Bill Meador avatar
Does anyone know what settings to use for the sensor when setting up the Seestar S30 Telescope field of view for Stellarium?  I've added the scope itself and focal length/aperture, but do not know where to find or calculate the sensor settings for X-Resolution, Y-Resolution, Chip Width, and Chip Height.  Assistance greatly appreciated!
Bill
Raúl Sebastián Morales avatar
Tipo de sensor
Sensor CMOS (Sony IMX662)
Tamaño de chip (mm)
5,6 x 3,1
Megapíxel
2,1
Tamaño de píxel
2,9
Resolución foto
1920 x 1080
Muestreo digital (Bit)
12
Enfriamiento
no
Interfaces
USB 3.0
Conexión (lado de telescopio)
T2 (M42 x 0,75)
Cámara a color
Temperatura de operación
-5° bis +45°
Tiempo de exposición máximo (min)
33,3
Tiempo de exposición mínimo
32
Imágenes por segundo
107 (A resolución máxima)
Ruido de lectura
0,8
Full Well Capacity
38,2
Distancia focal de brida (mm)
12,5
Fuente de alimentación
5 (via USB)
Diagonal del chip (mm)
6,4Equipo
Bill Meador avatar
Thanks………………will plug that info in and see if it matches what I see on the app………….so far nothing has looked right, but then I have been comparing with edited images that were probably cropped, so gonna find the time to fire up the instruments and compare Stellarium view to Seestar app view.
Clear Skies!
Puedes usar también la web astronomy tolls,un saludo.
How do I choose a camera sensor/barlow combination that will approximate the view given by a particular eyepiece?
I know that, for example, a 9mm eyepiece has a focal length of 9mm. Dividing a telescopes focal length by the focal length of an eyepiece used gives approximate magnification. We don’t think in terms of magnification when using a camera sensor instea...
Explains sensor/optics relationship relevant to calculating telescope field of view parameters.
Dec 31, 2025
