Ambient Humidity vs Indoor Humidity
2 replies88 views
Jerry Gerber avatar
Hi all,
If the ambient humidity is about 85% outdoors, any one know what the humidity would be at a remote observatory when the roof is closed?
Thanks,
Jerry
David Moore avatar
No, not as the question is posed. However if you could say what the temp was at 85% relative humidity (RH) and then ask the question what the relative humidity was with the same airmass at a different temp then this chart will tell you.
https://manual.museum.wa.gov.au/book/export/html/89/index.html
As the chart above shows it depends on the temp. Might be time to add some remote condition sensing to the rig.
Question about GM1000
Yesterday there was a huge power outage in San Francisco where I live. It's still happening. My GM1000 mount is at a remote observatory in New Mexico and I am unable to access it as my Wi-Fi & power is down. All the equipment is turned off so...
Remote observatory context relevant; power outages affect humidity control systems.
Dec 21, 2025
NINA Repeatedly Disconnects from Observatory Safety Monitor & Weather
Nina is repeatedly disconnecting from my observatory's safety monitor and weather. I should mention this is at a remote observatory, I'm some 900 miles away from my scope. I added the Reconnect: Safety Monitor and Reconnect: Weather to the Ad...
Remote observatory humidity/weather monitoring directly addresses your humidity question.
Sep 1, 2025
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Dew prevention discusses moisture control relevant to humidity concerns.
Nov 28, 2025
