iOptron Skyhunter and ASIAir support
12 replies191 views
Ajit Sharma avatar
I've an iOptron Skyhunter with iPolar, I am planning to get ZWO ASIAir Mini computer to control my set up but unable to get any resource saying if it is compatible with the mount or not. I've checked ZWO support website and this mount is not listed there, all I can find from CN thread that ZWO ASIAir Plus is compatible with this mount using USB cable, not Wifi. Could you please share if this is possible and how do I connect the mount with the ASIAir Mini (not Plus version).
iOptron support told me that "The SkyHunter can be controlled via USB connection using the MiniUSB (2.0) port on the mount.
changchun JI avatar
应该可以的,在盒子赤道仪选项中多试几个艾顿的赤道仪,哪个能让赤道仪动就用哪个,我的就是这样的
Ajit Sharma avatar
changchun JI:
The couldynights forum on this says otherwise, the users are struggling hard to use ASIAir Plus with this mount and even iOptron support is unable to confirm it if it will work and I guess no one tried ASIAir Mini on this mount, hence the confusion.
Gustav Lundby avatar
My experience with IOptron GEM45 and Skyhunter using Stellarmate, is that all newer versions of IOptron mounts works with all their drivers. That is the drivers are universal. If you see one IOpton driver in AsiAir, try that one.
randcpoll avatar
Yes, you can use the ASIAir mini with the StarHunter. You can even use the ASIAir Pro with it now that the firmware has been updated. You can use either the wifi or the cable.
However, I found with my setup that there is electrical noise on the StarHunter, probably from the motors, that interferes with operation of the ASIAir. I found that by using a long cable (about 12ft in my case) and just coiling it up everything works fine. This may just be a quirk with my system, but it does all work.
Ajit Sharma avatar
My query was about iOptron Skyhunter, by "Starhunter" if you're referring to the same Skyhunter then I guess that covers my question since I am unable to find any resources and neither can the support from iOptron can confirm it. I guess I'll buy it and check, hopefully I'll be able to find a workaround in case there are issues with WiFi or USB connectivity.
I'll update the thread once I've Air Mini and check if it works.
Thanks for your input.
randcpoll avatar
Oops, you are correct, Skyhunter, not Starhunter!
Sean Shifflette avatar
It was a coincidence that I saw this post. I was given an ASIAir for Christmas, and I've been attempting to use it with my iOptron SkyHunter. The ASIAir works with the GoTo feature and taking images with my ASI183MC Pro. However, it doesn't do so well with the Guiding feature. I've attempted several times to get my ASIAir to guide my SkyHunter, but it just wouldn't do it.
Well Written Concise
Ajit Sharma avatar
@Sean Shifflette are you using ZWO guide cam for your rig? As far as I know ASI Air doesn't support any other brand cameras except ZWO, you can get in touch with ZWO/iOptron support to check if guiding will work and update it for others. You may find the following CN article helpful;
https://www.cloudynights.com/topic/829269-new-mount-ioptron-skyhunter/page-15
Are you using ASI Air Plus or Mini?
Timo Jarvilehto avatar
I have used quite a while skyhunter with asiair mini and wifi works well. No problems with guiding either, However, now suddenly DEC motor stopped, and I don’t know what to do. Has anybody else had the same problem?
Timo Jarvilehto · Sep 26, 2025, 06:19 AM
Mine too stopped working in RA. I bought new RA engine with “clockwork” from iOptron and replaced it. Probably burned out after mount being “strangeled” by rotating several turns. Forgot to turn it off. (Tracking using internal battery!)
Ajit Sharma avatar
Are you able to identify why the DEC stopped working all of a sudden, Gustav seems to let it run which caused the issue. Haven't heard anything like this from any other users? How long have you been using this before stuck in the backlash?
You can send an email to iOptron support with all details and photos, they are very responsive.
The DEC motor suddenly stopped running when I was about to start photographing. The RA motor works all right. I have used the mount for less than a year, but quite intensively.
ASIair Plus with Sony a7II?
I was wondering if the ASIair Plus is compatible with the Sony a7II mirrorless camera. I am hoping to use it to automate my imaging process and start to auto guide my setup. Any help is appreciated.
ASIAir Plus compatibility question with different camera/mount combinations.
Oct 15, 2023
Controlling a UMi 17X: MiniPC or StellarMate/StellaVita/ASIAIR
Hi there! I’m decided to pair my Sky-Watcher Wave 150i with my C8 EdgeHD for Galaxy Season. For this I ditched the AVX mount head, got a ZWO Pier Extension which fits the AVX Tripod and voila: one sturdy, big and not so mobile setup (new guide scope ...
Discusses ASIAir compatibility with different mounts using similar control methods.
29 days ago
DSLR question
I connect my Canon 70D DSLR to my ASIAir Mini Mini with a USB cable. And it works fine. But I notice theres a small plug in hole on the mini labelled DSLR, and I wonder what thats for. Thx for reading.
ASIAir Mini compatibility and connection setup with telescope equipment.
Sep 13, 2023
First Astrophotography Setup - Need suggestion
Hi all, I'm planning to get started with the iOptron SkyGuider Pro along with my Canon DSLR, and later, I'll be getting my hands on the iOptron HAE29 scope, RC51, and GSO RC 8". I've attached a screenshot of the Excel file, which inc...
Author using iOptron equipment; candidate discusses iOptron device compatibility issues.
Jul 29, 2023
Hand Controller Time out
Hello all, recently I purchased an ASIAIR and have been trying to use it in conjunction with my IOptron GEM28 mount. However, after focusing and polar aligning, when I go to slew my mount to an object the hand controller will shut down for half a sec...
iOptron mount with ASIAir compatibility and control issues.
Dec 30, 2023
