Anyone have an idea of where I can get large plastic head screws?
10 replies261 views
ScottF avatar
I bought a used paramount MyT tri pier for use with my mounts using a 3/8" bolt. I cut an aluminum plate and fastened it using bolts and connectors for spacers, but I would rather have bolts that I can tighten without needing a wrench. Bolts with a large plastic knob or star shape would allow hand tightening and not require a wrench. The only ones I can find are too short or the wrong thread pitch. The pier uses a 3/8" and 24 thread pitch which is not popular. The bolt needs to be 4" long. Does anyone have suggestions of where to find such a thing, or will I need to make my own?
I've included a picture of the setup.
Yannis Doukakis avatar
3D print them!
ScottF avatar
Yannis Doukakis:
3D print them!
I would love to , but I don't have a 3D printer, although I am thinking seriously of buying one once I research them.
Ted avatar
Hi Scott, perhaps here? I'v used them before: https://www.jwwinco.com/en-us/
Another option: https://www.mcmaster.com
Ted
ScottF avatar
Ted
Thanks, I tried McMaster before, but they didn't have anything long enough or the correct thread pitch. The other link looks promising.
Yannis Doukakis:
3D print them!
I can send you designs for smaller screw heads in Fusion 360 which you can scale up to your size. Then you can order them to JLCPCB to be printed in ABS or even metal!
Bob Lockwood avatar
You can build your own from McMaster Carr. Just get the knob you want, threaded, (no post) and get the all-thread you need and put them together.
McMaster-Carr
all thread rods | McMaster-Carr
ScottF avatar
Bob Lockwood:
McMaster-Carr
Thank you! I found what I need, although it took a bit of searching as the 24 count thread pitch is not very common compared to 16.
John Hayes avatar
ScottF avatar
ScottF avatar
Bob Lockwood:
McMaster-Carr
I got exactly what I needed from them. They are fantastic to deal with and I received my parts in just a couple of days. Thanks!
Altitude Axis Clamp on HAE43B‑EC — Needs Extreme Tightening
I’ve been troubleshooting polar alignment drift on my iOptron HAE43B‑EC and may have found the culprit. The altitude axis clamp requires very high torque to hold alignment — I have to use the included wrench to really crank it down, otherwise there’s...
Discusses clamp tightening issues on astronomical mounts; relevant to hand-tightening bolt problem.
Nov 27, 2025
Ioptron Tri-Pier with Strain Wave Mounts
Possible Tri-Pier Solution for Strain Wave Mounts. -I had a problem with the Tri-Pier flexing under unbalanced loads previously discussed with some other members here. It turned out to be the top plate moving in the pier. It was flexing up a noticeab...
Author seeks fastening solutions for tri-pier top plate mounting issues.
Sep 27, 2023
