​​​​​​​Designing My Backyard Observatory – Seeking Advice & Feedback
17 replies611 views
akshay87kumar avatar
Hi everyone,
I'm in the process of transitioning my telescope to a permanent mount inside a small roll-off roof observatory, and I’d love to hear your thoughts—especially from those who’ve designed or built home observatories. Location co-ordinates are about 25° N, 87° E. Weather is extreme hot in summers (38-44°C extremes) and winters are 4-5°C. There is a long drawn rainy (monsoon) season between May-July.
Current & Planned Equipment:
  • Setup #1 (existing): William Optics 71GT APO on iOptron CEM40
  • Setup #2 (planned): Celestron C8 EdgeHD – to be used interchangeably on the same CEM40 mount for now, with plans for a dedicated pier later
  • Setup #3 (future expansion): I’m planning space for a third pier to keep options open for future additions (e.g., a wide-field setup or planetary rig)
Observatory Concept:
  • I'm leaning toward a roll-off roof design that can hold 2 to 3 permanent piers, with telescopes mounted atop each.
  • The observatory will be operated entirely remotely, so I don’t need space for staying inside—just room for setup, maintenance, and safe slewing. I will keep the roll-off roof manual to begin with, and automate it later (unless experience says it is better done in one go at installation)
  • I have open space on all four sides, though some trees are present to the east (manageable by positioning the observatory carefully). There’s light pollution on the west, so I’ll prioritize views toward the south, north, and east.
  • From experience, my image quality deteriorates below ~25–30° altitude, so the observatory design must ensure clear visibility above this range.
Seeking Your Inputs:
  1. Pier Spacing: How far apart should the piers be to avoid interference during full slewing—especially considering future additions?
  2. Pier and wall Height: What’s a good height that can help get horizon visibility, while keeping walls high enough. I would prefer the sliding roof to start just where the wall ends, and keep the roof higher (through slope) if that is feasible and better design. I woould like guidance on determining wall height to ensure visibility above ~30°,
  3. Other Design Lessons: Any insights from your own observatory builds?
    • Materials you wish you had or hadn’t used? (I plan to use brick-cement walls, which are common and sturdy in my area.)
    • Tips on roof design to accommodate wall/pier height needs? (I’m assuming a sloped roll-off roof will be required.)
    • Strategies for dust, rain, and wind protection in harsh conditions?
 Thanks in advance for your thoughts and suggestions. Really looking forward to learning from this amazing community!
Clear skies,
Akshay
Arndt Wolkenhauer avatar
Hello Akshay,
there are so many ways to build an observatory and the thoughts you have, I am sure everybody had them. It helped me a lot to look at many different projects.
Here is the link to my project which is built from aerated concrete, for insulation and to prevent heat retention. In the meantime, there is also a tripod at the back wall between the two solid columns.
Sternwarte V2 - AstroWolke
Clear Skies,
Arndt
Helpful Respectful Supportive
Jens avatar
I'd highly recommend going to the Cloudy nights Forum for specific advice on observatory building.
https://www.cloudynights.com/forum/72-observatories/
Well written
Arndt Wolkenhauer:
This is such a neat build! Thanks for sharing - and so much to learn from.
Well written Respectful
Bruce Donzanti avatar
Hi Akshay,
You can go to my Astrobin site and see some pics of my roll off roof which I built on top of my 4-car garage.  Now, it only has one pier but more importantly, take a look at the pics and feel free to send me a personal message with questions.  I learned a lot and wish a few things had been done differently, but it has served me well for over 6 years.  I also added some info on ClondyNights that Jens references above.
Good luck,
Bruce
Scott Lockwood avatar
Hey Akshay
You can also go to my AB site for some construction photos of two observatories I built.
I have hundreds more pictures if you are interested.
Scott
Thanks everyone for sharing your pictures! I am learning a lot from your pictures!
One key question that concerns me is the distance I should keep between the piers. I currently have the WO 71GT and planning to get a C8 Edge soon. I am planning to have space for 3 piers (very ambitious!) with a bit of flexibility. Just trying to understand what would be a safe distance between the piers, while optimizing the space. I see that my WO71GT currently accomodates easily within a 2.5 ft radius, but I dont have the other two equipment. And the CEM40 is a small mount as of now. It would always be good to maintain a distance and avoid getting the scopes and piers/mounts  very close together.
Would 6ft between the piers be a good conservative estimate? Or should I accomodate even higher?
I would say that is really pushing it. I've found that I get better results overall if restrict the lowest acceptable altitude to 50 degrees or even higher. I know that cuts into integration time per night but it helps with resolution and gradients. One approach to this is to pick two objects so you can split up the night, repeating that as needed so you're only shooting while the objects are in the elevation zone. That allows you to make the walls higher for better wind protection.
Bob Lockwood avatar
If your good with math, Bray Falls at Starfront has a great video to determine the swing of your setup for spacing.
Measuring Your Telescope Swing Diameter for Starfront
wsg avatar
Akshay.   My friend @Cosgrove's Cosmos (Patrick Cosgrove) has a wealth of knowledge of and experience in, exactly this topic.
CS's
scott
Hello Akshay,
My thoughts to help you improve things:
- Install a AC or buy one from those portables and put inside. This will help you regulate your roll-off inside in terms of temperature so you don't loose to much time adjusting the roll-off and waiting for the temperature to settle. It will save you a lot of time, trust me. I did in my dome.
- Install a weather station with an AllSky Camera to help you and monitoring the weather regarding clouds, wind, rain and temperature. Humidity also important.
- If you like in a area where in the Winter it snows, install a heating system in the roll-off tracks because the ice will be a major problem when opening the roof.
- The piers build it in cement. Don't buy those in metal, or make them in wood, etc. Cement is the better aproach. If you have the time, build it yourself with the electric outlets running from inside the piers with 4-6 outlets for power, three for ethernet (one for a computer) and the other two if you preferer to run the EQ mount at distance with the computer not right by side of her. For electricity and cables, think it in the long run. What you would need in various scenarios of installing equipment. I did in mine, I have in mine for Electricity, USB connections, ethernet with also RJ45 connections, SDI for video capture and for livestreaming from the actual telescope cameras, etc. all connected to the other room (the room controll). Like I said, think in the long run and the possibilities of everything you want to have so you don't have too much cables all running around.
If you live in a windy area like me, the Dome is the better aproach, but you'll be limited to just one pier.
Hope this gives a few ideias and help in your roll-off.
Regards,
Cesar
Josh Jones avatar
So this is good timing as I just finished mine, and while not really exactly what you are doing with a roll off vs mine with a couple domes, I can give some feedback perhaps that might help...   sorry for so many images, but it helps conceptualize I think your design as this could really be a roll off and still similar process.  I know there are a million opinions on these things, so I will just give a small blurb on why and what I did.
The entire build for me took about 2 months start to finish, pretty quick, did all the work myself, designed in fusion360, then went to work.  I had the 2 domes and they were very reasonable used finds for me.  The dome has some nice benefits with wind blockage, light blockage, and other aspects.  No chance of impacts with scopes, all tied into safety monitor with weather system.  Mainly, I had them, and I didn't want the footprint of a roll off roof.   Also, a roll off roof you can fit probably 6 piers in this same area, but I really only have time for 2 and it's a lot to run, schedule, etc...
1.  To isolate the piers or not... I chose not to.  I don't walk in there, and most professional remote observatories I go to didn't have isolated piers.  I was going to, but it didn't work into my plan with a pier already poured and my concrete couldn't avoid it.  No complaints, I'm not in there, it doesn't move.  Guiding is best it's ever been, I think this much concrete locked them in even further.  Those are 12" sonotubes down 4 feet with another 1000lbs of concreate around them.
2.  To insulate or not... I chose to insulate.  I decided I had an option of letting it cook in the summer, hope it was ok, or insulate and at least give me the option to try and cool if needed.  I'm glad I did.  It was 104 yesterday and it got 84 inside the building with no A/C on.  The domes are just fiberglass, so even with that it stayed cool.  I put a small A/C unit upwind and it cooled it down to 70 within 5 minutes when I turned it on.  The cold air has nowhere to go and it stays very cool.
3.  Exhaust Fan or not... I chose to add one.  It's inexpensive, and this one is downwind and exhausts on a schedule at dusk.  I'm glad this was in place, the cost is minimal ($200 bucks) and it will suck the air out really really quick and through the shutters.  ROR, may not need, but nice to exhaust the air even if the roof was shut, maybe an hour before you open.
4.  Pier Height.  I didn't want it so high that I had to stand on a ladder to use my visual scopes, but not so low I am crouched getting in.  Both failed... lol.  The door is only about 54" high, but to get scopes up high enough to have good view anywhere, I had to build piers a certain height.  I have plenty of room to stand in the dome sections, but duck going into them.  Annoying little bit.  To see visually, they are still a tad high, so I do have ladders to step up one step to see things.  In the end, it was a compromise with how I designed it and it is what it is.
5.  Power and networking.  I ran full 20 amps to each pier and 20 amps for the building.  60 amps total and glad I did.  I also have full ethernet run there and switched between all the piers and computers.  I wouldn't rely on wifi, a ethernet cable is really nice if you can fish one there.
6.  cheap but nice features would the LED inset lights.  I can run from my phone these wifi light kits and adjust the to any LED color.  small, inexpensive luxury item   Piers I welded up myself out of 5/8" steel.  The toolboxes were just low cost harbor freight versions, but really nice for storing parts and things and keeping fairly dust free.
In all this thing cost me $6k to build including concrete, electrical, siding, sheetrock and tongue and grove, lighting, metal roof, paint, etc...  This was minus the domes, which I found used for very cheap.  I didn't think that was too bad and it is going to be fun for the next 30 years to have.  Not sure if that helps, little different than your design, but some is probably pertinent to your build.
Dave Erickson avatar
Here is a link to my 10' Dome construction project:
https://cdn.astrobin.com/ckeditor-files/14617/2022/a382cb5b-489c-406e-8113-872791feb391.pdf
Here is a link to the control systems:
https://cdn.astrobin.com/ckeditor-files/14617/2025/cbe2ff82-b267-4afb-98de-c3704ef04d46.pdf
The third of 3 domes over 15 years...
Off the grid...
best, Dave
Claudio Tenreiro avatar
On this point I could suggest that the confortable distance is the one to allow free movement in the horizontal, of both scopes and its cables, plus the distance of yoursef standing in between them, as a minimum distance. I have similar scopes in size and CEM70, GEM45 mounts as fixed ones.
Best regards and CS!
PS: I have images, here in astrobin, of the process of building my roll-off roof place, which I run remote but from my house...no that far away and I hev a lot of room for working inside.
Cosgrove's Cosmos (Patrick Cosgrove) avatar
Hi Akshay,
I just completed my observatory - Whispering Skies.   It is a ROR design with 4 piers.
It measures 16x20 in size.  I have a complete series of blog entries on this project from the earliest concepts and through every stage of development and construction.  These can be seen here:
https://cosgrovescosmos.com/observatory-project
And a video of each stage of construction can be seen here on my YouTube Channel:
https://youtube.com/playlist?list=PL_BEhGmaZzH_3lfkWw1BDuIm9QQqSpmLC&si=_Kx2y1BBMl3XnRL8
Just a few learnings, I'll share off the top of my head...
1. If you are ever going to have a motor to open your roof, you have to plan for it now.   I would highly recommend adding a motor system.  I am using InteractiveAstronomy's Skyroof System, coupled with the SkyAlert weather system, which can help protect against unexpected clouds, rain, or wind.
2. Design your wall height such that your roof can close even when your tallest telescope is pointed at its highest point.  If you plan to have more than one scope, this will significantly simplify automation.   Otherwise, you need to add the complexity of verifying that all scopes are in a safe position before the roof can close.  If a scope is hanging up, you can't close the roof - this could be very bad.
3. Some people will tell you to isolate your pier foundations. Some will tell you it's not needed.  You are going to all the trouble and expense to build this thing, and you are going to have separate piers, why not isolate them?  Can't hurt and it might help!  I isolated mine, and I am glad I did.
4. Pier placement is tough.  It determines how low you can image. It can also ensure that one scope does not get into the field of view of the other scopes - or even physically in the way.  I had a spreadsheet I built with wall height, telescope tube center height, distance to the walls, and calculated the sight angles from each possibility.   You mention that you will be remotely operating the scope, so the interior can be small.  But keep in mind that you will have to work on scopes.  You may need to adjust them in the dark.  Make sure you leave enough room to maneuver around them easily.  Once you have the PA dialed in, bumping into the scope in the dark is often enough to throw that off.
5. Finally, enjoy the build!  Watching your dream come true is something great - be sure to enjoy it!
All the best,
Pat
Scott Lockwood:
This is very helpful, Thanks Scott!
Bob Lockwood:
This was of great help - completely helped get over the nervousness of "what diameter" to use for piers. Thanks Bob!
This is so good! I will need time to digest this. I am going through each of the videos one by one! I am just thinking of mine as a stripped down version (by half) to accomodate two or maybe expand a bit for three piers.
Josh Jones:
Thanks for sharing your learnings! Will certainly keep them in mind as I design my observatory.
Please do keep the feedback coming in. It is great to lear from all of you.
Gary Seven avatar
Your requirements are very similar to mine, except I wanted two piers. I purchased the plans from SkyShed and from BYO Observatories, ended up using the BYO design on a concrete slab. Making it an "unmanned" observatory is so much easier.
One little subtlety I was slow to pick up on - by making the gable ends east/west and rolling the roof off to the north, the roof peak is pushed back by 1/2 the length of the roof. Helps with polar visibility. If you have heavy dewing (from your longitude, that seems likely) you will need to allow for a gutter of some type to keep dew from running down the roof and into your observatory.
Here is a link to calculating pier clearances:
https://telescopepiers.com/ror-pier-calculator/
Well written Helpful Insightful
Dave & Telescope avatar
I doubt there is anything additional I can add that hasn't been well covered previously but I have a fair amount of experience with this. I built a small 8 foot square manual roll-off in my backyard where I can run all the equipment from inside the house. I also designed and partially built a much larger roll-off in a remote location. Backyard Observatories did the framing, roof construction etc. I will provide a couple links at the bottom but I think the main points would be these:
1) As others have suggested I think horizon exposure is overrated. I have never been happy with image quality below like 30 degrees. If you look at the observatory build done by BYO I posted one of the links to, you see I had a drop-down panel on the south wall which I did use a few times. That might be an option which would enable you to otherwise keep the walls higher.
2) When you say "remote" there is a big difference between remote where you are a significant distance away and have to rely on a totally separate infrastructure as opposed to remote that is e.g. in your backyard. See the link I posted to "going remote- what I've learned" which might have some useful stuff in there
3) Instead of brick have you considered cement board? Might be cheaper.
4) The main issue with roll-offs if you do plan to to fully automate the roof control (and by fully I mean with weather data links etc) in the future is to make sure the roof can close with the scope in any position. Short of that you can just have a semi-automated situation where you can have the scopes park flat with the walls lower and then you will have to visually check to make sure the scopes are properly positioned before you open and close the roof. Web cams are relatively inexpensive and very reliable. That's what I did and it did work although I had to make certain the weather was good because I could not set up an automated roof closure for clouds etc.
Anyway perhaps there is a point or 2 here that will help. Here are the links:
roll-off build
going remote- what I've leasrned
Good luck!
Dave
Planning my Observatory Building
Greetings to the community, I've been thinking for some time now about building my own observatory. At the moment, I have three setups in my backyard. These are out 24/7. The first one is out there for about two years now. Everything is covered w...
Directly relevant - discusses roll-off roof observatory design and permanent telescope mounts.
Sep 6, 2023
Telescope dolly, DIY
Have anyone here built a telescope dolly like these? (these are not mine) if so, do you have any plans you can share on how you built it? is it stable enough to image from?
Addresses permanent telescope mounting solutions; relevant to dolly stability for imaging.
Aug 5, 2023
Do I need dehumidifier / heater for winter in roll-off-roof observatory / damp climate with snow
Looking for info from people with experience from similar climates. Do I need a heater for dehumidifier in the winter for my gear when roof is shut and gear is not being used? I live rural North Eastern Oregon, US. It's damp but not as damp as Se...
Discusses observatory design and permanent telescope setup relevant to gear storage.
Oct 30, 2023
How I build my observatory and what I would do different if I had to do it all over.
Before I start. English is not my first language, so I'm sorry if there are misspellings or maybe the way I phrase things are not correct. I did my best. Why an observatory? When I started this hobby back in 2018, I bought a used C8 Edge HD on a ...
Directly addresses backyard observatory design and permanent telescope mounting solutions.
Sep 28, 2023
My roll-off roof observatory setup
I’ve been into astrophotography since 2021, mostly working with portable setups under average skies and inconsistent weather. Like many hobbyists, my learning has been incremental. Some things worked, others didn’t - and my processing workflows are s...
Directly relevant—shares roll-off roof observatory design and construction experience.
Jan 9, 2026
