I have £600, what should I upgrade on my setup?
11 replies283 views
astrokop avatar
My Setup currently is:
Stock 40D
SW Star Adventurer
Canon 75-300mm Lens
SW Star Adventurer Tripod
Noah Tingey avatar
Some ideas for you to consider:
1. Rokinon 135mm f2 (also sold as the brand Samyang)
2. SW Star Adventurer GTi (assuming that you mean you have the 2i)
3. If you already have the above, then an ASI220MM Pro + guidescope + mini PC to run NINA
patrice_so avatar
Save that money to get a cooled dedicated cam and/or a wider scope.
Clayton Ostler avatar
Stock 40D
SW Star Adventurer
Canon 75-300mm Lens
So I am going to make some assumptions before giving my opinion.
I am assuming you are managing your current setup with a computer or device of some type.
If you are not yet doing that, I would suggest using some of that money to get something to do that. I love my asiair plus.
Goto, PlateSolving, Electronic Assisted Polar Align, Imaging, Live stacking. Without these things I think the hobby would be too hard for me personally.
I am not saying you have to get the ZWO device, you could use a laptop, or stellarmate, or build your own rasberry pi or whatever, but having a device/computer to run the show is pretty important in my eyes.
Assuming you have that all solved, I would be looking for small used refractor. and small used guidescope/guidecam.
For me, buying an astro cam, but not having a scope to use it on seems out of order, I have used a camera lens on an astrocam before, but you are ultimately going to spend $150 on adapters and mount kits to connect to the camera and get it mounted on your mount, and I think that money would be just better spent towards a small refractor.
For around $450 you could get a used at72ed and a flattener/reducer, and still have $150 left for a cheap small guidecam/guidescope combo.
I sold my at72ed for $300 and there are 2 inch flattener/reducers for around $100 all the time.
I see svbony 30mm with asi120mm combos on cloudy nights for around 150-175 all the time.
Just my two bits.
Aloke Palsikar avatar
The 1st question I would have is what is your goal in short /mid term.  I assume you are interested to photograph some Deep Sky Objects like Nebulas, Galaxies etc.
Currently  you are using your Star Adventurer Mount along with your EOS 40D Camera and Lenses as described.  This is a good start
However I would recommend it would be worthwhile to invest your money in an entry level  Refractor Telescope and you can use it with your DSLR to capture images. There are several good products like Askar , Celestron etc.  Infact the Askar SQA55  also doubles up as a Telephoto lens.  Should fit in your budget I think. There are some good retrofitted, second hand buys available which work well.
As mentioned already investing in a dedicated controller like ZWO ASI Air could be good to manage your entire setup. Is definitely worth the price
Hope this helps
Supportive
astrokop avatar
Clayton Ostler:
Stock 40D
SW Star Adventurer
Canon 75-300mm Lens
Just my two bits.
Thank you for the reply, no I do not currently have a computer at this moment in time to control it but I was looking at facebook market place to buy one and I can get one for around 50 pounds.
SVbony sells a guidecam/guide scope bundle for around 110 pounds brand new, not sure what your thoughts on that bundle is but i think it's a pretty good bargain.
SVbony sells a 70mm Doublet Refractor Like the AT72ed for 230 pounds brand new, It's called the SV503 70ED If you were wondering. They also sell a flattener/reducer for 80 pounds too for the scope.
I Got a couple more questions.
Do you also think that the SV220 1.25 inch Duoband 7nm Filter would be a good fit for my setup? I also saw SVbony sells a version of the 585mc camera (uncooled) for 200 pounds too which I thought was interesting.
astrokop avatar
Aloke Palsikar:
Hope this helps
Thank you for the reply, yes like you said my main goal is to capture dso like Nebulae, Galaxies and further on.
Yes I definitely need a computer of some sorts to control my setup. I was looking at some laptops on facebook market place and I found one for 50 pounds that I might pick up. It's nothing fancy but unless I'm wrong then in that case please correct me I don't think you need a amazing computer to run programs like Nina, PHD2 etc
TiffsAndAstro avatar
Plenty of options and good advice here
Clayton Ostler:
Stock 40D
SW Star Adventurer
Canon 75-300mm Lens
Just my two bits.
Those all seem like good options
The585mc is a good camera.  But id make sure I have a scope, flattener and computer first.
I think that guide setup should be adequate for a small refractor.
I happen to own the scvony duoband. It's a great filter for the price, but it's only really designed for nebulas. So keep that in mind.
Starting the camera purchase is a bit of a black hole. You will need an ir/cut filter to go with the cam too. The difference between a noncooled 585 and your DSLR is not as much as you would think. So I would get other stuff first.  Just my opinion.
Aloke Palsikar:
Hope this helps
Yes, you do not need a fancy computer for this.  Any standard laptop either with Mac OS, Windows, Linux would work.  Many Softwares like N.I.N.A  or post processing ones like Siril , Graxpert, PixInsight etc work well on all these systems.  Infact ZWO ASI Air is an adaptation of Raspberry PI itself.  However you may need to have sufficient RAM (16-32 GB) and Disk space (> 500 GB) as post processing files occupy lot of space especially during Stackingi if you large no of exposures
Noah Tingey avatar
To clarify: NINA only works on Windows computers
Fornax LighTrack II setup advice
Hello all, I bought a Fornax LighTrack II used for about 370€. It's just the tracking arm so that gave me room to improvise how I would like to have my rig set up and I've come to this final configuration. However, I am very open to any suggestions. ...
Discusses tracking mount setup similar to author's Star Adventurer tracker.
Jan 10, 2026
Looking for a suitable telescope for a mobile setup
Hi! So, I have a spare EQ-5 pro mount, which I used the past year in my backyard observatory, however, I got an upgrade and I thought I should make a mobile, smaller setup around the mount. I have everything, except a telescope. I have a newton in th...
Addresses mobile/portable astrophotography setup considerations relevant to author's current gear.
Jan 20, 2026
