesn’t explain why my prior images were fine but this issue is now happening .  ***
Just to get a grasp of the magnitude of the issue are those images stacks of how many seconds/minutes/hours? As a means of comparison I'm shooting with a 6" at 1.63"/px and still get shot noise even with 10 hours' worth of imaging time.
I do not mean to be pessimistic (and crossing fingers it won't be anything like this) but the only time I had similar issues (increased noise/fixed pattern developing when there was none before)  is before my IMX533 based camera died on me.
Jack Groves avatar
The shot with the M58 crop is 41 hours of integration, and NGC 1333 is about 8 hours iirc. There’s definitely still some shot noise, but my main issue is the fixed pattern noise that I’m seeing.
also - re your point above about the camera dying, I’m hoping that’s not the case with my IMX571! I’ll add that the cooler wasn’t running particularly hard when I imaged the data
I'd check your shooting parameters, signally gain settings. If RANSAC can't find a fix is because the image is exceedingly shallow as when you run at very high gain settings. This said with 40 hours of integration from a prime dark site you shouldn't see any  of the fixed pattern noise but to be sure I'd have to look at a single raw shot.
Adam Block avatar
How old are your dark frames? More than 3 months?
-adam
Jack Groves avatar
Adam Block:
-adam
Hi Adam - the darks were just under a month old when I captured the data.
Adam Block avatar
Jack Groves:
Adam Block:
-adam
This effect tends to happen when there is a small mismatch between darks and lights (for whatever reason). Warm/Hot pixels do not cleanly subtract and you have "correlated noise" fixed pattern effect. This is been in issue in the past for some remote astro-data companies. It is hard to keep up with updating calibration data for the best fit of the current sensor characteristics- especially when running a pipeline.
Please see the attached picture... in addition to giving you my opinion I will also show an example from my experience and suggest a solution.- hope you agree this is similar. The red lines indicate the artifact which filled the masters (and more easily seen in the noisiest areas). It is quite subtle. What fixed the issue was new contemporaneous dark frames.
Jack Groves avatar
Adam Block:
Jack Groves:
Adam Block:
-adam
Hi Adam - this is absolutely the type of noise pattern I’m seeing! I’ll attempt to calibrate with a new set of matching darks and see if there is any improvement.
As far as the RANSAC error goes is that something that could be related or it is likely another issue altogether?
Adam Block avatar
Different issue entirely.
-adam
Nedim Bevrnja avatar
Hi Jack,
I took a closer look at the two images and I recognize this effect from my own experience when dithering wasn’t set up properly. Depending on your exposure time, the dithering frequency should be adjusted accordingly. Another important factor is how big the pixel shift actually is.
Right now I’m shooting with 180s and 240s exposures and I dither every 5 frames. The pixel shift is around 10 pixels, if I remember correctly.
Nedim
Well written Helpful
Weird noise pattern in several sub frames
I was going through some of my sub frames from the other night and came across several subs that contained weird interference noise of some sort. The camera was capturing all night long. At 2:30AM about half way through the session, there were 7 sub ...
Luminance noise patterns directly relevant to diagnosing interference noise in data.
Sep 26, 2023
Dithering Changed
Was wondering if anyone else that uses the ZWO AsiAir plus had experienced any issues with their dithering settings after the last update. On my latest image I am experiencing some walking noise, not much but its there. In looking at my guiding logs ...
Dithering settings changed recently; author suspects dithering despite consistent settings.
Jan 6, 2026
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Camera artifact patterns in luminance data; similar diagnostic troubleshooting approach needed.
Nov 27, 2025
Dithering in RA Only
Hi all, I imaged the Running Chicken Nebula last night and my stack is plagued with walking noise. Due to this (and previous occasions of walking noise), I have been thinking about dithering, but as I own a Sky-Watcher Star Adventurer I can only dith...
Luminance noise pattern may relate to walking noise issues in stacked images.
Jul 31, 2023
Bias noise not calibrating out
Hi all, I am dealing with a vertical banding issue on my integrated images. I am getting vertical banding that seems to correspond with a noise pattern seen in the master bias frame. It was not present on one night of shoothing and then present in on...
Luminance Noise Pattern / WBPP Errors — Addresses noise patterns in data requiring diagnosis.
Jan 22, 2024
