Need to take bias longer than 0 seconds on the QHY Minicam
12 replies445 views
Noah Tingey avatar
Below are two bias frames taken on my new QHY Minicam8M. The top one has 0.25 seconds of exposure, and the bottom has 0 seconds of exposure. See the gradient in the bottom one? The right side is darker.
Also, when zooming in, notice how the noise pattern in the 0 second image is funky:
Lastly, here is the histogram of the 0.25 second image:
And the histogram -- at the same zoom level & horizontal position -- of the 0 second image:
Assuming that my minicam isn't defective and this behavior can be seen in all minicams, then just a PSA that you should take your bias frames with an exposure length longer than zero seconds. I have found that 0.25 seconds is sufficient, but I don't know if that's the ideal length. Not sure if this has been documented elsewhere yet, so I decided to make a post about it.
Iosif Bodnariu avatar
A bias frame is taken at the shortest exposure of the camera, specified by the manufacturer.
Your camera have 11μs-900sec.
miniCAM8 (IMX585) | QHYCCD Astronomical & Scientific Camera
Jan Erik Vallestad avatar
Or better yet scrap the BIAS frames and do darkflats. I don't see why one would shoot BIAS with a cooled camera anyway.
Yilia Yu avatar
Hi, the QHYCCD technician suggests that bias should be taken within 20 ms.
Stelios_Stergiou avatar
Jan Erik Vallestad:
because they watching too many lazy YouTubers… 😉
TiffsAndAstro avatar
Jan Erik Vallestad:
Lol me too
Noah Tingey avatar
Iosif Bodnariu:
This is not true.
Many cameras enter different modes depending on exposure length, which can mess with your bias frames. In the QHY driver, this is called "Stream mode."
Noah Tingey avatar
Jan Erik Vallestad:
Assuming that you're dithering, why would you take darks (or darkflats) at all with a camera that has zero amp glow?
Noah Tingey:
As far as darks go because is better this way and costs nothing and for darkflats because you'll get a precise calibration with your flats.
Charles Hagen avatar
Iosif Bodnariu:
As has just been experimentally confirmed, the shortest possible exposure will not produce a result that will adequately correct the real bias signal of longer exposures. The point of taking calibration frames isn't to conform to convention, it is to correct your exposures. Shortest possible exposures here will invariably produce uneven flat field correction across the frame and will introduce a gradient that did not exist in the lights. There is no reason to do this. In Noah's 0.25s example, there is absolutely not going to be any significant dark current so there is nothing wrong with using that as a bias. This is precisely the reason why for years I have suggested taking 0.2s+ bias exposures - there's nothing to lose and you can avoid issues with stream modes and other short-exposure variability.
Jan Erik Vallestad:
With even an elementary analysis of the signal components associated with bias and dark flats, you will find that they are effectively identical. There is no significant additional contribution from dark current at reasonable temperatures (even uncooled with the 585) that could change the calibration frame. Dark flats on cameras that have near-zero amp glow and very low dark current are effectively just bias. There's no reason to spend any additional time taking new dark flats all the time to exposure-match your flat frames. This also does nothing for the primary use for bias (with this calibration routine) being light correction. Most people do not take darks with these types of sensor, and for good reason.
Eric Gagne avatar
I had the same issue with my Touptek ATR585M. It has something to do with the IMX585 sensor and its HDR mode. The minicam linearity mode uses somy’s HDR. The ATR585M gives the option, I had that problem only in HDR mode.
I started a topic on it and got the answer from another member who wrote an article about it.
https://app.astrobin.com/forum/topic/218299/touptek-atr585m/bias-frames-darker-on-one-side-in-hdr-mode
Rafał Szwejkowski avatar
I use darks for PI's Cosmetic Correction automatic mode, which is a must for long focal lengths.  Without it, the hotpixels prevent proper registration.
Dark & Bias without mechanical shutter
Is it possible to take dark and bias remotely without a mechanical shutter? I noticed many people here in astrobin using their CMOS like QHY and ZWO remotely, just wondering how everyone is taking their dark and bias without shutter.
Discusses bias frame acquisition on QHY CMOS cameras, directly relevant to poster's question.
May 10, 2023
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Not relevant; discusses fan vibration causing star trailing issues.
Nov 18, 2025
ASIAir Mini time between exposures - How to reduce?
Hello, I've noticed that the downtime between exposures is considerably longer than expected. I timed how long it takes the ASIair Mini to take a series of dark frames with the ASI6200MM without any other equipment connected. I subtracted the tot...
Discusses exposure timing issues with ASIair and camera settings configuration.
Nov 3, 2023
Player One Poseidon M camera showing clustered hot pixels in dark frames
Hello everybody, I recently bought a Player One Poseidon M camera (analogous to ZWO’s ASI2600-M Pro). The camera hasn't had its first light yet, because the weather has been bad and the filters haven’t arrived yet. However, I took bias and dark frame...
Relevant; discusses hot pixels and noise patterns in dark frames.
Dec 14, 2025
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Relevant; discusses gradient issues in dark frames from similar camera.
Mar 5, 2026
