Phil Creed avatar
Like a lot of folks I've been imaging strictly with refractors.  Simple reason–astrophotography.  is.  hard.  as.  is.  Put a camera on the business end of a refractor, done.  Newts, of course, need collimation.  Which, as a longtime visual observer, that hardly scared me…
…at f/5.
But this is imaging.  At f/4.  With itsy-bitsy weeeetle pixels on my 533MC-Pro.
Funny thing about 3.76-um pixels is they're harsher critics than the balcony hecklers from The Muppets, imaging Newts are ~f/4 and collimation is like the lightning round where dollar values are double and the questions are twice as hard.
Still, I thought I'd try my hand at one and borrowed a friend's ES N208CF.  It wasn't fun, and I didn't exactly nail the collimation.  The secondary shadow was ~10% displaced from center when defocused.  Still, for a "hold my beer" session of ~45 minutes, it wasn't bad.  And I appreciate getting a big, fast gulp of light with a longer focal length than I could EVER hope to afford with a refractor.
But an ES N208CF is a bit much for an AM5.  It DID work, but I had to use a 3D printed part to hold both my ASIAir and guidescope (yes, I used a guidescope) and…it DID work, but not ideally.  I was getting ~0.7" RMS on most of the 20-sec frames on M13 but some had sizable guiding spikes and had to toss 5 out of 140 subs.
My preference would be a smaller scope.  So I naturally got to thinking about the Carbonstar 150.  My only reluctance is the resulting focal length of 570mm @ f/3.8 is too close to my 540mm I get from my NP101.  It is, though, MUCH faster.  And I could realistically get 690mm at a still-fast f/4.6 using a Paracorr, a combination of focal length and speed in a refractor I'll be able to afford right around NEVER.  690mm isn't exactly "galaxy scope" territory, but that's still a sizable boost over most of 'Frac Land.
I only did a 45-minute test shoot with the ES N208CF so I can't really tell, but for those that have the Carbonstar 150, I have the following questions:
1.  Being a carbon-fiber Newt, is the resistance to temperature-induced focal drift the real deal, or hype?  How stable is focus over, say, a 3°C (5°F) drop vs. a decent-sized refractor?
2.  Anyone use a Paracorr with the Carbonstar 150?
3.  Anyone go full-throttle and use a Starizona Nexus for face-peeling f/3?
4.  How stable is the collimation over the course of a night?
5.  OAG, or just bite the bullet and get either a 2600-Duo or 2600-Air?
Clear Skies and Thanks In Advance,
Phil
Astrophotgraphy isn't hard at all, if your skies aren't crap. I can only answer the first question as far as a 6" newton CT goes: maybe once over the entire night with a 10 degrees drop (that's C not F!). I can't see any difference with a metal tube for a delta of 3 degrees C. My "refractors" (read telephoto lens) are far more sensitive to temperature shifts than that.
ScottF avatar
For #1 and 4, I have not had issues. I recheck focus during the night, so focus is good. I don't use an OAG yet, and have no issues on an AM5. Although I will be shortly with my qhy mini8 combo.
I think the use of carbon fiber is a bit of overkill in a 6" scope. I have a 6" f/6 steel tube Newt and I really don't have any issues with focus drift through a night's imaging. If I need to refocus it's usually because of changes in the seeing more than an expanding tube length. Everything of course is more sensitive at F 3.8 but the tube is shorter too. Refractors and SCTs are effected more by temp. changes.
On collimation, if the secondary and primary mirror cells are well designed, I wouldn't worry about collimation changing during a imaging session. In fact, if the OTA isn't transported and protected from large temp. shifts during the day, I would expect that collimation would hold pretty well.
Lastly, IMO you don't need an OAG and I'd avoid the Duo, just use a separate guide scope, it's an easier solution and if its a nicer refractor, you can image with that too.
Tim Ray avatar
Agree with Tony!
LenaStarLake avatar
Hi Phill its me Lena, just get it man, the only complaint I have is that they don't have a bigger 8'' version smile.
Phil Creed avatar
Hi Phill its me Lena, just get it man, the only complaint I have is that they don't have a bigger 8'' version .
Lena,
Glad to see you chime in.  I will need permission from my Chief Financial Officer to a CS150 otherwise my ghastly fate will be retold among imagers with hushed tones.
Yeah; I second the Carbonstar 200 idea.  Not exactly a perfect match but the 8" f/4 TS ONTC Newts would probably be the closest current fit.  But a stateside HPS version would certainly be nice.
Only thing I don't like about the Carbonstar is the secondary RIGHT at the very end of the tube.  A revised version that builds the (stupidly-expensive...) dew shield into the tube length seems like an overdue idea.
I forget; what did you use for a guiding setup that night at Warren Rupp?
Clear Skies,
Phil
LenaStarLake avatar
Oh wow I was unaware that they were selling a dew shield for this telescope now, that is a new addition since my purchase.
Your right its way too expensive I'm never going to buy that, since I could just 3D print an adapter and glue a circular piece of fabric on the front for 20 dollars and it would serve the same purpose. Though I have not had any problems with dew on the secondary in my time so I haven't found the need for that yet, but its still something to consider.
I use a touptek OAG which i made work with my 3D Printed filter drawer by adding some screw holes, I was able to get it a few months ago on AliExpress for like 100 dollars before they stopped shipping to the US. It works great for me, I prefer to off axis guide as it makes up for alot more of my mounts inaccuracies than having a secondary scope.
The equivalent now would be like a Zwo oag or ogma oag. I think just regular guide scope guiding would work just as well for with that fancy mount.
I hope that helps smile
ScottF avatar
One thing I forgot to mention, and it is irritating as all get out, is the crappy cap over the primary, and the crappy cover at the front. Neither stay in place. I had to tape the primary cover in place and add felt to the front cover to keep them from falling off.
Concise
Jefferson avatar
Hi Phil,
I've been using the Carbonstar150 since middle of 2024.  Here's what I've observed since then:
1) Temperature stability has been very acceptable.  All of last year I had been using the ASIAir and did not see a difference when autofocusing on 1 vs 2 C temp changes with the EAF.  I did not try larger temp deltas.  The main thing I saw was that was needing a longer cooldown time in the winter to get to ambient.  During the Summer 30mins was plenty while Winter 60mins was needed.  The extra weight savings of the Carbon Fiber is also appreciated.
2)  Haven't used the Parcor, but it is on my list of things to get.
3) I have been working with the Starizona Nexus 0.75x corrector as my current project.  The corrector does a good job with this scope of correcting out to the corners when everything is Tilt-free and Backfocus is dialed in...  To make this happen, I've been heavily leaning on OCAL 3.0 Max collimator for the telescope end and the Astro Precision Later Tilt adjuster for the imaging train.  As an additional note, the factory Crayford focuser with compression ring clamping around the corrector body is a tilt factory and tilt was noticeable at F4, even more so at F3.  I replaced the focuser with a TS R&P focuser and have been using a screw-in connection for the corrector-telescope attachment.  However, with the mirrors collimated and the imaging train square, I was still getting tilt when screwing them together.  Tape around the Nexus corrector body to allow for a snug fit inside the focuser body removed the sag and resolved that issue.  I think F3 is definitely doable, but a project to get dialed-in.  The main helper has been the Astro Precision tilt adjuster.  Everything you change introduces tilt and I couldn't imagine tying to correct for that in the dark with the limited clear skies I have.  BlurXterminator is also your friend
Here is my recent first light with the Nexus 0.75x:
https://app.astrobin.com/u/J.W.P?i=r72xrj
4) Collimation has been very stable and a non-issue.  The secondary spider is very robust, almost overly so.  The OCAL collimator make adjusting the secondary very easy as you get a live view of what is happening.  The secondary spider does however produce a low incidence internal reflections, which I have since resolved with gaffers tape.  I have an original primary cell cover, which was much better than the replacement injection molded part they had sent me (i.e. no fallout issues with the original 3D-printed cover as the temps drop).
5)  I've been happy with the 2600MC Duo.  There is plenty of light hitting the guide chip with both the 0.95x Apertura and 0.75x Nexus correctors.  No issues with finding guide stars at F4 or F3 with the narrow band filters I've been using (6-9nm FWHM band passes).
Let me know if that helps!
-Jeff
Jordan Morley avatar
I'd suggest getting a used newt or a cheapo on sale look for the newt you don't want and get use to taking it apart and modifying it. You can get quite decent upgrades on aliexpress and have fun with improving it (:
Phil Creed avatar
Wondering if Lena or others might chime in here on this–will a 2600 Duo/Air work on the 150CS?  I think it needs a FF-size imaging circle or thereabouts to illuminate the guiding chip.
I have a friends who's offering up a 2600 Duo at a good price and it.  is.  tempting. me to upgrade from my 533MC-Pro – IF it'll properly illuminate the guiding chip.
Clear Skies,
Phil
Why not enter the specifications into Newt for the web and see? It will give to the field illumination info you're looking for.
Newt for the web
Jefferson avatar
Hi Phil,
Yes, it will work.
Re-pasted from my earlier post smile
ScottF avatar
Jefferson:
Hi Phil,
Yes, it will work.
I have the 2600MM Duo on an f3.8 refractor with 3nm filters and I have found it unreliable finding guide stars. Maybe a less restrictive band pass would be better? I've been tempted to swap it out for another FW I have with less restrictive filters.
Phil Creed avatar
Jefferson:
Hi Phil,
Yes, it will work.
Which refractor, if you don't mind me asking?
Clear Skies,
Phil
Well written Respectful
ScottF avatar
Phil Creed:
Jefferson:
Hi Phil,
Yes, it will work.
Clear Skies,
Phil
Williams Optics Pleiades 68mm. I should add I was using a GEM and needed 3 seconds guide exposures for it to work. On a harmonic mount with 1/2 to 1 sec exposures there's no way I could use it. That's with 3nm filters.
Phil Creed avatar
Another question entered the bear brain as I stumbled through the forest of life:
I currently have an NP101 with a 540mm focal length at f/5.4 and an unobstructed 101.6mm of aperture.  So between the NP101 and CS150 it's a meaningless difference in pixel resolution.
My question would be SNR, and it's not as cut-and-dried as I initially drew it up in my head.  The CS150 has a 570mm focal length with the coma corrector at f/3.8.  At first glance this would mean (5.4/3.8)^2 or a 2.02X boost in imaging speed.
The effective aperture is ~135mm.  I calculated that first as (150^2 - 62^2)^0.5 to account for the 62mm secondary for 136.6mm aperture than clipped a tiny bit more off to account for the spider vanes.  So with the 0.95X coma corrector I get 570mm at an effective f/4.22.  Still really fast for 570mm FL.
So by running these numbers, I'd have about the same focal length as my NP101 but gather light (5.4/4.22)^2, or 1.64X faster...
...or would it STILL be more?  Would the increased aperture of the CS150 vs. the NP101 tack on an additional boost to SNR?
Clear Skies,
Phil
Jefferson avatar
Hi Phil, I think your original math is correct, but do not think there is an additional SNR boost above the 1.64x you calculated, assuming equal integration time.  I think you would however capture light from fainter objects (dimmer stars) that the smaller aperture can't "see".
@ScottF, I think you may have bandpass shift from your fast F-ratio setup.  Your tight filters block more light, but may not be centered to the light that is coming through your scope.   A wider filter would help and is worth trying if you already have one on-hand. This is assuming you don't have this issue with the filter removed.  If you do have issues with the filter removed, then you have an issue elsewhere.​​​​​​​
Helpful Respectful
ScottF avatar
Jefferson:
They are "supposed" to be ok at f3.8, but I am a bit suspicious and plan to check at some point.
levin green avatar
Hey, is it possible to use a ZWO 2400MC PRO with the carbonstar 150? I am worried about trying a fullframe camera on it instead of going with the 2600MC PRO. Anyone have experience with it / know if its possible without crazy vignette?
From the ad at High Point:
“This dedicated approach resulted in an increase of about 10% more signal in the center of frame and more signal overall across a circle reaching out to micro 4/3 sized sensors. While APS-C and full-frame cameras will work with the CarbonStar 150, this telescope shines brightest with the excellent smaller sensors available today such as the IMX533 and IMX294!”
Well written Concise Engaging
Alex Nicholas avatar
Phil Creed · May 20, 2025, 02:02 PM
  1. My newt is CONSIDERABLY faster at f/2.8, and is an Aluminium tube… I refocus the newt after a 5°C temp drop (though it doesn’t typically need it) where as my 120mm F/7 APO would be visibly out of focus after a 2.5°C drop in temperature.
    I feel that the Carbonstar 150 would be just fine at a 3°C temp drop.
  2. Can’t speak to using the Carbonstar 150 @ F/3, but again, my 150mm F/2.8 newt is INCREDIBLY fast - and also, INCREDIBLY unforgiving… If you think collimation at F/4 is intense… at F/2.8 - it’s a painful, painful task, that even with a plethora of tools at your disposal, it can still LOOOK spot on, but produce wonky stars… If you want to look at F/3, be 100% sure you’re OK with throwing full nights of data in the bin for a few months until you really get used to it.
  3. Again - the carbon star and my scope are different, but, looking at the mechanics of both, they are also quite similar in a lot of ways… My secondary almost never needs adjustment - my primary needs adjustment every time I move it in and out of the house.. it may only be a tiny tweak - but its every time. I did find with mine that the primary mirror was able to move laterally in the mirror cell, which caused collimation to go out wildly after a meridian flip - this has been resolved with a thin layer of teflon tape to take up the space in the mirror cell… Again - The carbonstar may or may not suffer this - but at f/3.8 or f/3, 1mm of lateral movement of the primary will ruin your night…
  4. With my newt - I actually ditched my OAG, because I had 55mm of available backfocus distance, so it was rotator or OAG.. Since I don’t want to rotate my focuser after completing collimation, I opted for the rotator. However, (and again, mine is F/2.8, so the carbonstar will be more forgiving to a point) the critical focus zone on a properly fast newtonian is TINY, changing filters requires a refocus, your stars in the OAG might be razor sharp when imaging with Lum filter, but when you switch to a SII or OIII filter that might be 30 focuser steps further in or out, I can guarantee you, your guide stars are an absolute mess… Might be OK at F/4, or F/3.8, but at F/3 and F/2.8 - almost unusable. My guiding in L, Ha & R averages 0.4” RMS, but G and OIII are closer to 1.1” RMS because the star is ALL MESSED UP…
    2600MC Duo/Air resolve this as your guide star is affected by the filter, so focus of your guide chip changes with your imaging chip - but then you’re guiding through potentially a 3nm Ha/OIII or worse, an SII/OIII filter… Have fun with that…
