What should poor Menart do next?
Multiple choice poll 6 votes
33% (2 votes)
17% (1 vote)
17% (1 vote)
0% (0 votes)
33% (2 votes)
0% (0 votes)
Jure Menart avatar
Hi all
After few days of Ha & Oiii acquisitions I finally checked my result. And of course as always I found an issue on integrated images I have quite nasty scattered light in right top corner. Of course it's on both images so I don't have good reference to use @Adam Block trick to replace part of the image
I couldn't find the guilty star (I assume it's a star and not reflections from nearby light sources - as my previous project was not far away on the sky and I didn't see this issue at all).
Lucky my acquisition is not done yet (I think I am somewhere in the 50% of acquisition), so I see few options:
  1. At the end simply use CloneStamp and remove it carefully and leave acquisitions as they are now
  2. Rotate camera for 180° - I might have scattered light on both corners but also some good reference to fix it with replacement (it's corner of the image and not the main focus of the image, so I could get away with slightly higher noise I think), bad thing is I double the issue in both corners
  3. Do the right thing and investigate why this reflection and fix it - I will be honest, the nights are so short, I'd like to avoid doing this and just continue with my calibrated setup through this project The lazy way I know
  4. Slightly change position / rotation and try to get rid of scatter light and not loose too much final FOV - problem I see with this is that the scattered light is not visible in single subs, so I am not sure if I wouldn't just make it worse and loose final FOV
  5. Other processing or acquisition ideas?
  6. Throw subs away and get a real hobby
Ha and Oiii integrated images (GraXpert quick background extraction, StarXTerminator & STF applied for easier visibility of the issue):
Oscar H. avatar
that little thing in the corner?
just crop like this when you're done getting all the data:
it'll still look great.
Jure Menart avatar
Oscar H.:
Hi Oscar
I intentionally left out cropping which of course it's valid solution But I agree I might do that at the end, so in this case it's better to just continue with the same acquisitions.
I want to see some ideas of fixing this issues as it's often the problem with our pictures.
The practical thing to do is to wait for the crossing of the meridian and the thing will likely disappear (crossing fingers here). You would then have a clean (at least locally) image to use to clone-stamp the reflection away.
Anne-Maree McComb avatar
I have the same problem with my reflector.  I'm wondering why crossing the meridian would resolve it?  Wouldn't it just appear in the diagonally opposite corner?
Well written Engaging
Jure Menart avatar
Wouldn't that be basically.the same as 180 degree rotation? Unfortunately at this moment meridian flip happens after the astronomical darkness.
Yes it would appear at opposite corner which means real signal would be stronger then scattered light. And even if not one could use only integration without scattered light for each corner.
Jure Menart:
Then you're all good. Or you meant after the astronomical darkness is over? You still have about an hour of nautical darkness which is fine with NB imagining.
Anne-Maree McComb:
Yes, that is exactly. You can either average them or, better, clone stamp the affected areas with the image that isn't affected.
Steve avatar
Jure Menart:
Is nautical darkness OK for OIII data?  I’ve always done H-alpha during that period.
Steve:
*Yes, but not as good as during the astronomical night.
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Addresses gradient/scattered light issues in integrated astronomical images.
Mar 5, 2026
Weird Amp Glow-like Artifacts
Hi, I just noticed some artifacts in one of my images: I just did a quick edit, to bring out the problem more. That's the stacked image of 20x300s subs, but it's in every sub. It looks like Amp Glow to me, but I have the ASI533MM Pro, which s...
Scattered light issues relevant to author's artifact troubleshooting investigation.
Jul 8, 2023
Lens Flare Artifacts in Narrowband Images
Hi everyone, I've noticed a few of my narrowband images have recently had some horrible lens flare when capturing at 300s (at least that's what I think it is). I thought it was a flats issue but after much experimentation, I've found flat...
Scattered light artifacts in stacked images similar to author's flare.
Dec 28, 2023
QHY268m - strange ghosting artifact in recent data
Hi, hoping to get some feedback on this issue. I'v been on a forced break for a couple of months (clouds, short nights) and have just fired up the rig again. However, I am seeing a previously unseen issue in my data (HA, OIII and SII all show thi...
Scattered light issues can manifest as ghosting artifacts in calibrated images.
Sep 7, 2023
Oiii emission near the Flaming Star Nebula
Hi, Yesterday I finished processing my latest image of the Flaming Star and Tadpoles nebulae. I used the Optolong L-eNhance filter and for RGB stars just a UV/IR Cut. I then made a HOO palette (H=R, O=(G+B)/2) and processed my image with my usual wor...
Troubleshooting artifacts in narrowband image integration and processing.
Jan 10, 2024
