Is this a backfocus issue, or is it too minor to even worry about?
8 replies379 views
Is this worth trying to fix?
Single choice poll 20 votes
10% (2 votes)
90% (18 votes)
Gleb Polyakov avatar
Doing trial runs for a new rig based around the SVX180T, and I'm noticing what to me looks like minor backfocus issues. It does appear to be different per filter. See aberration inspector corners below. This is the Hydrogen Alpha filter, which shows the least issues. Lum has the most extreme effect.
BlurXterminator fixes it, and I'm shooting full frame here on a 6200MM, so I might should just be cropping the corners out anyway. But what do y'all think? Is this worth trying to add a .5mm or 1mm spacer for, or is it better to just leave it and fix if necessary in processing?
Helpful Concise Engaging
Quinn Groessl avatar
If you have a tiny shim spacer you could try adding it of course. It's pretty dang close though.
Go after it if it makes you happy but honestly, it's not something you'll ever see except with extreme pixel-peeping. I guess you could hang a jeweler's loupe on chain next to the image if you ever print it out large for display. smile
Daniel Cimbora avatar
On my laptop monitor I perceive left-right elongation in all 9 panels.  Backspacing issues wouldn't cause that sort of uniform defect across the sensor.
Or is there something else I'm missing?
Perhaps run some subs through ASTAP image inspector to quantify the star shape defects in different regions.
Alex Nicholas avatar
I certainly wouldn't be too concerned about that. As Daniel mentioned, I see some very slight elongation in all frames, which may be a little guiding/tracking error, which will be making the corners seem worse than they are, and if that's the very corner of a full frame field, I guarantee you BXT will have that looking more perfect than you will ever getting it by adding/removing sub-millimeter shims… You'll likely crop out 50% of the area of all the edge frames in that abberation inspector image for most images, if not all of it… This hobby can have you pull your hair out at the best of times, don't waste time by creating/perceiving problems where they don't exist.
[deleted]
I agree with Daniel's comment, and add that the angle of the major axis of these ovals appears parallel to the RA axis, implying a tracking or guiding cause.
Leonardo Ruiz avatar
The subject of backfocus and tilt is a very personal one. Many users design their optical train with spacers to ensure they achieve the manufacturer's recommended backfocus and trust that the installed accessories are perfectly accurate. Then by applying BlurXterminator they manage to leave the stars almost perfect.
However, there are numerous factors that contribute to minor variations.
Factors That Can Affect Back Focus, Even with Manufacturer-Recommended Accessories
Imprecision in threads: Threads are not always perfectly aligned or dimensioned, which can cause a slight misalignment in the back focus distance.
Manufacturing tolerances: Optical and mechanical components have minimal tolerances that, when accumulated, can affect the back focus distance. Even small variations in manufacturing can lead to misalignment.
Thermal expansion or contraction: Changes in temperature can affect the materials of the equipment, causing them to expand or contract, which can alter the back focus distance.
Incorrect alignment of the optical train: If the optical components are not perfectly aligned, this can cause slight displacement that affects focus.
Wear or imperfections in components: Over time, wear on threads or other elements can cause small misalignments in the optical system, affecting the back focus distance.
Tolerances in additional accessories: Even if the main accessory has the recommended back focus length, additional accessories (such as filters, adapter rings, etc.) may not have the same precision, which affects the alignment of the system.
Tolerances in Back Focus Systems
The tolerances in optical systems depend on the specific components you're using, but in general, manufacturing tolerances for accessories like cameras, filter wheels (EFW), OAGs, and spacers are small. However, when accumulated across multiple elements, the error can become noticeable, although it’s generally still small in comparison to the total back focus length.
Estimating Tolerances
Thread Tolerance:
The threads of components like spacers, filter wheels, or adapters typically have a manufacturing tolerance that ranges from 0.05 mm to 0.1 mm. However, depending on the precision of the thread manufacturing, this tolerance can be larger in lower-quality components.
Spacer Tolerance:
Spacers are critical components with a specific length. The tolerance for spacers is generally in the range of 0.05 mm to 0.1 mm. Some high-quality spacers may have a lower tolerance, but standard spacers usually fall within this range.
Filter Wheel (EFW) Tolerance:
Tolerances in filter wheels can vary, but they are generally in the range of 0.1 mm to 0.2 mm, depending on the design and the manufacturer's quality.
OAG Tolerance:
OAGs (Off-Axis Guiders) also have some tolerance in the alignment of the guide sensor. This can be around 0.1 mm to 0.2 mm.
Camera Tolerance:
High-quality astrophotography cameras typically have a mounting tolerance in the range of 0.05 mm to 0.1 mm, although the sensor positioning tolerance may be more precise depending on the model.
Calculating the Accumulated Error
If we take a conservative tolerance estimate of 0.1 mm per component and use five components (such as camera, EFW, OAG, and two spacers), the accumulated error could be, in the worst scenario:
Accumulated Error=5×0.1 mm=0.5 mm
My Solution: Baader VariLock 46 and Baader M48 Tilter
For those seeking a precise solution to these issues, the Baader VariLock 46 and Baader M48 Tilter are highly recommended accessories. The Baader VariLock 46 allows for fine adjustment of the back focus distance, while the Baader M48 Tilter helps correct tilt, ensuring that the optical train remains perfectly aligned.
These accessories not only allow for the correction of minor manufacturing defects and adjustment variations but also provide an effective way to achieve optimal optical performance by reducing the effects of small imperfections and ensuring more precise and consistent focus.
For me, the main advantage is that once installed, it allows for quick corrections without having to disassemble the optical train, allowing for rapid testing and adjustments, which allows for very rapid evaluation of problems such as vignetting, tilt, and backfocus.
Super helpful and interesting! The tolerance stack point is a good one – I'll look into whether baader makes a m54 version.
I'm not convinced it's astigmatism, just because there's a radial pattern to the elongation, pointing at the center. I'm inexperienced, but my understanding is that points at backfocus.
Ultimately, yeah, it's minor enough that it doesn't matter. It can be a project to try to chase down and perfect some time down the road. Appreciate all the input folks!
Respectful Supportive
BACK FOCUS ISSUE - Williams Optics FLT91
In my recent sessions with my WO-FLT91 with the Flat6AIII flattener, I have noticed that the stars in all four corners are elongated, indicative of back focus issues. I checked this in the aberration inspector process in PixInsight and I am consisten...
Directly addresses back focus problems; relevant to author's corner elongation issue.
Sep 29, 2023
Dual narrowband imaging issue
I'm new to using dual-narrowband filters in combination with a OSC camera, and I'm faced with the following problem. During one of the last sessions, I used an Antlia ALP-T 3nm Ha-OIII filter with a ToupTek ATR2600C camera. The filter is inst...
Discusses filter-related imaging issues similar to author's backfocus problems.
Aug 6, 2025
