Unintended changes to tracking rate when slewing in PHD2 for calibration
5 replies101 views
Himanshu Pandey avatar
I have been experiencing a nuisance issue where the tracking rate of my Skywatcher AZ-EQ6 changes from sidereal to a custom rate, that I have not defined, when I slew for calibration from within PHD2.  I have to manually click on sidereal in the eqmod window before I can start a calibration in PHD2.   I don't see the tracking rate changes from slews I initiate within NINA where the guiding resumes as intended afterwards.
Are you, or have you, experienced this issue?
You might try switching to Green Sky Server. It's a more up to date replacement for EQMod.
Sorry, I mean Green Swamp Server!
Thanks Tony, I will give it a try.  I assumed it wasn't supported any longer but that was a bad assumption with the last release less than a year ago.
Jim Raskett avatar
I second GSS. Been using it for years and have had no issues with PHD calibration slews or anything else for that matter.
Do you guys have any experience with GSS and multiple instances?  I have two mounts and GSS only seems to support one running instance, it only controls whichever mount connected to it last.   I don't see a way to have multiple windows open concurrently.
ToupTek is getting closer to breaking the monopoly (StellaVita 2.0))
Hello AB!! About a year ago, I had early hands-on time with what was then called Astro Station. I made a YouTube video and a few forum posts about it here and there… At that point, it was obvious what they were trying to build: an open, brand-agnosti...
Mount tracking rate issues with PHD2 calibration slews relevant.
Feb 9, 2026
Slew rate does not make sense
Hi, I have a problem where NINA (or possibly SynScan Pro or the mount) is slewing way faster in the RA axis than it thinks it is. This leads to the mount overshooting substantially and I have no idea how to fix this. The following is what I can see:P...
Slew rate problems with NINA and mount control relevant.
Oct 13, 2025
Struggling to improve my telescope guiding performance
I’ve been struggling to improve my guiding for a couple of months now, despite any changes I make it doesn’t seem to have a major effect for improving my total rms. Gear Used:Sky Watcher 150iExplore Scientific ED102ZWO OAGZWO ASI 120MM Relevant Setti...
Guiding performance issues with PHD2 potentially related to tracking.
Feb 20, 2026
