NINA - blank frames during autofocus
8 replies121 views
Had a weird thing happen last night. I was running a QHY5iii715C camera and everything was per normal until I tried an autofocus run. All of the autofocus frames where blank/ pure white. I've never seen that before so I'm wondering what the cause might be. I was running HocusFocus and checked everything I could think of in NINA to no avail. I'm wondering if anyone else has seen this issue and what you did to fix it.
bigCatAstro avatar
Had a weird thing happen last night. I was running a QHY5iii715C camera and everything was per normal until I tried an autofocus run. All of the autofocus frames were blank/ pure white. I've never seen that before so I'm wondering what the cause might be. I was running HocusFocus and checked everything I could think of in NINA to no avail. I'm wondering if anyone else has seen this issue and what you did to fix it.
I’ve had this happen a couple times, one was atmospheric and the other hardware. I’ve had a cloud pass through the frame and it caused the sub to be white/green and I’ve had my usb cable for my camera go bad and produce black or white frames.  The usb cable issue was resolved when I replaced it.
Concise
Well, there weren't any clouds and I don't think it was the cable because I didn't have any problems with imaging both before and after trying the autofocus run. In fact, other than that, the night was flawless. I repeated the process a few times with the same result. I thought it might be a camera gain setting somewhere because I change my cameras around often but I couldn't find anything.
bigCatAstro avatar
Interesting, so you were able to repeat the issue in a non-imaging session?  Have you uninstalled and reinstalled the ASCOM driver for the camera?
I was able to repeat the issue during the imaging session. I've not messed with the drivers yet but that will be the next thing.
Brian Puhl avatar
Autofocus has its own gain settings.     I'd just double check there first.
That was the first thing I looked at and it gives exp. time which was normal, nothing about gain though, I don't use filter offsets. If it happens again I'll check min and max to see if there's even any data there.
Well, it worked fine last night so who knows what caused it. Just one of those intermittent software hiccups that are all to common.
bigCatAstro avatar
Glad to hear things went well.  A strange hiccup no doubt.
Paramount MYT + Nina + PHD2 guiding issues
Hey folks, quick question for anyone running a Paramount MYT with NINA and PHD2. My Paramount is doing my head in. Everything is set up correctly as far as I can tell, SkyX, ASCOM, all that. But every now and then PHD2 throws up the error “your mount...
NINA and autofocus troubleshooting with similar equipment setup.
Nov 27, 2025
Is this tilt/backspacing/collimation/pinched cell...or a combination of everything?!
Over the summer I took the mirror out of my R200SS to wash it. I've done it before and it's always been fine. This time however, on using it the stars were horrid. The first night, the were looking like this during focusing; So I took everyth...
Camera autofocus issues differ from optical collimation problems with telescope mirrors.
Sep 11, 2023
Focuser trouble when NINA starts
Hello, I’m new to NINA (was using ASIAIR before), I was able to connect and set everything and to perform two nights of imaging. Here is my issue, the last two times I turned all my equipment on, my focus was lost (I mean stars wereway out of focus, ...
NINA focuser connection issues may relate to autofocus problems.
Sep 3, 2025
EdgeHD 8 Focus Point Moving
Hello! Curious if anyone can assist here. I have an EdgeHD 8 using a ZWO EAF. Been using it fine for well over 2 years now and everything has been fine until recently. It can’t seem to find focus anymore using Nina/Hocus Focus. What happens is the fo...
Focus point issues with automated focuser similar to autofocus failure.
23 days ago
