Matthew avatar
I’m currently using a Canon 2000D with a 75-300mm telephoto lens on my Star Adventurer 2i, what would be a good lens upgrade for a beginner like me that will yield much better results than my 75-300. (trying not to go over $550 but can make exceptions).
Olaf Fritsche avatar
A small refractor would be a good choice.
Christian Großmann avatar
I stumbled with an EF 300 f/4 L on a Bresser Exos1 mount into astro photography. I think, the 300mm range is quite good. But the problem is, that every lens that is made for standard photography is basically a compromise between sharpness and contrast with the focus set to infinity. The stars will usually have some fringes and are less sharp at the edges of the frame. But there are some sharp primes with better values that you can get within your price range. But they will also be a compomise.
If you like to get into that astro stuff, have a look at the askar lenses. They are made especially for astro and you may get better values at infinity. They have a 180mm lens (FMA180) and a 135mm lens (FMA135) that are quite affordable. I never used one of those, but heard a lot of good things about them (but not exclusively). The star adventurer should handle those lenses really well.
That is just my suggestion and the the way I would go. But I am sure, that there are some other opinions here.
Christian
Björn Arnold avatar
I send ahead that I am not photographing with standard lenses (yet) besides a few initial tests.
A question arising for me is if you need a variable focal length (despite using a telephoto lens) or if you’d be fine with a dedicated fixed focal length lens of possibly higher quality?
(It doesn’t answer your question but might open the discussion for different ideas/suggestions)
Besides: what „better quality“ are we talking about? I noticed you don‘t have uploaded images. What do you think are the issues you want to address with a different lens?
CS, Björn
Axel avatar
Canon 200mm f2.8, insane sharpness, check my gallery as I mainly use one.
Axel
Matthew avatar
Björn Arnold:
CS, Björn
so I haven’t uploaded images because I can’t get my stuff to properly work (stacking and editing) I just need someone to physical guide me. My photos keep coming out with quite a bit of noise as well. I was using the cam at 300mm 1min exposure and iso 1600. My star tracker worked great but the images said no. I think it might have been my light pollution filter to be honest. As to why I have an adjustable 75-300 is that I have it for regular photography and learned that it can be used for Astrophotography (to an extent ). I do not need a variable length (while it would be nice but it’s gonna cost more so at the moment no) I’m looking for set focal point that will provide sharp images for Astrophotography for under $550, I want to be able to capture all sorts of objects and why not. I’m looking for a focal point really above 130mm.
I also started with a similar setup. Getting the right focus was really crucial. It took me about 10 to 15 minutes with manual control to set it to the right point. I used Astro Photography Tool at that time, which helped me to get the HFR or FWHM values. At that time, there were not auto focus routines on those software tools. That has changed now and APT as well as Nina or other ones have solutions, to use the motors of the lenses and run auto focus cycles. It is much easier now.
With a focal length of 300mm and your APS-C sensor, you should keep the exposure time at 120s or below. At least in my case, everything above starts to get blurry. With guiding, that would change a bit, but that is the next step. Depending on the light pollution in your region, you have to take a lot of frames to get rid of the noise. I suggest at least 2 hours of data. There always will be some noise left in the frame, but usually it is managable.
Things got better for me, as I started to take calibration frames (bias, flats and darks). While bias and flats are quite easy to take, the darks made some problems. During nights, where the temperature falls very fast, I took 2 lights and after those I took 1 dark. If the temperature is quite stable, you can expand the cycles to 45/15 minutes. I guess, other users have their own opinion about that ratio. But in the end, I used Deep Sky Stacker to get the final image.
Here are my first succesful images with this setup. It took me not so long to reach that point.
https://www.astrobin.com/ozkn6q/
https://www.astrobin.com/t1o4cp/
https://www.astrobin.com/2b6fyp/
I think, that the lens you use is at this point not your problem. It will work and at least in the image center, everything should look ok. With your APS-C sensor, the edges can't get too bad, because the lens is made for full frame.
I'd like to challenge you to keep getting better. The first tries are hard. But if you are succesful, it was worth it. Just keep trying!!!
Hope this helps
Christian
Don't know where you're hailing from but often times you need to look into the used lens market for that price mark. Nikkor 180mm f2.8 AF-ED would be probably a good fit and is good enough for AP at full aperture. There is also the Olympus OM Auto-T 300mm f4.5 which is cheap and holds it own except for some residual violet halo that needs to be filtered or post-processed away. Obviously the Canon/Nikon 300mm f/4 would do if in the more modern variants, again used. I'm not considering more expensive lenses that are obviously above the budget threshold.
Björn Arnold avatar
Björn Arnold:
when you say your issue is stacking and editing then a new lens won’t change the game. Of course, I implied that you have good raw material. That said, I strongly recommend against buying a new lens right now and first nail down where the issue is.
So, here would be my suggestions:
1. Make sure you get your sky tracker dialed in, i.e. you should have round stars in the center of the field under longer exposures.
2. Start with bright targets like M31 or the Plejades which are about to come up nicely.
3. Don’t use the light pollution filter in the beginning. Do it step by step.
4. (Some) Noise will be there. The question is only to which extend. Dialing your camera in is one thing. The other is noise reduction during post-processing.
This list can be easily extended but my point is: analyze the process and identify the major issues. I bet the lens isn’t among the top three.
Also feel free to share data so others can take a look. No serious person will criticize it but will try to be helpful.
Björn
Elmiko avatar
Samyang 135mm f/2 Really well built. Excellent focus bezel ring.
B0bby White avatar
I support Elmiko point.
Within your budget, if 135mm is good and enough for your purposes, Samyang/Rokinon 135 f/2.0 will be honest choices. It's really decent lens: fast & sharp. SA tracker also give you possibility of longer subexposures on such focus length.
You also can try Canon 70-200 IS UMS  f/4.0 for 200mm.
Greg Erianne avatar
Might be a little over your budget, but there’s a new version of the Askar ACL200 Astrophotography lens available at Agena and a few other places.  Don’t know if that’s an option.
Upgrading towards an astrophotographic equipment
Well, after having understood I'm still quite a terrestrial photographer (which, to be fair, holds some truth), I'd have another (perhaps) beginner's question. Currently, I'm taking photos with my ordinary DSLR and its zoom lenses, to...
Discusses astrophotographic equipment upgrades for beginners with budget considerations.
Oct 23, 2023
Small telescope and Star tracker for beginner astrophotography
Hi, I am currently looking for a small refractor telescope to begin astrophotography in the 300-450mm FL range. As I was searching for an ideal scope I very frecuently stumbled upon the WO Zenithstar Z61 and the Redcat 51. They both seem to be great ...
Covers beginner astrophotography gear in similar focal length range.
Aug 30, 2023
First good equipment
Hello all. Im new here. I would like to Ask you about my choice. Currently im user of Sigma 70-300 for my canon 1100d. I know its quite old and not well one. I want to pick up the new one between 150-200mm. Options are 2. Samyang 135 which is a littl...
Similar situation: Canon camera user upgrading from budget telephoto lens.
Oct 1, 2023
