Just to give an update on my own post earlier - belt tensioning was a bit of a red herring, I guess I didn’t point my scope at the problematic portion of the sky and assumed issue is fixed. It was not. I took the entire mount apart to troubleshoot. It is clear that the spike happens every 5 minutes. By sitting down with a stop-watch I realized it cannot be the belt and it cannot be the large gear because they make maybe just ¼ of revolution in this 5 minute period. The only thing that makes a full revolution in 5 minutes is the RA motor/shaft and the small gear that moves the belt so I paid much more attention to this section.
I took the DC brake apart and made some interesting discoveries. The front cover or caliper has a rough finish and it is clearly dragging
I can’t exactly tell whether this is happening because the brake itself is poorly made or is it because the brake is somehow not aligned with the shaft properly but long story short I decided to remove it and continue session without it
Before the mod:
After:
For those of you interested - no the scope will not crash into a tripod if power disconnects. My setup is very close to the payload limit of 8 kg and even if I leave the RA axis in 90’ angle and disconnect the power, the motor has enough friction to hold it, you have to push RA axis quite hard to move it so I’m happy to live without this brake. Of course I didn’t want to be destructive and cut the brake simply off, so I left it in a disassembled state unscrewing as much bits from it as I can and just hiding the magnet in the housing
As you can see that the guiding before meridian is pretty bad except for DEC=60 and 45 degrees (but for 45 degrees, there are periods of bad guiding. See plots below). After meridian, the guiding is pretty good. Below are the guiding graphs of the 10 sessions. They are shown in the same scale for comparison.
I then run a long guiding session at DEC=15 degrees from 2 hours before meridian to 2.7 hours after meridian. Here is the result.
