Hybrid processing conundrum
4 replies130 views
cafuego avatar
I was lucky enough a few days ago to be able to capture the conjunction of the the Moon and Venus in Sagittarius. I shot it wide angle (150mm-ish or so) with a DSLR lens and Ha+[OIII] filter on a cooled ASI24MC so that I would also be able to pick up the Lagoon and Trifid nebulae. That worked out nicely and I got all subjects in frame. The Moon is (as expected) completely over-exposed, but I can live with that.
Now my issue is that over the 30 x 60 second exposures, the Moon has moved a fair distance against the background stars and if I stack the images, it turns into a white egg.  Is there a way I can process my subs so I keep the Moon from a single sub and exclude its maxed out pixels from all the other ones?
I have a Mac and generally use Siril for stacking and initial processing.
Well written Engaging
As far as I know not in Siril. Maybe in PI if the conditions are right. But I doubt it.
Geoff avatar
Try the comet processing routine in PixInsight (Treat the moon as a moving comet)
I don't think that is going to work as normally the lunar halo is too strong for such an operation to succeed. A montage might be a better option.
Well written
cafuego avatar
For the record, the first attempt (using Siril and a lot of tweaking in Lightroom to reduce internal reflections and lens flares) is
120s vs 300s subs
Hi! I read a lot about recommended exposure times according to your setup, target, sky conditions, etc. Saw several videos about this subject. Either way, I wanted to run some tests with my equipment so I can have my own conclusions. I just want to s...
Discusses exposure time selection relevant to author's 60-second exposure strategy.
Aug 24, 2023
