Cannot connect to StellaVita while it’s shooting.
9 replies173 views
Eric Gagne avatar
I know there’s only a few users yet but I’m wondering if I’m the only one with this issue.
If I lose connection while it’s shooting I can’t reconnect.  There was one occasion where it reconnected while it was auto focusing but if it’s shooting it won’t.  There’s a message that it’s downloading data from the main camera, after a while it seems to connect but then it disconnects again right away.
I wrote Touptek about it but like I said, wondering if others have the same issue.
Kaoru_Requiem avatar
Sorry, I don’t have this issue.
Stacey Baczkowski avatar
I have the same issue. I have tried using the Stella Vita connection and with the wireless bridge with the WiFi dongle.  It doesn’t seem to matter how I connect, I can’t reconnect and I loose the connection a lot. I am using an iPhone to control the SV. Have you found a solution?
I think I figured out what the problem was.  I was running the QHYMinicam8 and had powered it through one of the ports on the SV.  The SV did not consistently deliver sufficient power and the camera would stop working.  Then, when the SV tried to reconnect, it could not detect the camera.  I tried a dedicated power source for the camera and have not had the issue happen again.
Well Written Helpful Insightful Concise Supportive
Eric Gagne avatar
I always had the minicam powered using the 12v adapter that came with it.
I forgot to come back here and explain.  Touptek told me it’s an issue in the qhyccd sdk.  Apparently on some models it does not allow connection while the sensor is integrating.
At some point during a session it will loose connection because it times out on querying the camera for info.
Then it reconnects, tries to load data from the camera, times out again, disconnects again and repeats that every 5 minutes or so.
You can reproduce this at anytime even inside with a wired connection to your router.  Just start shooting a few darks, quit the SV app on your mobile device and try getting back in.  I’m guessing it won’t , just like me.
Eric Gagne avatar
Touptek released an update today that is supposed to fix this.  I will report back tomorrow.
** edited to correct typos
Thanks for the update. I’ve been testing various things to try and work around it. I can easily reproduce the problem. If I keep my phone on all the time, it seems to work,  but I don’t quite trust it.  I’ll get the download as well.
Eric Gagne avatar
The problem appears to be fixed.  I let my iPad go to sleep a few times last night and the app reconnected each time.
I downloaded the update and it worked. I disconnected and reconnected a few times last night. Thanks for the help.
Eric Gagne avatar
Stacey Baczkowski:
Glad it’s working for you too.
Two Stellavita on the same network
I got a second Stellavita for my second rig (NINA sect members if you’re getting ready to reply with a “switch to Nina” answer just keep walking). I configured them both in bridge mode on my home network. Unfortunately the app automatically connects ...
Multiple StellaVita units; author mentions StellaVita connectivity issues.
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
Similar disconnection problems with camera equipment during operation.
Nov 25, 2025
ToupTek is getting closer to breaking the monopoly (StellaVita 2.0))
Hello AB!! About a year ago, I had early hands-on time with what was then called Astro Station. I made a YouTube video and a few forum posts about it here and there… At that point, it was obvious what they were trying to build: an open, brand-agnosti...
Discusses StellaVita 2.0 features and improvements relevant to author's device.
Feb 9, 2026
Looking for Camera and Filter Wheel Recommendations
The biggest problems I have running NINA at home or at a remote observatory is 1) camera connectivity to NINA, and 2) the filter wheel getting stuck on one filter. When running at the remote site, I always have to make sure that the camera cools and ...
Camera connectivity issues to control software similar to author's problem.
Oct 31, 2025
